BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > EGS fault codes CF1501, CF1541
      02-23-2020, 01:10 PM   #1
hatak
Drives: BMW4 GC
Hi I have 430ix GC which has recently been tuned using flash tune from my local tuner it resulted in 305HP / 443NM Car drives very well and it is great change, however I've made fault code scan and two showed up under EGS
CF1501
CF1541
There is not much information about those, however in one of threads I've seen guy had same code CF1541 when he installed bootmod3
So I wonder if they could be related to to the fact that flash tune is installed.
I have no other issues, I've tried delete those codes but they returned.
Any thoughts on that ?
Regards
Maciej
      05-25-2020, 07:50 PM   #2
Estoril_AJ
Drives: 2014 335i xDrive M-Sport
Did you ever figure out what the issue was with both codes? I have the CF1541 code and cannot seem to find an answer. The only SB from BMW I can source states something about the wiring harness for the EGS
      05-31-2020, 10:42 PM   #3
obeeone
obeeone's Avatar
22
Drives: 2015 BMW 335i xDrive
Currently going through this right now as I have the cf1541 error code active under transmission errors. Saw the same SB about EGS harness and was curious if you guys solved anything?. I did install my chargepipe not long ago and the EGS harness is right there so I wonder if I knocked something around there.
I did try to clear the codr, but it wont clear.
      09-30-2020, 09:05 AM   #4
Sebastian5020
Drives: 435 M Sport Edition
I found that because i have the same problem!
https://static.nhtsa.gov/odi/tsbs/20...46572-9999.pdf
      09-30-2020, 10:58 AM   #5
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
http://bmwfault.codes/
They have notes on almost all fault codes. Even CF1541.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      10-01-2020, 07:36 PM   #6
el_couzin
Drives: f30
same code here and I'm not quite sure where to start!
      02-03-2021, 04:14 AM   #7
hatak
Drives: BMW4 GC
Well they flashed it again, and it went away
      02-03-2021, 08:40 PM   #8
el_couzin
Drives: f30
thanks for the update.
my car still has the code and isn't tuned. it might have been tuned by one of the previous owners.. who knows
