07-26-2024, 09:26 AM | #23 |
![]() 1393
Rep 1,747
Highly unlikely from BMW or ZF, but check Lemforder's catalogue as ZF is part of the same group.
Or see if a breakers yard will sell you just the cover, but that is also unlikely. Or phone around a few steering rack refurbishers to see if they have any spares kicking around, or can suggest where to get one from. They obviously need to get parts, so they might have contacts the public don't. |
07-30-2024, 10:06 AM | #25 |
![]() ![]() ![]() ![]() ![]() 245
Rep 727
Are the genuine kits far superior to the compatible ones, seems to be huge difference in cost, have not rung a dealer yet, but online genuine ones seem to be around £120
07-30-2024, 12:13 PM | #26 |
![]() ![]() ![]() 299
Rep 587
I had my kit for £25 off a dealer last year, watch out what you are buying.
1995 E34 525td auto • 2016 F30 320ed auto
07-31-2024, 12:03 AM | #28 | |
Rep 587
For consideration - if welding a nut or a socket on-to a rack's nut, is made of aluminum! There are nut extractor sockets available to get it out, if replacing.
08-02-2024, 02:43 PM | #31 |
Rep 6
08-02-2024, 05:15 PM | #32 |
![]() 1393
Rep 1,747
08-09-2024, 09:04 AM | #33 |
Rep 6
**UPDATE**
The part from the Vauxhall insignia steering rack is a 100% match. Now installed knocking has gone away (for now) |
08-09-2024, 10:37 AM | #34 |
![]() 1393
Rep 1,747
Nice one
![]() Vauxhalls are good for something then ![]() ![]() Still, it does prove how incestuous the car industry is I suppose. |
09-07-2024, 05:10 AM | #35 | |
Rep 3
Did you take out the yoke (30) and insert foil (30.1)? And swap over from the Insignia rack? Was the insert foil showing wear on the BMW rack? thanks, Douglas |
09-07-2024, 05:27 AM | #36 | |
Rep 3
I have the hot weather knocking on the ZF rack and I've made a small adjustment (initially c.36 degrees - but the self centering was too reduced, so knocked it back to c.23 degrees) to the adjusting screw (34) but the shallow soft alloy nut has given in slightly. I'll be sure to use a 6 point socket for any further adjustments, and one that has faces as close as possible to the open end of the socket. Fingers crossed. I realise no similar kit is available for ZF racks but I wonder if the the yoke (30) and especially the insert foil (30.1) are available as spares, as I assume the foil is where the wear is. thanks again, Douglas |
Allworth298.50 |
10-25-2024, 01:29 AM | #37 |
![]() 2
Rep 22
11-04-2024, 09:49 AM | #39 |
Rep 1
Do you have more information regarding the Vauxhall steering rack? Part no or certain models/years which are equipped with ZF racks. Appreciate your answer!
11-13-2024, 02:39 AM | #40 |
Rep 1
Helo have you found the part number? We dont have vauxhall car her in indonesia maybe i can get it from ebay
11-14-2024, 05:02 AM | #41 |
Rep 1
For anyone who adjusts the ZF rack via the 17mm nut, if the problem persists, there is a service bulletin on it. It’s the inner tie rods from factory. I had a knock that I felt through the steering wheel but wasn’t audible when hot of after a significant run of about 30 miles. I tried tightening the nut which didn’t work. Change the tie rods both sides and it was resolved. https://static.nhtsa.gov/odi/tsbs/20...66230-9999.pdf
03-13-2025, 07:39 AM | #42 | |
![]() 4
Rep 51
Тhank you man! Will give it a try ! ![]() |
03-13-2025, 02:34 PM | #43 | |
Rep 587
My case was something bonking, clunking, wobbling when driving straight at slow speeds, and never when turning. That manual mentions that 'TK' racks are unaffected, is hard to agree with this, as I have witnessed videos where people sorted their issue with a kit. Although is interesting material; they show corrosion on ball joint, as if it is worn out by friction due to lack of lubrication -- can see a loose fit on the right ball joint comparing to snug fit on the left ball joint. IF tightening the yoke stabilizes steering rack's shaft and ball joints are worn as it is on the right image, then this explains why tightening the yoke or changing ball joints rectifies the issue. Is quite complex. It seems to me, these two issued can be related to each other, and, if it is the case, then reserving the right to say that tightening the yoke can help either way. Lastly, temperature difference is crucial for knocking occurrence. Looking at how loose is the fit on the right image, and knowing the expansion coefficient of metals, a temperature delta of even as much as 50 degree hardly explains how the knocking may depend purely on this factor. Seems to me to do with lubrication, or the lack of it...
