BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Active navigation code
      09-23-2018, 02:09 AM   #1
Elvings
Elvings's Avatar
Drives: F30 320
My F30 need 21 code characters for active navigation
      09-23-2018, 02:21 AM   #2
Elvings
Elvings's Avatar
Drives: F30 320
My car acutely is no have navigation system
So I change the head unit
This head unit have navigation system
So I coding my cars VO606 already
So the screen can saw the navigation line
But is black color
Not active
      09-23-2018, 02:23 AM   #3
Elvings
Elvings's Avatar
Drives: F30 320
Without VO606
      09-23-2018, 02:25 AM   #4
Elvings
Elvings's Avatar
Drives: F30 320
After coding VO606
But still can't work
      09-23-2018, 02:28 AM   #5
Elvings
Elvings's Avatar
Drives: F30 320
Now use ISTA+ scan
Say need
20 characters active navigation
      09-23-2018, 03:31 AM   #6
Elvings
Elvings's Avatar
Drives: F30 320
Anyone can teach me ?
      10-18-2018, 02:47 PM   #7
to.mi.potiski@gmail.com
Drives: bmw F31
I have the same problem but the problem is in the head unit it has the wrong VIN number. Thats way the NAVI is grey. Pliss reply if you solve the problem.
      10-18-2018, 05:40 PM   #8
Jhnblckwood
Drives: F30 2014 320i xdrive
U need an nbt navigation emulator or expensive fsc code
      10-18-2018, 05:41 PM   #9
Jhnblckwood
Same with u.
      10-29-2018, 03:56 PM   #10
Drives: bmw F31
i have a question. I got the repair code for the NAVI and i insert the activation code in the ISTA/D and it was successful. But the NAVI is still shadowed?
      01-13-2020, 01:32 AM   #11
Piotr Wi
Drives: F30 320d 2018
And did you find solution, i have same issue but i've already use navi emulator and result as in yours sample
      01-16-2020, 06:09 PM   #12
RuleNormaliai
RuleNormaliai's Avatar
24
Drives: F31 320d EfficientDynamics
Are theese NBT units or EntryNav? If NBT i can help
      04-13-2021, 04:54 AM   #13
ExQt0r
Drives: BMW F30
Mine is NBT. Can you help?
      04-13-2021, 11:49 AM   #14
Zheez
Drives: 320D (2014)
As per the other thread, if you have a 6.5" screen you don't have NBT - you will have the version of HU_ENTRYNAV without navigation. The name is confusing, but there are two versions of it, with and without nav.
