08-06-2018, 01:20 PM | #23 | |
Rep 906
From a value standpoint, I'd roll with the 328 here. However, from a driving pleasure standpoint, the current generation's 335 is far superior imo. I didnt feel that way about the previous generation. I loved my E90 328....but thats because it had the silky smooth inline 6. As mentioned, drive both and follow your heart.
2009 328i xDrive 6MT (Retired and I miss her)
2015 335i xDrive 6MT (Retired and I dont miss her) 2018 M2 6MT (Never retiring) Last edited by Al Bundy's Dodge; 08-06-2018 at 02:09 PM.. |
08-06-2018, 01:34 PM | #24 |
Rep 59
I just recently bought my 335i and i was in the same position as the OP. I decided to get the 335i its more of a rare car where im from and it would hold value later on when i go to sell it. I drove both the 328 and the 335 and after i drove the 328 i wasn't as impressed as i was with the 335. Just my opinion and like someone else said its your decision to make. I love my 335 and im more than happy i picked it over the 328.
08-06-2018, 01:47 PM | #25 |
Rep 77
I love the 335i for the smooth power delivery of the straight six. IMO it doesn't compare to the i4. The extra ponies are welcome too.
Breezin20.00 Lance_Goodthrust4.50 |
08-06-2018, 02:36 PM | #26 | |
Rep 7,047
Which one you should get is the one YOU want. We can only give you our opinions and reasons for why we got what we got. We can't tell you what will be best for you. That's probably what you were really asking anyway. I'm thinking that since you are considering two 3 series that are pretty much the same other than the engines, then you may be wondering if the price of the more powerful 335i's 3.0 turbo inline-6 is worth the extra money over the cost of the lower powered 328i's 2.0 turbo 4. Some will say that MPG is an advantage with the 2.0 turbo. Well, that's not really true in the context of why there is a more powerful 3.0 turbo to begin with. What does that mean? When equipped nearly identically there is very little MPG difference between a 328i/xi and a 335i/xi. The weight difference is under 200lbs in total. The biggest different regarding weight is the lower weight at the front end of the 328/330i or xi. There is around 100lbs less weight at the front of the 328, and that weight is also positioned back towards the front line axle, and closer towards the center of the car. The lower weight and better placed weight gives an advantage to the 328 regarding transitional handling. The overall feel is that the 328 feels lighter and more nimble during sportier drives, and that's a very positive advantage. The 2.0 turbo 4 is an excellent engine and produces strong low rpm torque as well as developing a very linear and flatter torque curve throughout it's power band. That flat and broad torque is why this car is a lot faster than one may initially think. Plus, couple to the ZF 8spd, maximum performance can be extracted. The same is true of the 3.0 turbo 6 in the 335i. It too have a broad and flat torque curve, and it's stronger than the 2.0 overall. As good as the 2.0 is the 3.0 is even stronger and gooderer. That's obvious of course as it's displacement is 50% larger from the 2.0, or the 2.0 is 33% smaller from the 3.0. Interesting that. With an AT the 335's engine is couple to the same ZF 8spd AT. And, the gear ratios are even the same with either engine. The 3.0 does sound better overall, to my ears at least, as it is the renowned and classic BMW inline-6 engine design. The 3.0 is also smoother in operation. It's like quiet and like butter at idle, and it retains the wonderful smoothness all the way to it's red line. Fantastic. Some will say the 328/330's 2.0 will give you better MPG. Not so fast on that. Even with BMW's and the EPAs tested rating, the 2.0 is 22mpg city & 33mpg highway w/26mpg combined. So, the 2.0 is rated at only 1mpg better on the highway. The reason for that is simple. To produce more power requires more air and more fuel. The 3.0 when driven like the 2.0 will need about the same amount of fuel. There is nothing magical about a smaller engine that it can get better MPG. It produces a given power that requires a given amount of fuel. And since the 3.0 can produce the same min and max power as the 2.0 can, it will then use about the same amount of fuel. Now, if you want more power and greater acceleration, the 3.0 can go beyond what the 2.0 can produce, and that thus requires more fuel. So that is where the 3.0 will get lower MPG, when it's producing more power and accelerating faster than the 2.0. Still, there is a prevailing conviction that the 328/330 get's "better or much better MPG than a 335/340. And that is just not true when it comes to actual MPG for daily driven cars, driven in the same manner where maximum power is not called on for the majority of the time. Another factor that may be true is the insurance premium. You need to check with your insurance agent to see if the 328xi has a lower premium than a 335xi. There could be a greater difference in premiums in certain markets and/or certain age groups. Which one to get depends on what you want and how much you are willing to pay for it. If you want the greater power, smoother engine, better engine and exhaust sounds, then get the 335xi. You could get a 328xi and then get a tune, and get a different exhaust, and that will cost you money and time. And if your new/used BMW has an extended or certified warranty, those modifications can and will affect warranty coverage by stated warranty and law. Also, modifying an engine to produce more power, without modifying the internals to cope with the added stresses, will reduce the engines longevity. All of that factors in. If you like and want the power of the 335xi, then pay the extra and get that power already designed and built-in. If you don't like or want the extra power of the 3.0, then there is not need to pay extra for it cause the 328xi's 2.0 is a fantastic engine in it's own right. Let's us know which one YOU choose. |
alohasurftoad3076.50 Breezin20.00 |
08-06-2018, 02:41 PM | #27 |
Rep 409
I am going to drive both but am leaning hard towards the 335. Just feel I wouldn't have to do anything further to it to get the performance and sound I am looking for. I am not looking to drive the car like a teenager every day. Only a couple days a week like that.
Will report back. |
08-06-2018, 02:43 PM | #28 | |
Rep 4,446
Drives: '23 X1 28i xDrive
If the cars were equipped the same, and had around the same mileage, then I would definitely go with the 335. But with 20K more miles on the 335, I'd probably be more inclined to go with the 328. But you have to live with the decision. |
wrickem2101.00 |
08-06-2018, 04:19 PM | #30 | |
Rep 103
08-06-2018, 04:33 PM | #31 |
Rep 5,088
08-06-2018, 04:56 PM | #33 |
Rep 8,942
We have a stock 328, Dinan 328 and Dinan M235. The stock 328 is totally fine and quick enough. The only time it's a problem is when I haven't driven it in a while and need to adjust what I'm used to and drive a little differently.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
rayxi40.00 |
08-06-2018, 05:36 PM | #35 |
Rep 155
If I were to do it all over again I'd get a 335. Speed/acceleration has never been an issue with the 328, but smoothness of the power delivery has.
You say the 328 is loaded, but I'm skeptical as to what this actually constitutes. Very few 328s are spec'd with adaptive headlights(standard on 335i). Most 328 msport models also don't have the brembo brakes (standard on 335i). And since you seem to be set on x-drive, the suspension is going to be soft and mushy unless either of the cars comes with dynamic handling pkg(again rare on 328). That being said, the 328i is considerably cheaper, and when I had to make the choice you are making, I chose the Msport 328i over lesser equipped 335s. This was on the basis that I wanted an estoril blue msport with a heads up display, adaptive headlights, and non dynamic sport suspension. While I wish it had heated seats, a back up camera, parking sensors, and the harmon kardon sound system, the biggest disappointment to me has to be the depreciation. 328 msports appear to depreciate faster than any other F30. It appears the one you're considering has already depreciated considerably, so perhaps that won't be an issue. That being said my most pleasant surprise, have been the ergonomics and reliability. The car has been nearly trouble free for the 50k miles I've owned it. And then something about the Msport F30 fits my proportions better than any car I've owned to date. This can almost exclusively be attributed to the sport seats and msport steering wheel(I wouldn't buy a 335i without these which based on the price I imagine the one you're considered is missing). However, even things like the height of the window sill, and position of the arm rest aid in comfort that cars portraying themselves as considerably more luxurious cannot match. |
rayxi40.00 Lance_Goodthrust4.50 |
08-06-2018, 05:41 PM | #36 | |
Rep 3,211
08-06-2018, 05:54 PM | #37 | |
¯\_(ツ)_/¯
537
Rep 1,000
You said they were within 5000 milage, 41000 and 22000 aren't within 5k. Wtf. I was gonna say go for the 335 when the milage was close but like that I'd probably go with the 328... actually fuck it go with the 335i it'll be more enjoyable |
tex26702412.50 Lance_Goodthrust4.50 |
08-06-2018, 07:29 PM | #38 |
Rep 4,446
This is why Common Core Math sucks.
08-06-2018, 08:16 PM | #39 |
Rep 153
I've got a 335i and had the dealer install a Dinan Stage 1 tune on it. I've been very happy with the results, although I don't know if I'd go with Dinan today based on the complaints I've read regarding their customer service.
Trust me, even if you get the 335i you want to put a Stage 1 tune on it. Turned the car into what it should have been in the first place. Last edited by VCuomo; 08-07-2018 at 03:21 PM.. |
08-06-2018, 08:19 PM | #40 |
Rep 5,457
Drives: F30
Dinan does seem to be lacking big time since the change in ownership. Sad but all too common these days!
08-06-2018, 11:44 PM | #41 |
Rep 3,622
If you can afford the 335i get it.the 328 is a great car but the N55 was an award winning engine and bmw's in-line 6 is a truly awesome thing.
Everyone here voting for the 328i is likely trying to justify their own buying decision. No one with the 335 is wishing they had gotten a 328
BMW CCA Member #516012
08-06-2018, 11:54 PM | #42 | |
Rep 5,457
Drives: F30
Do your homework! |
08-07-2018, 01:44 AM | #43 |
Rep 5,088
sspade2464.50 MacklinUSOB518.00 |
08-07-2018, 08:54 AM | #44 |
Rep 1,290
All else being equal, I'd pay more for the 335i without hesitation. Unfortunately though, the 335i has twice as many miles as the 328i. In this situation, I'd keep looking until I found another 335i or 435i msport, but with less miles on the odometer.
When shopping for a 3 series I never considered a 320 or 328i. My approach was that if I couldn't get a bmw with the I6, then I wouldn't get a bmw. That's just my personal bias though, since you solicited opinions. I'm not saying that there's anything wrong with a 328i. Plenty of people love them. It's just not for me. I'd suggest a couple of good test drives in each to see how they suit you, and go from there. |
