BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Aftermarket turbo inlet on stock turbo.
      10-25-2020, 01:47 PM   #199
52172
52172's Avatar
Drives: 2015 Bronze Metallic 335i
got my Vader solutions inlet installed only thing that cracked was the coolant line. Will still pass visual cause we cut factory inlet so looks factory. i'm happy as cost was only 60 bucks.
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s.
      10-26-2020, 11:28 AM   #200
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
Originally Posted by itsrichierich View Post
For those that bought the MST turbo I let, did you guys get the stock or hybrid adapter? I have an F30 N55 wit PWG, stock turbo.
Honestly, what is the difference? Ones for stock and one is for aftermarket turbos?
Get the v2, which is for hybrid turbo, even if you are on stock turbo. The stock turbo adapter is literally just a thicker piece of metal - i.e., smaller inner diameter with the same outer diameter (outer diameter determine by fitting into turbo). So you are just necking down the flow area sooner if you get the stock turbo version. Indeed the actual turbo itself will still have a smaller diameter where the air enters the cold side than the metal piece on the inlet if you get the v2, but you still get the extra volume and eliminate the unnecessary reduction in flow area with the v2 version. Also, the articles posted earlier in this thread from bench testing inlets (for VWs but same idea) basically showed that the bigger the better even if it means an abrupt 'step down' in inner diameter near the turbo.
      10-26-2020, 11:30 AM   #201
thejeremyman9
4364
Subjective impressions and/or before and after logs?
      10-26-2020, 11:38 AM   #202
52172
52172's Avatar
i could take a log later but we also installed Turbosmart DV at same time also flashed stage 2 95 octane so car feels very strong. i'll try and do a log later.
      10-26-2020, 03:07 PM   #203
aps
aps's Avatar
336
Drives: 2018 M3 ZCP
is the turbosmart dv install any easier to do with the inlet taken out?
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5
2013 Glacier Silver F30 335i (sold)
      10-26-2020, 03:10 PM   #204
52172
52172's Avatar
i believe so. While we were in there we had the water pump out to so i changed dv, wp, and inlet all at the same time.
aps335.50
      10-26-2020, 03:11 PM   #205
itsrichierich
Moto Lover
itsrichierich's Avatar
187
Drives: '19 BMW S1000XR
      11-23-2020, 11:45 AM   #206
itsrichierich
Moto Lover
187
Anyone have cold start issues after installing?
To begin, I have never had cold start issues. Untill recently after I installed my MST turbo inlet and Turner Motorsport Intake.
Car idles pretty rough and some times shuts off when trying to idle. I have to keep it revved up (not much) to keep the car on.
      11-23-2020, 11:51 AM   #207
435gc
435gc's Avatar
174
Drives: 2015 435i Gran Coupe xdrive
More likely the intake. The MAF is pretty sensitive. Any chance it got knocked around?
Any codes?
      11-23-2020, 12:08 PM   #208
itsrichierich
Moto Lover
187
Any codes?
No codes, not that I can see. I'll do another scan later on today and see if there's a ghost code.
Getting a new MAF sensor a good first step to diagnosing this?
      11-23-2020, 12:24 PM   #209
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Any codes?
scanning the shadow code is the first step. you wither have a vacuum leak because something isn't on all the way/something broke, or unplugged etc.
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      11-23-2020, 01:02 PM   #210
DJSF3014
Drives: 2020 m340i
Any codes?
Don't need to get a new maf what you can do is clean it and leave it unplugged if the car runs fine with it unplugged the it's yours problem easy day.
      11-23-2020, 01:22 PM   #211
itsrichierich
Moto Lover
187
And it's normal for the car to start up normally once it's warm? Because that's what I'm dealing with.
On an actual cold start, it's rough/hard to stay idling. But once it's warmed up and driving, no issues.
Do I unplug the MAF from the intake before starting the car or while it's running?
      11-23-2020, 01:37 PM   #212
DJSF3014
Drives: 2020 m340i
Before turning the car on and then you will just tell by idle. What fuel are you running?
      11-23-2020, 01:41 PM   #213
itsrichierich
Moto Lover
187
I was on E30 mix when this was happening while on my road trip. But I fueled up on 91 and it's still happening.
      11-23-2020, 01:56 PM   #214
DJSF3014
Drives: 2020 m340i
Did you adjust you're tune? Cause the most likely cause of the slow start up or hesitant is from the e tune when it gets cold that's what tends to happen.
      11-23-2020, 02:54 PM   #215
Pray for Mojo
Drives: 2014 M235i & 2018 X3 M40i
Before looking at replacing the MAF, spray it down with this to clean it.
https://www.homedepot.com/p/CRC-11-o...5110/205021972
      11-23-2020, 04:35 PM   #216
thejeremyman9
4364
Step 0 is scan for codes.
Step 1 is to remove the intake and put the stock one back on.
You can also try unplugging the MAF, but i would try the above first personally.
Cold start issue is a classic symptom of intakes. The MST should not be the problem unless there is a defect (very unlikely since you would see a hole in it or it would have not fit snug everywhere) or not installed correctly. Confirm its seated all the way onto the turbo inlet piece (host clamp tight), confirm PCV (aka CCV) hose is correctly installed, and confirm intake is tightly clamped into inlet. I have ran the MSTv2 inlet with stock intake, dinan intake, and CTS turbo intake (as i reviewed in my thread on those) and never had a single cold start issue even with no adaptation reset or anything besides swapping the hardware.
You can also do a log and check if your MAF readings are reasonable or the intake is throwing them off.
Finally, you can try resetting adaptations, but if you've already driven ~50+ miles with the new intake on that probably isnt going to make a difference.
I would scan for codes then put the stock intake back on and drive around for a bit, then let the car sit overnight and test cold start the next day with stock intake.
      11-23-2020, 06:24 PM   #217
itsrichierich
Moto Lover
187
Ok, I will give this a try. I jsut scanned it and had no codes via BM3 module and bimmerlink.
Speaking of PCV, I do see some oil seepage up top. And looking at it, there was suppose to be a clip that needs to be pressed in correct? There's the 4 prongs but there's also a U-clip that locks the PCV into that nipple? That might be an issue.
      11-23-2020, 09:51 PM   #218
thejeremyman9
4364
No clip on PCV on the VC side, just the 4 prongs that snap over the lip to hold the hose in place. It should not be leaking oil around that though. Might want to confirm the Oring is OK. Even my old one was totally dry before replacing.
      11-23-2020, 11:51 PM   #219
itsrichierich
Moto Lover
187
So I replaced it with a new PCV, per you recommendation and common sense. Looking at a YouTube, here’s a reference to the piece I’m talking about. It’s the ribbed piece. The new PCV I bought didn’t come with it. Going to order a new one and check.
Just swapped over to my OEM intake, hopefully this will fix it.
      11-24-2020, 12:04 AM   #220
thejeremyman9
4364
I don't remember that on mine either... All i had to do was release the 4 prongs. I would have to go look at the car to see if that was there but just hidden under the sheath. Mine doesn't leak at all though. Is that link the pinch-to-release thing similar to the vacuum hoses on the intake and CP?
