05-17-2017, 06:34 PM | #111 | |
Rep 5
01-11-2018, 08:39 AM | #112 |
Rep 740
Gang!
Here reviving an old thread, but I have some questions. Its time to replace some of my suspension components due to wear, I want to try the F80 Torsion Strut/Trust Arm (TS) and the F80 Lower Control Arm (LCA). I am completely stock with the sport springs and the Adaptive M suspension. Should I expect any issues with the cars suspension after the swap? |
01-11-2018, 07:05 PM | #113 | |
Rep 891
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
04-29-2018, 11:44 AM | #114 |
Rep 2,044
Hello BMW Experts!
I've been reading the Mx35i threads on the LCA, and they report getting ~ -2 degrees camber with the M3/4 LCA (ie: ~ -1.0 over stock). But they have a different knuckle than my F30, meaning I should have ~ -1 > -1.5 degrees camber. This should be fine for the street. I haven't figured out if the M3/4 TS will give me more camber or not (< -0.5 extra?). Since the TS doesn't change toe, I figure very minimal camber change if any. But the M3/4 TS does correct the caster back (from M3/4-like specs)to stock to some degree. I don't see rub on my car, and many others don't have rub. So for me the Question would be if I like the feel of more caster or not; some do some don't. I feel the mountains calling.... "I had both, started with LCA only, added TS later on hoping to reduce caster, but that changes absolutely nothing, we compared both F8x and F3x TS side by side: no difference. And it was still rubbing after adding TS. TS will not change camber at all, only caster, the BMW official repair manuals also mention alignment isn’t required when changing tension struts. What you can try if caster (and rubbing) was a issue is to fit the TS with caster adjustable bushings (powerflex, superpro...), this would allow to reduce caster a bit and try to get back within more normal values." Murf Last edited by Littlebear; 04-30-2018 at 05:28 AM.. |
05-05-2018, 12:51 PM | #115 |
Rep 95
Hi.
I have a 2013 335i M sport with EDC suspension. My car has 66k miles but due to mostly city driving i feel as my suspension is already worn out. Im looking to upgrade instead of just replacing with oem. So theres is only the tension arm and lower control arm M options? What else should be replace at this mileage up front as i feel thats where most my squeaks and rattles are coming from? I am also thinking about replacing my edc suspension with coilovers. I will most likely go with BC racing coilovers and KW edc cancelation kit. M tension arms with M lower control arms. What else you guys recommend? |
05-07-2018, 12:48 PM | #117 |
Rep 2,044
Hello BMW Experts!
Is changing the TS harder than changing the LCA? Specifically: -is the upside down balljoint on the hub a pain? -do you have to remove the disc & backing plate as Bentley says? TIA! Murf |
05-07-2018, 12:57 PM | #118 |
Rep 1,291
Changing isn’t different from LCA, but did you note that he bushing doesn’t have the same size on f80 and f30? You need either spacers or change bushings completely, which makes it a more complicated process.
05-07-2018, 01:48 PM | #119 | |
Rep 2,044
Got the spacer info; I don't really like opening & disturbing the bearings, & hoped to avoid that. Pic of wheel, showing position with M3/4 LCA. Murf Last edited by Littlebear; 10-30-2021 at 06:03 AM.. |
06-14-2018, 01:08 PM | #120 | |
Rep 39
Hello all,
Apologies for reviving an old thread. Been reading up on F8x replacement LCA threads. While the general consensus is that the F8x LCAs are a direct swap, plug and play I found a post stating that a 1mm shim is required for the LCAs to fit right? Quote:
Did anyone here need the added 1mm shim? |
07-03-2018, 06:27 PM | #121 |
Rep 891
EDIT: Raised ride height about 1/2" and they fit without any problems. See bottom photo.
So I finally took the plunge and ordered the LCA's for my car. From what I read, I don't expect to have rubbing issues, but wanted to see if there were others out there who have installed these with a similar setup to mine. I am lowered to the point where there is no wheel gap, but no tuck either. My wheels are 18x8.5et38 all around wrapped in 245/40 PS4S. Is there anyone who could give me some reassurance? I intend to go another route if there is rubbing. Photo for assistance Post install
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 07-20-2018 at 08:29 AM.. |
07-18-2018, 03:01 PM | #122 |
Rep 891
Edit: Zero problems, please disregard. Hope this info helps others.
So I have my car in the shop as I write this and I just got off the phone with them. While they haven't reported any issues as far as rubbing goes, my foreman was concerned with the extension of the tie rod ends and that they are very close to the end of adjustment to compensate for all the toe these add. He is estimating 1/4" on the threads. My question is, has anyone here ran into any issues with their tie rods in conjuncture with this upgrade? I have done some searching across the board and I can't seem to find anyone even hinting at their tie rod arms not successfully accommodating the excess toe compensation. Thanks in advance.
07-30-2018, 05:40 AM | #124 |
Rep 35
Thanks MacklinUSOB!
MacklinUSOB518.00 |
01-13-2019, 02:37 PM | #125 |
Rep 928
What are the ideal spacer sizes? I was gonna source stainless spacers 1.5” od .5” id two 15mm wide and 2 2mm’s wide? These are the correct sizes I believe? Thanks
01-13-2019, 07:10 PM | #126 | |
Rep 3,947
https://www.powerflexusa.com/shop/pr...?category=1790 |
01-13-2019, 09:05 PM | #127 | ||
Rep 891
I wanted the ball joints and bushes replaced, the arms take care of both for less.
Polo088161610.00 |
01-13-2019, 09:36 PM | #128 |
Rep 928
01-14-2019, 07:46 AM | #129 | |
Rep 891
https://www.2addicts.com/forums/show...1&postcount=41
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 05-15-2019 at 02:42 PM.. |
01-14-2019, 07:48 AM | #130 | ||
Rep 928
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
01-14-2019, 07:52 AM | #131 |
Rep 928
I see the more detailed specs. Those are the ideal sizes I guess? I'm going that route for sure. Stainless steel would be the best material.
01-15-2019, 05:18 PM | #132 | |
Humanist
272
Rep 398
'19 F31 M Sport Estoril Blue : '16 F80 M3 ZCP Mineral Grey : '15 E84 X1 M Sport Le Mans Blue : '13 E92 M3 ZCP Alpine White '10 E82 135i M Sport Le Mans Blue : '99 E46 328i Sport Fern Green : '95 E36 M3 Cosmos Schwartz : '95 E36/5 318ti Clubsport Jet Black |
