10-23-2020, 04:14 PM | #89 |
Rep 1,499
Don't want to steal your thunder so you should share your latest findings
10-26-2020, 12:46 PM | #90 |
Rep 1,782
I run the Area 7-4 sim on my PWG n55 while in oEM tune and pass fine
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
10-27-2020, 07:55 AM | #91 |
Rep 72
*** OFFICIAL bootmod3 de-cat with OBD readiness THREAD***
Area 74 only works for PWG N55. I tried it on my EWG and it didn't work. I have big daddy's cat sim /spacer and it worked for a couple months. Doesn't work anymore. For my next inspection, either getting AA high flow cated DP or buy another big daddy's cat sim. Such a pita.
Mike
2018 M3 ZCP 6 MT |
10-27-2020, 10:45 AM | #92 | |
Rep 7,598
10-27-2020, 11:10 AM | #93 | ||||
Rep 72
Mike
2018 M3 ZCP 6 MT |
123Britt289.00 |
10-27-2020, 11:34 AM | #94 | |
Rep 7,598
10-28-2020, 10:57 PM | #95 |
Rep 1,934
How does the car adjust AFR if its fed a constant "simulated" lambda signal???
Pussiwillow521.00 |
10-29-2020, 12:39 AM | #96 |
Rep 7,598
10-30-2020, 09:08 PM | #97 |
Rep 261
Drives: 2017 320i xdrive
So basically nobody has figured out how to run a catless DP and still pass inspections in states like NJ....
12-03-2020, 10:15 AM | #98 |
Rep 1,499
Just a quick update. I passed inspection today with a VRSF catless DP and modified stock tune. No spacers, CATSim or anything like that. Just modified stock tune. PM me for details.
12-03-2020, 10:59 AM | #99 |
Rep 2,653
Inspection
Maaaaaan talk to me!!! lol
12-03-2020, 12:18 PM | #100 |
Rep 1,499
Check your PM
12-03-2020, 12:30 PM | #101 |
Rep 963
Moving back to Raleigh next year and going to have to get inspection done so this is awesome!
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
JaredG_F301106.00 |
12-03-2020, 12:34 PM | #102 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
12-03-2020, 12:44 PM | #103 |
Rep 1,499
I'm not sure. The available tables are different so it's hard to say.
12-03-2020, 03:39 PM | #104 |
Noob
70
Rep 254
How do you like the sound of Fabspeeds HF DP? big difference from your previous catless setup? I currently run a vrsf HF DP and knew it wouldn't pass emissions but I was to impatient and cheap to buy Fabspeeds HF DP and I wanted to flash to stg2+ asap at the time.
Now my emissions are due in June so looks like I will be buying Fabspeed after all lol (basically wasted $400+ because I was impatient) but im curious how Fabspeed sounds and more importantly did you pass? Ct has similar emissions tests as PA I believe.
FBO, MHD Stage 2+ E20, Xhp Stage 3
12-03-2020, 03:46 PM | #105 | |
Rep 1,499
FWIW you don't need to get the Fabspeed DP. You just need to make some tweaks to your tune to pass.
12-03-2020, 03:47 PM | #106 | |
Rep 7,598
You should have made your purchased over the last week or so as most things were on sale. You could have also gotten AA, which was at least 15% off, so around $850. Last year i paid around $1100 for my fabspeed during BF sales. I can confirm that fabspeed will get emissions monitor for the cat into ready state. I would note however that its technically not EPA approved so you can still fail visual. AA on the otherhand should be a guaranteed pass in any state except California. |
02-02-2021, 03:00 PM | #107 |
Moto Lover
187
Rep 591
Not to steer this thread off topic but I have a question. Car is currently stage 2 91 tune with catless DP and all the other bolt on. Getting ready to sell the car and need to smog it.
I obviously have to change the the DP back to the OEM, but what tune do I need to change to? Stage 1 or back to stock? I read that the car needs to go through a monitor readiness but how many miles of different driving does that take? |
02-02-2021, 03:36 PM | #108 |
Rep 2,653
Hey bud I never got a PM
Disregard - I is dumbz.
02-02-2021, 06:53 PM | #109 | |
Rep 462
The number of drive cycles needed to complete all monitors to ready depends on the vehicle and iff you can truly do a drive cycle in a single drive or not based on traffic. Older o2 sensor may take a longer time to heat up etc. For me the one that takes the longest, usually a day or 2 of regular driving, is the evap monitor. Google obd2 drive cycle |
02-02-2021, 07:33 PM | #110 | ||
Rep 2,653
