BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Towbar witter or westfalia
      05-03-2017, 04:20 AM   #1
K3vmcb
Drives: F31 touring
Well guys not been on this forum long I've had lots of towbar a in my time but mostly been witter I've used I was wondering what you guys think as I need to make a decision asap so that I can get one bought lol. They are both detachable but is one more visible than the other ? many thanks kev
      05-03-2017, 04:54 AM   #2
daveb666
Drives: F31 Tourer
I have a Witter detachable on my f31. No bumper cuts and nothing visible from the back of the car
      05-03-2017, 05:09 AM   #3
djcowlin
djcowlin's Avatar
283
Drives: G21 330e
I had a Witter on a Passat. It was easy to remove and fit, and I had no issues towing a horse trailer. I also quite liked the plastic cap that fitted over the tow ball, which had a red and white Witter logo. But maybe that was just me.
Current: 21 G21 330e | Portimao Blue | 791 M | M Sport Pro | Vis/Tech/Comfort Plus packs
Previously: 19 F20 M140i Shadow Edition | EB II || 16 F31 340i | EB II || 13 F31 330d Luxury | MG
      05-03-2017, 07:02 AM   #4
moonshine
moonshine's Avatar
Scotland
849
Drives: 718 Boxster S
there is nothing to choose between them tbh - they are very much a muchness. you pay your money, you take your choice.
      05-03-2017, 07:03 AM   #5
K3vmcb
Drives: F31 touring
I don't know if you can lick the westfelia one as don't see a key slot
      05-03-2017, 07:10 AM   #6
moonshine
moonshine's Avatar
Scotland
849
I don't know whether the Westfalia is lockable, but I would guess it is but couldn't say for certain. perhaps google a youtube video of it in use to check?
The specs on PF jones website indicate the towing weight for the westfalia is 1800kg vs 2000kg for the Witter
      05-03-2017, 03:22 PM   #7
Craig-SM
Drives: BMW 320d M Sport - F30
Westfalia have a lock in the release handle. I've always had Westfalia as they are the OEM manufacturer for most German makes.
http://www.towbarsdirect.co.uk/image...Detactable.jpg
The red disc is the key
      05-03-2017, 05:10 PM   #8
RalphyBMW
Drives: F31 330d xDrive MSport
Westfalia make the OEM BMW bar.
The Witter is a sod to fit, you need to remount the OE crash bar on top to be able to fit the bumper support; the Westfalia is a direct replacement for the OE crash bar.
I've got a Witter bar with Westfalia loom. For my next car I'll be going for Westfalia bar and loom.
2016 F80 M3
      05-04-2017, 02:50 PM   #9
K3vmcb
Drives: F31 touring
A sod to fit so if I fit a witter towbar the crash bar has to go back on don't think that would be a bad thing is it ?
      05-04-2017, 03:00 PM   #10
moonshine
moonshine's Avatar
Scotland
849
Here are the fitting instructions for the Witter towbar
http://www.pfjones.co.uk/witter/BM38.pdf
      05-04-2017, 04:39 PM   #11
Craig-SM
You shouldn't need the pressed metal crash bar as the towbar frame that replaces it is much stronger.
      05-05-2017, 01:11 AM   #12
RalphyBMW
Exactly, but the Witter is quite small and has a poorly designed bracket for the bumper support.
2016 F80 M3
      05-05-2017, 01:25 AM   #13
Chrismac13
England
201
Drives: BMW F31 335i
I have the detachable westfalia unit, very discreet can hardly been seen when detached. According to the installer its the only one that fits properly
Current: 2016 BMW M5 F10
Gone: 2015 BMW 335i F31, MPPK, DMS Remap, Eibach Pro kit
RalphyBMW164.50
      05-05-2017, 06:26 AM   #14
K3vmcb
Drives: F31 touring
Can you take a couple of pictures to show me it fitted please ?
      05-05-2017, 08:14 PM   #15
Davetwilliams
Drives: 340i touring
Pics of westfalia installed on 340i touring Msport
First post....8 years with a Mk5 GTI and felt like time to upgrade.
I recently fitted a westfalia hitch. Here are some shots of the westfalia detachable. You can't see any signs of it when he ball is detached. The electric socket swivels up or down on its mount manually.
The towbar bracket is very substantial and a fair bit heavier than the crash bar it replaces.
Fairly easy job to fit if you have a socket set - helps to have a range of extensions to get the bolts under the wheel arches. I have more photos of the installation if you end up needing them. Oh and I also bought the dedicated heat shield from local dealer. This replaced the heat shield that was stock (replacement is shorter to allow room for the hitch). I've seen posts where fitter has cut a slot in his heatshield but this risks you melting the tow ball release bracket etc. It was £35 for the heatshield. I understand this is only required for petrol but check.
Hope this helps.
Last edited by Davetwilliams; 05-05-2017 at 08:15 PM.. Reason: Clarification of socket
kiwifiz10.50
      05-06-2017, 08:38 AM   #16
K3vmcb
Drives: F31 touring
Does someone have a picture of a witter towbar fitted thanks
      05-06-2017, 12:56 PM   #17
Mattt1
Drives: 335d xDrive
How long did it take to fit? I've been quoted £175 for fitting on top of the cost from PF Jones.
      05-06-2017, 02:17 PM   #18
K3vmcb
Drives: F31 touring
I did my last towbar on my a4 avant and it was like 4 hours or something
      05-06-2017, 04:04 PM   #19
Davetwilliams
About a morning to do the tow bar and then another morning to do the wiring. I was taking it easy. Also mine is a 2016 and so all the wiring was in the right hand compartment of the boot - no need to route to the front.
£175 doesn't sound bad if it comes with a warranty (vs risk of screwing up the wiring?!)
      05-06-2017, 04:59 PM   #20
6times7
Drives: F31 330d
Davetw has got it spot on with his reply. It would be easy to take another afternoon if you wanted to get the wiring super tidy.
      05-07-2017, 09:27 AM   #21
daveb666
Drives: F31 Tourer
I have the westfalia removable on my f31. £414 fitted army work from pfjones. With the dedicated wiring.
Took the chap 1hr20mins - not worth an afternoon of my time if a pro can do it so quickly.
You can't see any of the bar/plug when no towbar in as it's totally hidden under the bumper and no cutting involved.
      05-10-2017, 07:23 AM   #22
jpp01
Drives: F31 330D Xdrive Touring
Davetwilliams, do you mind me asking about the wiring for the Westfalia. Does the dedicated wiring harness/unit, that can be purchased with the Westfalia plug directly into the BMW harness or do you have to use snap in Scotch Locks to pick up the signals? Mines a 63 plate F31, so the wiring may be slightly different, as yours is newer model?
Thanks.
