BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Cal Speedway Roval
proTUNING Freaks
      05-24-2015, 08:18 AM   #1
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
Cal Speedway Roval
Had a blast at CAL SPEED ROVAL / Bimmerfest.
https://youtu.be/9Z_6sd7exKI
ADD: Anyone having same issue with 'Chassis Malfunction', I have EDC but deleted with KW EDC DELETE module...i guess it doesn't completely remove the EDC. After 3-4 laps, I get 'Chassis Malfunction' and engages the traction control.
G05 - M Performance roof spoiler
      05-25-2015, 08:45 PM   #2
danielleraecer
#ladydrivenamerica
Drives: 2017 F87
I started to get a "Chassis" warning when I took my F30 to the track for the first time. I ended up having a warped rotor, but that's it.
Had a blast at bimmerfest too!
      05-28-2015, 12:43 PM   #3
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
Thanks, I'll check it out but I think it has to do with DSC according to Autologic.
      05-28-2015, 02:27 PM   #4
drob23
drob23's Avatar
Drives: S4
That really sucks, because those KW deletes are not cheap. Hope it isn't hard to figure out the problem. How does it affect the vehicle other than throw the hard code?
UNDRSTR
      05-28-2015, 02:28 PM   #5
drob23
drob23's Avatar
Drives: S4
Wow...you really warped a rotor? Usually this isn't the case, I would imagine you put some pad deposits on them: http://stoptech.com/technical-suppor...nd-other-myths
UNDRSTR
      05-28-2015, 02:47 PM   #6
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
Really bad...because it engages the traction control on which gives mass of acceleration delay.
      06-07-2015, 04:31 AM   #7
M3 Number 86
Drives: black m3
I have an m3 but had edc I never bought a module I just disconnected the harness in the trunk. try that.
      06-07-2015, 08:15 AM   #8
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
What year is your m3? All the F series are different, you need the module to delete.
Thank you for the tip though
      06-07-2015, 02:54 PM   #9
M3 Number 86
Drives: black m3
2011 but I have kw clubsports and edc. And everyone says you need to buy the module which is false. Just unplug the harness. It can't be too different. It's worth a try!
