07-08-2020, 02:51 PM | #331 |
Rep 18
So I have a strange question,
I looked at retro fitting the tpms system to my 2012 F31, but looking at the need to make a look and buy a new controller ECU and the sensors kinda put me off. However o still prefer the look of the metal tyre vales, so my question is can I buy a service kit( which is the metal valves) and fit these to my wheels without the sensor attached and use them just as metal valves? Or anyone know of a retrofit kit Inc loom at a reasonable cost? Many thanks Moto |
07-08-2020, 03:39 PM | #332 | |
Rep 2,302
You can just install the metal valves. But after that the wheel should be balanced, as the metal valve is heavier and can lead to an imbalance. |
07-09-2020, 03:59 AM | #333 |
Rep 18
10-14-2020, 01:19 PM | #334 |
Rep 18
TPMS error
I have a F30 330d 2016 model I have done the coding but I keep getting an error. I tried the coding on the beginning of the thread but I don't need a tpms receiver so I am missing something
My TPMS must be part of the DSC. What is the correct coding for Newer model cars 2016 models? FEM RC_RDC_ENABLE = aktiv ICMQL IcmKod_B_S2VBA = verbaut DSC C_Funktion_RDCi_l = nicht_aktiv C_Funktion_RPA_e = nicht_aktiv C_RPA_Extra = nicht_aktiv HU_NBT RDC = aktiv RDC_DRUCK_TEMP = aktiv RDC_FORTSCHRITTSANZEIGE = nicht_aktiv REIFENUEBERWACHUNG_RDC_RPA = rdc RPA = nicht_aktiv KOMBI ST_TYR_RDC_ALIVE = aktiv ST_TYR_RDC_TIMEOUT = aktiv KOMBI DSC_MIT_RPA = ohne_RPA |
10-14-2020, 03:18 PM | #335 | |
Rep 2,302
DCS C_Funktion_RDCi_l = aktiv and HU_NBT RDC_FORTSCHRITTSANZEIGE = aktiv (not important) But that's not a guarantee that it will work. For some people it worked, for many people it didn't work that easy. |
10-28-2020, 01:10 PM | #337 |
Rep 18
TPMS still not working
I have coded the following
FEM RC_RDC_ENABLE = aktiv ICMQL IcmKod_B_S2VBA = verbaut DSC C_Funktion_RDCi_l = aktiv C_Funktion_RPA_e = nicht_aktiv C_RPA_Extra = nicht_aktiv HU_NBT RDC = aktiv RDC_DRUCK_TEMP = druk_und_temperatur RDC_FORTSCHRITTSANZEIGE = nicht_aktiv REIFENUEBERWACHUNG_RDC_RPA = rdc RPA = nicht_aktiv KOMBI ST_TYR_RDC_ALIVE = aktiv ST_TYR_RDC_TIMEOUT = aktiv KOMBI DSC_MIT_RPA = ohne_RPA I have the upgraded dsc its a 07/2015 build F30 VIN NT48013. Everything is there no errors after coding but no indication of tyre pressure or temp it stays dashed. Any suggestions are welcome. Last edited by Iceman777; 10-28-2020 at 01:12 PM.. Reason: Spelling |
11-19-2020, 02:18 PM | #340 | |
Rep 79
I'm having issues with my original rdc system intermittently showing rdc system not active. 99 procent of the time, it just works fine. the faults given, always come from one or 2 front wheels. Sensors, changed but problem stays. It's a 2015 F31 318da and i have the mk100 system in my car. Is there anyone here that can confirm wich remote system in the car is used that is working together with the mk100 system? My mechanic changed the remote control receiver in the right side of the boot today, but i am confused reading on some sources that the rdc system is integrated in mk100??? All help appreciated! |
11-23-2020, 02:48 PM | #341 | |
Rep 464
I cannot confirm absolutely but based on your model year, I would think your MK100 is providing the RDC functionality. I would be very surprised if your vehicle has a separate RDC module installed (typically attached to the underside of your vehicle to one of the straps securing your fuel tank). The Remote Control Receiver in the boot (that your mechanic replaced) is the antenna/receiver the MK100 (i.e. RDC) uses to read the TPMS sensors. Is your TPMS now working properly? Was this the component your mechanic replaced? https://bimmercat.com/bmw/en/search/...0d/ECE/61_5325 Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold Last edited by larrylam646; 11-23-2020 at 02:56 PM.. |
11-23-2020, 02:59 PM | #342 | ||
Rep 79
Im 99 % sure that nothing is under the car. But my question is : do the sensors in the 4 wheels send their info to the mk100 under the bonnet or to the remote control receiver in the boot(what a strange place!?) For now its working. But before it did sometines work perfect for weeks. And then 3 days in a roe throwing faults every 10 minutes. So i will be sure after some time. Strange enough i did not really had issues with te remote locking... Thx for your answer, and my excuses for the bad English. |
11-23-2020, 03:14 PM | #343 | |
Rep 2,302
The 4 sensors are sending to the remote control receiver if the RDC control unit isn't installed (since 03/2014 in EU models). |
11-23-2020, 03:21 PM | #344 | |
Rep 464
I am not surprised the Radio Remote Control Receiver used to read the TPMS wheel sensors is in the boot. This location is similar to the location of the (separate) RDC module used the older TPMS system. Larry
2014 Estoril Blue 435iX - sold Last edited by larrylam646; 11-23-2020 at 03:48 PM.. Reason: Correction |
11-23-2020, 03:45 PM | #345 | ||||
Rep 79
11-24-2020, 02:03 PM | #346 |
Rep 18
On my 3d attempt I succeeded to get tpms working. It seems there is some changeover of the sensors in 2014 to 2015. Ok so fist sensor i put in was 209 partnumber on the end. Then I got a second set 209 on the end and fitted x3 of them and kept x1 of the other 209
Then I got a set of 1891 partnumber on the end made by continental. Fitted x2 of them to the rear wheels and wholla system works now with 2 different sensors but same partnumber 209 front and 1891 x2 of them on the rear. The result And the coding was done the same everytime. It seems some how these 1891 sensors& from Continental that replaces the 1890 did thet trick. So i got 209 in front and 1891 at rear. So all of them work on the F30 but it seems the 1891 activated the system. Last edited by Iceman777; 11-24-2020 at 02:24 PM.. |
11-24-2020, 04:02 PM | #347 | |
Rep 2,302
In any case, the sensors with the 209 are not original. The 36106856209 has not been manufactured or sold by BMW since 2016. And the original sensors are labeled BMW or Continental, like your sensors with the 6891. But it's OK when it works. |
12-22-2020, 05:13 AM | #348 |
Rep 10
Hello!
I am trying to retrofit RDC in my November 2015 F10 (L8LAA National version, India) and I have installed only the wheel sensors 6855539 assuming that my DSC is MK100. I have VO coded 2VB but the following are missing in FDL coding. FEM RC_RDC_ENABLE = aktiv (There is no FEM module present) DSC C_Funktion_RPA_e = nicht_aktiv C_RPA_Extra = nicht_aktiv I have coded the following successfully and the HU shows green tyres with -- values for pressure and temperature and a message that values will be measured when the car moves. But after a few moments I get a "Tyre Pressure Monitor (RDC) failure Unable to detect any loss of tyre pressure" message. HU_CIC RDC = aktiv RDC_SAFETY= aktiv RPA = nicht_aktiv KOMBI ST_TYR_RDC_ALIVE = aktiv ST_TYR_RDC_TIMEOUT = aktiv KOMBI DSC_MIT_RPA = ohne_RPA The RDC module is also absent while coding. Is it that I need to install the RDC receiver or am I doing something else wrong? Any help is appreciated. Thanks |
12-22-2020, 07:07 AM | #349 | |
Rep 2,302
For most people it doesn't work that easy and you also need the receiver. Also there are some other codings or ecus for an F10. You can try this but i have not much hope there. DSC_Premium > Allgemein 3000 > Funktion_ReifenPannenerkennung_aktiv = nicht_aktiv or DSC_CT01M > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_ReifenPannenAnzeige_aktiv_I = RDC ICMQL > Daten 3000 > IcmKod_B_S2VBA = verbaut KOMBI FPK_I12 > ERM_Konfiguration 3004 > ST_TYR_RDC_ALIVE = aktiv KOMBI FPK_I12 > ERM_Konfiguration 3004 > ST_TYR_RDC_TIMEOUT = aktiv KOMBI FPK_I12 > FZG_Ausstattung 3003 > DSC_MIT_RPA = ohne_RPA HU_NBT > EXBOX 3001 > RDC = aktiv HU_NBT > EXBOX 3001 > RDC_DRUCK_TEMP = aktiv HU_NBT > EXBOX 3001 > RDC_SAFETY = nicht_aktiv HU_NBT > EXBOX 3001 > REIFENUEBERWACHUNG_RDC_RPA = rdc HU_NBT > EXBOX 3001 > RPA = nicht_aktiv |
01-10-2021, 05:52 AM | #351 |
Rep 4
I had the same issue of no cafd when I tried to retrofit RDC to my F20.
I tried connecting e-sys as F10, I also tried flashing RDC ecu but e-sys wanted to hwdeinstall the RDC ecu as the f20 never came with RDC. I would try those two methods first as they are safer than the method below which only applies if your model never came from factory with 2VB as an option. Only do this is you are very confident in using e-sys and are willing to risk bricking your car if done wrong... 1-connect to car using e-sys 2- expert mode -> coding -> read FA -> Activate 3- save FA 4- edit FA 5- in FA change vehicle vin to the donor vin of the RDC module (vinlong). Change build date to donor vin build date(zeitkriterium). Change build code to donor vin code (typschlussel). Change model code to donor vin model (entwicklungsbaureihe) 6- calculate FP (I had to remove some salapa options for it to calculate ie. 7AC as F10 never came with that option) 7- save FA 8- go back to expert mode -> coding 9- answer yes to loading modified FA or load it manually 9- read VCM (SVT) 10- click on RDC ecu in SVT tree 11- click "detect CAF for SWE" 12- choose latest istep cafd !!!!YOU MUST DO STEP 13!!!!!!! 13- read FA (very important otherwise you risk writing donor vin details to your car and brick ECU's) 14- expand FA and check for correct vin, etc Be very careful and ensure FA matches your car NOT donor car including all changes done above. If FA still has the donor vin click "read" again. Donot go any further until the FA matches your car!!! !!!!ONLY NOW IT IS SAFE TO INJECT THE CAFD INTO THE RDC ECU!!! 15- right click on RDC ecu in SVT tree and choose "code" 16- manually find the modified FA file you saved earlier and delete it. Donot risk accidentally using that file again. You now have a valid cafd in the RDC ecu (with your vin). Now you can code other ECUs mentioned in this thread to get the sensors working. Hope this helps others... Last edited by ditto675; 01-10-2021 at 12:32 PM.. |
atzebmw588.00 |
01-22-2021, 03:12 AM | #352 |
Rep 42
I have a question that I'll appreciate if somebody can help me with. I have a F30 328i with production date 2012/11 EUROPE. Which set of control unit/sensors should I use to retrofit TPMS on my car?
1. Control unit 6876227 / Sensors 6856227? or; 2. Control unit 6855180 / Sensors 6798872? |
