10-26-2019, 10:12 AM | #23 |
Rep 121
10-30-2019, 10:37 AM | #24 |
Rep 59
That didn’t last very long! Just got done driving it and this no longer works! Went back and checked all the settings and they have remained the same. The seat will just not go back when the door is opened like it used to! Tried recoding it to no avail. Any suggestions appreciated.
10-30-2019, 10:19 PM | #25 | |
Rep 121
10-31-2019, 08:13 AM | #26 |
Rep 59
Thanks. Tried to put it back to 32 and then tried 28 but neither had any effect. Seems like I’ve lost the ability to save anything to the drivers seat! Tried to use the memory position that I had previously used and it’s been wiped out and cannot get it to reset! But, I’m getting no error codes either
12-02-2020, 06:47 PM | #27 |
Rep 27
Drives: 2015 435i m sport estoril blue
My 435i was coded on 11/29 by the dealership. It erased all of my custom coding, luckily I had a list of what I did. I discovered the the update changed the options for the easy access. The options under 3012 moved to 3015. They now need to be the following:
3000 EINAUSSTIEGSHILFE set to:Modus_FA_SLV 3015 EAH_VERFAHRWEG_SLV_PHYS werte = 00, 3C 3015 EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS werte = 00, 32 |
09-07-2021, 04:19 AM | #29 |
Rep 1
11-02-2021, 10:09 AM | #32 |
Rep 27
I doubt it, I'm sure it is a safety issue. BMW would not want a seat moving by itself while in drive. Probably only allow manual adjustments by a person.
