10-10-2021, 12:19 PM | #177 | ||
Rep 2,130
I've had a little play with it today and made it shift sooner in the low gears changes by a few % and raised the % on the change down on higher gears just to keep the revs over 1000. The main problem I was having was that when cruising along at 30mph or 70mph it would be fine, but if I were to accelerate, but not enough to kick down, then the car would lug and judder until it got on boost. I want to eliminate the lugging. Everything else I'm fine with, and overall I'm quite happy with the new map.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
10-10-2021, 12:58 PM | #178 | |||
Rep 3,897
Just me?
10-11-2021, 10:28 AM | #179 | |
Rep 614
Straight from XHP's FAQ: Do I need to do a run-in-phase? We do recommend around 50-75 miles of driving without wide open throttle, with varying speed, load scenarios and shifts, so the transmission can adapt to the new software as fast as possible. This driving-in-phase is only recommended after the initial xHP flash and not needed for subsequent flashes, like map changes or different custom settings etc. I just flashed my transmission, but the shifts are bad. Your transmission may behave weird, right after flash, e.g. starting in 3rd. gear. This issue should clear within a few hundred meters of driving. The transmission has extensive adaption-algorithms, to keep shift quality in check over a full life time and even with heavily worn out clutches. The adaptions applied are very sensitive to abrupt changes, as they operate in a narrow window. Therefore, shift quality can suffer in the first few hundred miles, after doing an oil-change, replacing transmission hardware, or changing the TCU software, like with xHP. Don’t overstress your transmission during this adaption phase. The best way to adapt your transmission, is just normal driving in D mode with lots of varying speeds and shifts. We DO NOT advise anybody to clear the adaption values to speed up the process. Depending on the current wear state of your transmission, this can lead to unwanted and permanent bad results. |
Abzynthe1393.50 |
10-15-2021, 08:54 PM | #180 |
Rep 420
Xhp Drag Mod mode test. On the street + 15C. The road is simple asphalt. Target 28 psi. Tim 17. E35 / WMI Port. Start from 2nd gear 3000 rpm. The total weight of the car with a driver is 1720kg. X-Drive.
M140IX. Turbo Pure 800 Cast.
10-16-2021, 07:41 AM | #181 |
DisplacementReplacement
438
Rep 1,130
So a .3 improvement on 1/4 and (5kmph) negative on speed, am i seeing that correctly?
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
10-16-2021, 07:50 AM | #182 |
Rep 708
10-16-2021, 08:14 AM | #183 |
438
Rep 1,130
Haven't read of any. I've ran it for many years on my M235xi and M240xi and drive hard, combined 40-50 thousand miles driven aggressively. I am curious about this new drag option as it sounds great, just would be concerned about how brutal it is on the transmission life span.
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 Last edited by Jnat; 10-16-2021 at 10:21 AM.. |
10-16-2021, 08:52 AM | #184 | |
Rep 708
I assume all F3X series use the same transmission (all engine type)? Thanks. Last edited by gameson; 10-16-2021 at 08:58 AM.. |
10-16-2021, 10:18 AM | #185 |
Rep 3,897
Much more relevant - how many Kilometers?
I am pretty sure you can safely have any tune for 100 years if you leave the car in the garage
10-16-2021, 10:22 AM | #186 |
438
Rep 1,130
Ok, M235xi and M240xi, driven hard, 40-50 thousand miles combined on XHP, performed normally...
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 Last edited by Jnat; 10-16-2021 at 01:43 PM.. |
Skyhigh1908.00 |
10-16-2021, 01:24 PM | #187 | |
Rep 122
Mods: 19" HRE FF15, M Performance diffuser, Bilstein B16 Damptronic, VRSF catted downpipe, Remus catback, Dorch St1, Pure 800, OS Giken LSD, Ross Racing PCV+OCC V1
10-16-2021, 01:45 PM | #189 | |
438
Rep 1,130
i guess time will tell on the wear end of it...
10-16-2021, 01:47 PM | #190 |
Rep 122
Wide open throttle
10-16-2021, 04:20 PM | #191 |
438
Rep 1,130
I just tried it and wow, very impressive response in all aspects...
Great job XHP But, i will not be using 24/7 as it's abrupt... which is good
10-17-2021, 10:34 AM | #192 |
Rep 2,130
I'm pretty safe then
10-19-2021, 12:03 AM | #194 |
Rep 1,199
I've decided I'm doing xhp before I even do MHD. The transmission has a much bigger impact on driver experience than a boost of 10-20% hp. This car so much faster than I can utilize in my DD patterns already that I think the extra 50-60 hp from Stage 1 will be largely wasted if I do it first.
My iPhone Ethernet adapter comes tomorrow
10-19-2021, 02:15 AM | #195 | |
Rep 3,897
WDE82816.00 |
10-19-2021, 04:58 AM | #196 | |
Rep 282
i like the take off in second gear and uplifted shift rpms in comfort ( ive raised them by 20 percent ) . i dont do 0-60 launches .
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
10-19-2021, 11:44 PM | #197 | ||
Rep 1,199
10-20-2021, 02:12 PM | #198 |
Rep 122
I don't dare to run stage 3 anymore. At a certain point in time the downshifts were so harsh in S-mode and M-mode it was really like banging in the gears, especially from 5 to 4 it was really bad. You could even hear it.
So first went back to stage 2 but that didn't help much, so back to stage 1. Did that for a while and then tried stage 2 again. After another while tried stage 3 but then altered the throttle blips to try and make it a bit smoother. That seemed to help quite a bit however downshifts were still quite harsh. Last week went back to stock and I will keep it that way for a while hoping for that the trans will re-adapt. Even now in stock the downshifts in m-mode are not smooth (upshifts are), but to be honest I don't remember if they ever were? However I don't know how long I can live without the custom shift settings for comfort mode. The ridiculously low shiftpoints drive me crazy. I don't understand how people can drive like that...
