BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Factory OEM F30 Wheels Offsets (18, 19, 20 inch) and Brake Sizes
      01-01-2013, 11:05 PM   #23
7 4 7
7 4 7's Avatar
India
129
Drives: E46 328i, F30 328i, G20 M340i
Originally Posted by dcg71 View Post
I think 245 is about the widest you could go on an 8" wheel, so you could potentially stagger with 245s on the rears. May look a little beefy though. 235 all round might be a better solution.
Thanks !!!
235/45 square available ? If 235/40 i may not want to lower the profile ( bad road conditions )
245/40 @ the rear sounds good to me ? Any success stories out here ?
Also any one running on 245/40 R18 square setup ?
BMW F30 328i (A/T) | Toyota Fortuner 4x4 (M/T) | Toyota Hyryder Hybrid (e-CVT) | BMW G20 M340i | Skoda Kushaq (A/T) | Kia Seltos (DCT) | BMW E46 328i (M/T)
      01-15-2013, 12:48 AM   #24
nsquared
[Versatile]
nsquared's Avatar
378
Drives: (S)LOW.
Is the center bore still 72.6mm on the F30s?
'02 TS E46 330xi - SOLD
'06 SGM E90 325i - SOLD
'13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD
'20 AW F87 X3MC - Sold
Current: `23 Chalk G80 M3CX | Ordered: '24 M3CS - Week37 build.
      01-16-2013, 11:08 AM   #25
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
Yes.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      01-16-2013, 11:22 AM   #26
nsquared
[Versatile]
nsquared's Avatar
378
Drives: (S)LOW.
Originally Posted by remmib View Post
Yes.
Thanks.
      02-19-2013, 09:16 AM   #27
viognier
Drives: IS250
plz help i have a 18" rays RE-30 8.5j ET35, 9J ET 40. can this fit F30 335i, my 335i is 18" Double Spoke Style 397 (Sport Line wheels) - 18x8" ET34
      03-31-2013, 11:07 AM   #28
FDinTO
Drives: F30 2014 335xi Msport 6MT
I have a 2010 E90 328xi with Blizzak RFT's (225/45/17) mounted on 4 Replica rims for the winter. Lease end is arriving.
Will this winter combo fit on 2013 F30 335xi? with Msport (but not the optional Msport brakes)?
      04-02-2013, 06:42 PM   #29
Shulman_
Drives: 2013 328i X drive
Hey guys
I am new to this forum, and have a quick question in regards to 2013 328i X drive wheel setup
I know for x-drive the wheel diameter, front vs. back, cannot exceed 1% change.
I want to put 275s in the back with a staggered setup
What is my best option for tire combo?
235/35/19 ad 275/30/19 Seems to have a 0.1% change
or
245/35/19 and 275/30/19 seems to have a -1% change?
or
Anyone else have suggestions?
PS I do not know if the calculator I used was accurate
Thanks a lot for the input, I do not want the X drive to "trip" out, nor put extra strain on the transmission
      04-03-2013, 09:11 AM   #30
Shulman_
Anyone? ^^^
      04-03-2013, 09:25 AM   #31
tissot
hmmmmmmmm
Hong Kong
17
Drives: F30 - 328i
2006 330i  [0.00]
2006 330i  [0.00]
2006 330i  [0.00]
My x-drive is running
225/40/19 8.5 35et
255/35/19 9.5 38et
0.3% change
I'm using this calculator http://www.rimsntires.com/specs.jsp
      04-03-2013, 10:01 AM   #32
Shulman_
^ the size you are running is the stock size, which will for sure work.
I am trying to go with either 265 or 275 rears, and this so I am wondering if anyone else with x drive has experimented with these sizes
Thanks for your input though!
      04-04-2013, 09:28 AM   #33
Shulman_
^ Can anyone chime in?
The 235 and 275, the rear is slightly larger in rolling diameter than the front
All other combos such as the proven 235 and 265 have the front diameter a little larger
Does anyone know if thats a big deal? If both staggered setups are under 1% in change
      07-06-2013, 08:57 AM   #34
AWF30
Drives: aw f30 m sport
Anyone know the weight of style 400 wheels ?
      08-28-2013, 09:19 AM   #35
illirep
illirep's Avatar
Drives: 2023 M3
Does anyone know if the following will work on my 2013 335xi M-sport:
BBS CH
19x8.5 et20, 245/35
19x10 et20, 275/30
      08-28-2013, 10:16 AM   #36
FranckF1
FranckF1's Avatar
1042
Drives: M3 (G80,Euro)
No, way too agressive at the rear by more than 20mm. The front is a bit too agressive also, by a bit less than 10 mm.
      08-28-2013, 10:45 AM   #37
illirep
illirep's Avatar
Drives: 2023 M3
Couldn't I do a 20mm spacer to get me to the 40mm oem offset? Or do spacers work in the opposite direction?
      08-28-2013, 11:07 AM   #38
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Spacers is not a solution, since they decrease total ET.
      08-28-2013, 01:55 PM   #39
illirep
illirep's Avatar
Drives: 2023 M3
I see. Thanks
      09-05-2013, 10:43 AM   #40
echangf30
Drives: 14' F30 MSport 335xi
i have 19x8.5 et 25 and 19x9.5et 39 what tires am i supposed to get without rubbing. Is this a hard question? no drop either.
      09-22-2013, 07:00 AM   #41
sonicsonic
Russia
31
Drives: 2014 335i xDrive 6MT 370whp
Need an advice! I want to order r18 forged wheels 8,5j front and 9,5 rear. Maybe advan or rays. Any problems with installation on my car if I have M-sport brakes option? What offsets need?
      10-28-2013, 08:33 PM   #42
moreno1
moreno1's Avatar
Drives: BMW 335i E93
i would like to know if anyone could tell me if a friend could use winter square set 225/35/19 on his stock 401 with his 435xdrive coupe with M-performance package?
2009 335i E93 /// BSM /// Sport /// Premium /// /// 19" M pack 225 wheels /// M6 wheels winter set /// 35% Tint /// Gloss Black Grills /// PE Exhaust /// Lux H8 V3 /// Interior LEDs /// JB4-DCI /// Combox & CIC Retrofit /// M3 side skirts /// M3 front bumper ///
      10-29-2013, 02:59 AM   #43
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
225/35-19 has 8" wheel width as recommendation, 7.5-9" allowed. So both the front and rear wheel will be within the spec. for the tire.
But the overall diameter of 225/35-19 is 1" short compared to OEM 225/40-19. It will influence the speedometer, and the tires may look small in the wheel housings. No serious issues but good to know!
      10-29-2013, 12:57 PM   #44
moreno1
moreno1's Avatar
Hi ss0803,
Thanks for your answer! So he will be able to use those new winter tires (225/35/19) on his 401 wheels without any serious issues!!
I tried to use the calculator on E90 side and the difference seems to be -3.15%. The dealer told him that one should never go more than a difference of +/- 0.5%. Is this true or they are just trying to get him to buy a new set of winter tires for his new car??
can anyone comment please and thanks?
f30 3 series wheel offset, f30 3 series wheel offsets, f30 328i wheel offset, f30 328i wheels offset, f30 328i wheels offsets, f30 335i wheel offset, f30 335i wheels offset, f30 335i wheels offsets, f30 offets, f30 offset, f30 wheel offset, f30 wheel offsets, f30 wheels offset, f30 wheels offsets, wheel offset f30, wheels offset f30, wheels offsets f30
