BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Low coolant
proTUNING Freaks
      02-14-2020, 11:14 AM   #1
Benjt2
Drives: 2013 F30 335i RWD
Low coolant
Alright so I have a 2013 335i PWG, just recently my low coolant light came on, I had a flush early last year, so I checked and yeah its low, still some in res. But not a lot. Car is on a stage 2 custom tune.
How often do head gaskets fail? And Turbos? Idk where I'm losing coolant but I haven't found any leaks yet and the only thing I have noticed is my exhaust smells different then what i remember idk though. I don't know how to start diagnosing this and I want to before it gets worse and starts causing a lot more damage. Any help or insight will be greatly appreciated and I can give out as much info as needed.
Thanks to anyone who has anything to say!
      02-14-2020, 03:00 PM   #2
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
Did you try purging the system of possible air bubbles?
Did it go low again after you topped it off?
      02-19-2020, 12:13 AM   #3
BMWinAZ
BMWinAZ's Avatar
104
Drives: 2013 335i, ‘08 328i, ‘03 316ti
If your headgasket failed you should see the „milkshake" on your oil filler cap and also have a smokey exhaust. Check your oil filter housing gasket. I had a leaky one on the Mini and really didn't see much dripping while the engine was not running. On an F30 all the undercladding would easily mask the drips. The source of the leak only became apparent when my mechanic and I looked at the engine while it was running.
      02-19-2020, 12:20 AM   #4
BMWinAZ
BMWinAZ's Avatar
104
Another source of a low coolant light could come from running the heater for the first time after a coolant flush. If you or your shop don't run the heater right after refilling the coolant, turning the heat on for the first time a few weeks or months later, can cause low coolant levels due to the heater core siphoning off coolant. Happened to me a few years back in my old E83 X3.
      12-15-2020, 05:05 PM   #5
harmanonline85
harmanonline85's Avatar
Drives: BMW 328XI
I have a 2013 328xi and i always get the low coolant warning in winters. I got it checked and there were no leaks and the coolant level was right upto the mark but still it shows low coolant warning on idrive. Sometimes it goes away after the car runs for a while but sometimes it stays there. Any suggestions/inputs?
      12-15-2020, 10:15 PM   #6
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
It's probably a defective sensor, but to be sure you need to run a diagnostic to see what codes come up.
      12-16-2020, 06:56 AM   #7
harmanonline85
Drives: BMW 328XI
I will get it checked this weekend. Thanks for your help!!
      01-02-2021, 10:51 AM   #8
harmanonline85
Drives: BMW 328XI
Update- Had to get my coolant expansion tank changed since the sensor was faulty...got it replaced and now no warnings😌😌
cfm56d7b5886.00
      01-02-2021, 03:48 PM   #9
cfm56d7b
Replacing the faulty sensor is much less disruptive and less expensive than replacing the head gasket. Thanks for sharing the root cause.
