06-25-2023, 03:17 PM | #1 |
![]() ![]() ![]() 299
Rep 587
Knocking in steering rack during hot weather - fix
Hi,
I have fixed steering rack knocking noises that used to appear during hot weather, especially on a long run. It was steering rack indeed, aware there are 2 types, mine is 'no repair kit' one, and it is sorted by tightening the nut. Some people reported tightening it by about 20degrees, mine had more than, didn't pay attention but not far from a full turn. Tightened it all the way that steering is just about impacted (feels slightly heavier, although returns to neutral position), in fact it doesn't wobble as much as it used to on the bumps via force transfer from body and hands, perhaps closer to how it used to be when new? No idea- haven't owned from new. For those DIY, if you open window while car is on axle stands it is possible to feel the steering wheel to see how resistance is changing, although there will be no change for some of the first degrees, which possible will already make a change on knocking. A bit more about the problem on the link below https://f30.bimmerpost.com/forums/sh....php?t=1919184 |
06-26-2023, 10:45 AM | #3 |
Rep 587
ZF = no kit (thats my rack, where you just tighten nut)
Thyssenkrypp (repair kit available) Difference is obvious by looking at rack, if its a standard 17 hex nut = ZF, if its a 3 pin slot drum = Thyssenkrypp Images of ZF rack with 17mm nut Last edited by Allworth; 06-26-2023 at 11:02 AM.. |
MY340i828.00 |
07-07-2023, 08:41 AM | #5 |
![]() 1393
Rep 1,747
It is exactly where he has pictured above, in the left picture. You'll need a torch or LED work light to see it but it's clearly visible when you get your viewing angle right.
If you can't see it, call up your dealer and ask them if part number 32106891974 is compatible with your car. |
07-07-2023, 03:00 PM | #6 |
![]() 1393
Rep 1,747
When winding the tensioning block in, you may find the steering weight varies depending on ambient temperature. Heavier when cold, lighter when hot. There's a very fine adjustment point between too little and too much tension. The steering controller doesn't seem to complain about too little or too much motor current in either case, so it's purely a subjective feel thing.
It can be adjusted in situ without jacking it up, so quick and easy to experiment with. |
07-07-2023, 08:04 PM | #7 | |
![]() 66
Rep 196
07-11-2023, 09:53 AM | #8 | |
![]() 66
Rep 196
07-14-2023, 02:56 PM | #9 |
![]() 1393
Rep 1,747
OK, sweet, it's £50 plus a couple of hours labour well spent. Probably out of stock as so many of these cars need the repair kit!
Or you can do it yourself, it's not hard. You may not be able to get the tension exactly as BMW prescribe with their 10 page instructions and half a dozen special tools, but I had it done by them and ended up backing it out anyway as it didn't feel right. It's very subjective. |
08-04-2023, 10:03 AM | #10 |
![]() 66
Rep 196
My local indie doesn't carry out the repair unfortunately, they remove & send for repair + geometry adjustment & labour is £1233.00!
Has anyone else had it done in the west midlands? |
08-12-2023, 03:52 AM | #11 |
Rep 587
08-15-2023, 08:58 AM | #12 | |
![]() 16
Rep 224
Am I right in saying that if it was my steering rack, I would be able to re-produce by moving the wheel lock to lock stationary? My knock (right side of vehicle I believe through the steering wheel) is most noticeable when: Low speeds over small bumps or notches in the road, but I mean crawling, above this it doesn't seem to do it. Coming to a stop, or setting off, any change of motion really, again the slower I do this the more noticeable. Seems more apparent in the heat. Took to local garage but they couldn't find or reproduce.. |
08-15-2023, 01:05 PM | #14 |
Rep 587
08-19-2023, 06:47 PM | #15 | |
Rep 1
I fixed it
See you, hope this helps Last edited by Kikocadillo; 08-19-2023 at 07:00 PM.. |
08-20-2023, 08:13 AM | #16 | |
Rep 587
08-28-2023, 07:28 AM | #17 |
Rep 18
Have suffered the same symptoms as TurboWeasel, but when looking for the tensioning nut on my ‘18 340i F31 couldn’t see anything? It is much more crowded in that area thanks to the intake for the turbo, but am I missing something? Should I look from underneath rather than on top?
08-28-2023, 10:43 AM | #18 | |
Rep 587
08-29-2023, 06:36 AM | #19 | |
![]() 828
Rep 1,544
08-29-2023, 08:09 AM | #20 | |
![]() 1393
Rep 1,747
It might be easier to jack it up and look from the bottom if that's the case as the bayonet clip on the turbo inlet can be an absolute arse to remove from above. |
12-03-2023, 05:02 AM | #21 | |
Rep 3
sspade2527.00 |
