11-19-2020, 08:27 AM | #2 |
Rep 16,054
I prefer the stock lamp.
Onizukachan1076.00 lpaulodt210.00 |
11-19-2020, 12:05 PM | #3 |
Rep 472
I saw these tail lights on facebook too. I think these would look cool on a aggressively modified f30 or a f80. Otherwise, I think it's a little overkill.
11-19-2020, 03:57 PM | #4 |
Rep 40
I literally hopped on the forum because I saw these on FB. I want
2015 328i N20 - Custom ACN91 tune by Navardi Tuned, VRSF catless downpipe, FTP Motorsport charge and TIC pipes, Turner Motorsports turbo inlet and upper intake pipe paired with modified stock intake box, Active Autowerke FMIC, AWE quad exhaust and mid pipe, Airlift 3P air suspension, Megan Racing rear suspension arms, Volk Racing TE37 SL, other shit...
11-19-2020, 05:52 PM | #6 |
Rep 1,783
These tail lights from the CS and GTS are awesome looking. I don't believe you can retrofit them to an F32 though. I believe they're only compatible with M4's, whether base or otherwise. I'd like to hear if someone was able to retrofit them though. Although they're $10k lol.
11-19-2020, 08:08 PM | #7 |
Rep 660
Drives: 2014-320Xi / 2017-330Xi
My wife has an F30 2014 and I an LCI... Quite frankly I like more the pre-LCI tail light with straight line instead of the curvy lines.
The only one I would consider to change is the blackline... otherwise stay OEM and no leaks. |
11-19-2020, 10:29 PM | #9 |
Rep 1,783
12-01-2020, 06:29 PM | #10 | |
Rep 1,380
There was a post on IG recently regarding these to be stolen prototype designs, with many flaws supposedly.. that said at £480 it's not bad to say they're literally plug and play. The light up pattern is managed via an internal controller, so in theory if they did release a 4er shape then they should be compatible.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
12-02-2020, 08:39 AM | #12 |
Rep 1,637
12-03-2020, 01:36 PM | #13 |
Rep 3,679
dubsesd posted about something similar on his IG (same username). Not sure if they're the same as the ones pictured but same idea. The ones he posted about are by a new (?) company called Solas Illumination Co.
12-06-2020, 09:58 PM | #14 |
Rep 1,783
Appears to be only for F30 and F80 unfortunately. I'd buy a set of these if they were available for F32 but sadly doesn't appear to be the case, based on what I can see at least.
Another recent thread about these lights: https://f30.bimmerpost.com/forums/sh....php?t=1777820 |
12-07-2020, 12:25 PM | #16 |
Rep 1,637
03-23-2021, 10:39 PM | #18 |
Rep 1,783
05-16-2021, 04:39 PM | #20 |
Rep 1,783
Awesome! Thanks for the heads up. I'm so eager to buy a set of these lol. Sure these are going to be the new "carbon fiber mirror caps" in the BMW world pretty soon, but they sure go look cool.
I found them at teamrpm.nl but that's all I'm finding so far but they're preorders. Which other sites do you know are selling them? The red version 2's are the ones to get imo. Hopefully these new F32 versions starting to go on sale will be the equivalent of the F30 V2's. Edit: Another thread provided a Chinese link below but prices are a bit high. There are other vendors with slightly lower prices but delivery in August. I found a link for $960 with a June delivery date but good lord that's expensive lol. These are selling for $650 for the F30. https://www.aliexpress.com/item/1005...archweb201603_ Last edited by eff32fl; 05-17-2021 at 12:13 AM.. |
05-17-2021, 04:02 AM | #22 |
Rep 1,637
