01-29-2020, 07:01 PM | #551 | |
Rep 98
01-29-2020, 07:25 PM | #552 | |
Rep 1,454
01-29-2020, 07:38 PM | #553 |
Rep 179
Ya, I'm trying to find the lowest mileage replacement I can. Curious.if the euro b58b30a fits my car the same as us spec. Theres some decent looking 5-7km engines in Germany and the uk. Any coding required on a motor swap? I would think my dme wouldn't notice that it was a change mechanically, just new sensors being read...
01-29-2020, 09:17 PM | #554 |
Rep 201
01-29-2020, 10:46 PM | #555 |
Rep 179
Bought the car w/ 37k in October and quickly got the bug...started w/ intake and downpipe, then bm3, then exhaust, carbon everywhere... you know how it goes lol. The car ran like new all the way up until she didnt. The only code I ever pulled was a mass airflow code when I hadn't attached the intake boot completely and was sucking in un-metered air. A quick fix and a clear of the codes and no other issues along the way. I had been counting the days until my VTT GC turbo arrives so I could get that installed and get a custom Cary Jordan tune. I PLANNED on my trip to the dealership being to get a M Performance Diff, not to get told my warranty was void and I need a new motor... such is life though I suppose
01-29-2020, 11:59 PM | #556 | |
Rep 446
Mod bug will bite you if you buy a BMW ================================= |
01-30-2020, 05:49 AM | #557 |
Rep 98
It’s a metallic tapping/rattling on cold start. It happens after the car has sat over night but the sound is hard to pick up in a video. They were saying the waste gate isn’t sealing completely when it’s cold. It sounds like other people have had this issue and the dealer says that it’s normal... The sound usually goes away when it’s warmed up but not always.
01-30-2020, 07:59 AM | #558 | |
Rep 201
Again- best of luck to you and any info is appreciated! |
Supr3me551.00 |
01-30-2020, 09:41 AM | #559 | |
Rep 79
les anderson145.50 kern4174446.50 |
01-30-2020, 10:43 AM | #560 | |
Rep 446
01-30-2020, 11:13 AM | #561 | |
Rep 98
"Minor play in wastegate arm, suspect wastegate seat is not fully seating.... took video of noise with second tech and submitted to tsara for turbo replacement... Instructed to remove wastegate linkage to check for binding and play in wastegate arm. Found no binding when moving wastegate arm from one end stop to the other. Felt some play in wastegate arm. Submitted video to tsara case of play in wastegate arm. Instructed there is not enough play in wastegate arm to replace turbo. Instructed to check wastegate flap to see if its sitting flush. Removed spark plug and inspected wastegate flap with bore scope. Wastegate flap is sitting flush. Instructed per tsara noise is normal operating noise and not enough evidence for turbo wastegate failure." I'm going to keep an eye on it, I'm not convinced this sound is normal. The turbo on my old passat had wastegate rattle and was replaced... I just saw your thread on the cylinder wall scoring in your B58 - How's that going? Any updates? |
01-30-2020, 11:50 AM | #562 | |
Rep 179
I have not yet contacted BMWna or ptf directly. I was driving normally when the failure occurred, about 45mph uphill. I do not have any recent logs. I know there are other documented cases of cylinder scoring during to injector/ plug failure. Hoping to appeal to BMWna based on the fact it was no probable result of the software. The car has lived its life in Wa. |
01-30-2020, 12:14 PM | #563 | |
Rep 231
01-30-2020, 12:19 PM | #564 | ||
Rep 1,239
01-30-2020, 12:45 PM | #565 |
Rep 179
That's exactly what they will say, I just have to prove it is a hardware only issue and has happened exactly the same way in stock vehicles.
01-30-2020, 12:48 PM | #566 | |
Rep 201
If it is me, I am not going silently on this and would start to make that fact clear. https://en.wikipedia.org/wiki/Magnus...s_Warranty_Act |
01-30-2020, 12:49 PM | #567 | |
Rep 201
01-30-2020, 01:16 PM | #568 |
Rep 79
I'm sure that would be their reply, but it doesn't address the fact that the same failures have occurred regardless of the software the DME is running. They *should* have to prove the the software directly caused the engine failure, but we don't really live in that world I guess.
02-01-2020, 03:43 AM | #569 |
Rep 281
This has got me concerned about mapping now. Was going to press the button when the warranty runs out in a few months. May have to think twice.
InstigatorX58.00 |
02-05-2020, 12:50 PM | #570 |
Rep 7
Hi All
For info. I’ve have a 440i with 13k on it. It has been running “lumpy” at 1000 rpm with an apparent problem with no5 cylinder. Garage cannot pinpoint the problem. This week it is getting a new engine fitted. It is a standard engine with no mods. Regards. |
02-06-2020, 09:07 AM | #571 | |
Rep 10,256
Is the garage a BMW dealer? What diagnostics did the garage perform? No stored codes? Spark plugs OK? Compression test OK? |
02-06-2020, 09:14 AM | #572 |
Rep 7
Hi
Yes Bmw Uk garage. Injector replaced and spark plug. Apart from that, I or they seem to be unable to cast any light on it. It has been in the garage for 5 weeks. I should get it back this weekend they think. Can’t imagine a new engine will be cheap. Hasn’t put me off the car. Ps I’m no engine expert. |
b58 |
