BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Turbo Whine/Whistle After Getting DP, CP and FMIC Installed
      01-22-2019, 01:45 AM   #1
ethanm5000
Drives: 2014 428i
Today I dropped off my car at a tuning shop to get a VRSF dp, cp and fmic installed so that I could go stage 2 BM3. After I picked it up, I noticed a fairly loud whine/whistle coming from the driver side. I texted one of the guys at the tuning shop and they told me that they had been hearing it too and that they checked for boost leaks around the DP and didn't find anything. I am doubting that it's downpipe related and am now looking at the chargepipe. I noticed that the chargepipe has some wiggle and play. I would just like to see what people on here think. Originally I wasn't thinking much of it, but I am almost certain it's a boost leak at this point. It just doesn't sound correct and I can't tell if the car is pulling as hard as it should be for BM3 Stage 2 AGG. I'll try and run a datalog tomorrow. What boost numbers should I be seeing for stage 2 agg for 93 octane? BTW, I have a 428i so it's the N20.
Thanks in advance!
      01-22-2019, 08:33 AM   #2
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
You should see 22 psi or thereabouts up to about 4500rpm at WOT, and it will taper off to 18-19psi in the upper rpms to redline. Run a datalog and post it up and we'll know pretty quickly if you have a leak. Could very well be the CP.
      01-22-2019, 04:39 PM   #3
ethanm5000
Drives: 2014 428i
Here's a quick datalog I did, I'll try to get a better one.
http://www.bootmod3.net/log?id=5c4792c0c090c61e5911d282
      01-22-2019, 04:56 PM   #4
rjd_F30
rjd_F30's Avatar
That log looks perfectly fine in terms of boost, no leak. The last section was a little weird though, looks like the throttle closed up and timing fell off. I guess it's hard for you to tell seeing as you just installed these parts, but did the car feel like it was pulling strongly?
Is there any way you can capture the sound on video?
      01-22-2019, 06:57 PM   #5
ethanm5000
Drives: 2014 428i
So before I had the parts installed, I was running stage 1 93 octane. It doesn't seem to be pulling any harder than it was on stage 1. Perhaps I am psyching myself out, but it just doesn't feel noticeably faster. Sometimes the boost just feels slow and almost like it's stock. I was able to get it on video, it's kinda hard to hear from within the car, but I couldn't record with the window down because of wind. It's very high pitched, so it makes me think it's a small hole.
Here's an image of the CP connection to the throttle body.
View post on imgur.com
Here's a longer datalog:
http://www.bootmod3.net/log?id=5c47a12fc090c61e5911d292
And here's the video from within the cabin:
https://drive.google.com/file/d/1LZo...ew?usp=sharing
      01-22-2019, 08:05 PM   #6
rjd_F30
rjd_F30's Avatar
Gotcha. The car should pull much harder on stage 2, so there's definitely something going on. That's an interesting sound though, can hear it pretty clearly in the video. Is it louder with the windows open, or can you not hear it because the wind drowns it out. I'd honestly be surprised if it was a boost leak judging by that sound, and the logs indicate it's not, but the symptoms are definitely of a boost leak... Also for logs, try to keep them short and sweet, just do a 2 or 3 gear wide open throttle pull, that's the best way to look for a boost leak.
Also, hard to tell if the CP is seated all the way in there. Not sure if we should be seeing shiny stuff. Is there a lot of play right there?
EDIT: the more I listen to it the more it does kinda sound like some air escaping... hard to be certain.
      01-22-2019, 09:35 PM   #7
canman111
Drives: F30 328i RWD
2014 BMW 328i  [0.00]
You should also check the chargepipe to intercooler side.
The metal c ring on both throttle body and intercooler side should look recessed into the gap provided. If one looks different, or not fully flush, you may have a leak there.
      01-23-2019, 12:02 AM   #8
ethanm5000
Drives: 2014 428i
So it's louder with the windows down. Especially when there is something for it to echo off. For example, if I am building boost as I pass a car It's obnoxiously loud. There is a lot of play where the CP connects to the throttle body.
      01-23-2019, 12:07 AM   #9
ethanm5000
Drives: 2014 428i
Yeah, the problem is that I had these parts installed at a shop since I am in college and have no way of doing any of this myself. Of course, with my luck, either the part is bad or the shop just didn't install something properly. I had a friend rev my car as I listened from the outside and I didn't notice the sound. I am pretty certain at this point there is some sort of boost leak.
      01-23-2019, 12:16 AM   #10
ethanm5000
Drives: 2014 428i
The other thing one of the guys at the shop was telling me over the phone is that it could still be leaking regardless of what the datalog showed if it's a small enough leak that the turbo is able to overcome it. Not sure if that's true, but I guess it's a thought.
      01-23-2019, 06:31 AM   #11
canman111
You may have to take it back to the shop that installed it for you to have them check everything over.
Surely theyd do it free of charge as a "warranty job" for their labour. Wouldn't be too hard to make sure everything is seated well.
My experience was when i installed my CP as the first mod, the CP at the intercooler side didnt have the c clip all the way in. It looked ok but under throttle i could hear a sound like air escaping. I had a lookover and could push the pipe in a little further and the clip seated more flush. No sounds after that. It may look ok idle but may be loose under throttle. YMMV. Good luck
      01-23-2019, 06:32 AM   #12
rjd_F30
rjd_F30's Avatar
Yah, hearing that, I guess my guess is it's leaking at the throttle body, just the logs contradict that. Could be a faulty pipe or a botched install, neither one are terribly unlikely. It's also not uncommon that you don't hear it when your friend revs it standing still as there's no load on the engine. Also not impossible to have a leak go undetected I guess, but if the leak is big enough to make the car feel slow like you're saying it does, that's 100% something we would see.
I agree with the above post, take it back and have them look at it. If they back up their work, talk with Tiago@VRSF about getting a refund if you can for certain blame it on the pipe. Hopefully he'll take care of you.
      01-23-2019, 04:24 PM   #13
ethanm5000
Drives: 2014 428i
Yeah, unfortunately I tried reseating it at the throttlebody last night and dropped the c clip. I lost it in the engine bay after it landed on the floor pan.
      01-23-2019, 05:17 PM   #14
rjd_F30
rjd_F30's Avatar
That stinks. Shouldn't be too hard to drop the belly pan if you have to. If it isn't seating all the way in there, it's probably a problem with the pipe.
Different motor, but this thread might be of interest to you https://f30.bimmerpost.com/forums/sh...1236747&page=2
      01-23-2019, 07:58 PM   #15
canman111
rjdnyy224 puts up a good point with the link.
Shop may have possibly forgotten to transfer o-ring?
rjd_F301999.50
      01-24-2019, 04:46 PM   #16
ethanm5000
Drives: 2014 428i
So what do I do if I can’t find the c clip?
      01-24-2019, 05:16 PM   #17
rjd_F30
rjd_F30's Avatar
You should definitely be able to find it... Drop all the under belly pans, should only take 10 minutes, and it should be there. If not, just pick up another clip online.
      01-25-2019, 06:26 PM   #18
ethanm5000
Drives: 2014 428i
I managed to find one website that sells them. Will get here on Monday. Still gotta figure out the boost leak issue. Pretty sure it's at the throttle body connection though.
      01-25-2019, 09:35 PM   #19
rjd_F30
rjd_F30's Avatar
Nice, and I'm with ya. That throttle body connection is a likely problem spot.
      02-01-2019, 05:39 PM   #20
ethanm5000
Drives: 2014 428i
Yeah so I put the c clip back on and put some tape around the throttle body connection and meth bungs and the car pulls super hard now. Just gotta figure out which one is causing the leak. Gonna try tightening the meth bungs first.
      02-01-2019, 06:18 PM   #21
rjd_F30
rjd_F30's Avatar
Nice, making progress. Trial and error with the tape at those two spots and you should find it.
boost leak, bootmod3, chargepipe, vrsf
