BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > engine knock issue
proTUNING Freaks
      11-05-2024, 09:46 AM   #1
lowzero
Drives: bmw 535GT
engine knock issue
hey guys!recently i flashed bm3 for my 535gt.i found that theres some knock in my engine.following month i cleaned the Carbon deposits in cylinders,and replaced the spark plugs with original parts.but it seem useless,there is still knock in the datelog. how can i fix it???
here are 2 logs
https://www.bootmod3.net/log?id=671f...32f364f8fdab87
https://www.bootmod3.net/log?id=672a...a92c3aa60407fd
full exhaust,kn high flow rate filter and upgrade intercooler are equipped
      11-06-2024, 09:52 PM   #2
Tejas1836
Tejas1836's Avatar
1230
Drives: 2023 X5MC Workmaster 75
Remove the flash???
Two is One and One is None
      11-08-2024, 03:35 AM   #3
lowzero
Drives: bmw 535GT
Originally Posted by Tejas1836 View Post
Remove the flash???
not working still knock in stock tune
      11-08-2024, 04:05 AM   #4
John H.
John H.'s Avatar
Drives: 2022 G15
Possible mechanical issue/s. I would advise to have it inspected by a technician. Any codes?
      11-13-2024, 09:46 PM   #5
lowzero
Drives: bmw 535GT
inspect which part?no code exists.
      11-14-2024, 07:26 PM   #6
Dasky_spas
Drives: Bmw
Try different fuel station/brand if you fill up at the same station. Start with the easiest variables first.
      11-16-2024, 08:21 PM   #7
BimmerWu
Drives: BMW 325Li 2021
冷车启动,开了8公里左右吧,进气温度来到了 60 度
水温油温其实是低的,不到原厂开格栅的条件
水温油温低,进气格栅不开(保温节能),高流量空滤疯狂吸机舱内的热空气,此时再走高增压低点火角的程序, 就容易爆震
我猜此时如果是原厂空滤,反而进气温度可以低一点,因为没有那么顺畅,有一个热交换
      11-17-2024, 09:47 AM   #8
BimmerWu
另外可以切回原厂程序看看,对比一下
      11-21-2024, 08:23 PM   #9
BimmerWu
BM3 Tech Support has helped me fix it.
Active radiator flap now can keep open when engine on.
And keep close when engine off.
