02-18-2020, 08:19 PM | #45 |
Rep 2,357
I have yet to find an argument for the Turbosmart - except spending money on the car and tju tju sounds (dual port).
Is there an argument...?
(A Dane in China) |
02-18-2020, 11:26 PM | #46 | |
Dream crusher
984
Rep 2,421
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
02-19-2020, 04:03 AM | #49 |
Rep 373
yes its the same unit for EWG and PWG
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
Rayzor10.00 |
03-01-2020, 10:27 AM | #52 |
Rep 4,146
03-01-2020, 05:16 PM | #53 |
Rep 1,282
Installation is the same for both. I think it has better throttle response.
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
03-01-2020, 07:54 PM | #54 |
Rep 4,146
03-01-2020, 07:57 PM | #55 |
Rep 1,282
I had the gfb dv+ in my car which I installed. I recently removed it and installed the turbosmart bov. The turbosmart is one piece and the gfb dv+ is an add on to the stock dv.
03-01-2020, 08:33 PM | #56 |
Dream crusher
984
Rep 2,421
Is there a night and day difference or just different?
IG: @bmwdoubles |
03-01-2020, 08:38 PM | #57 | |
Rep 5,392
In the Turbosmart installation, you remove the stock DV and then reverse the process to install the Turbosmart. It's a direct swap. But in the DV+ installation, you remove the stock DV. But then you have the take it to the bench and follow another procedure to take your stock DV apart and combine parts with the DV+. Once you have the DV+ assembled out of the old and new parts, then you install it on the car. |
oma3710194.50 |
03-01-2020, 08:58 PM | #58 | |
Rep 5,392
The Turbosmart BOV Dual Port is venting some, but not all, excess boosted air to the atmosphere which makes that whoosh sound. But the fuel mixture is determined by sensor measurements just before air enters the engine, which is after the BOV. BOV has no disruptive effect on fuel mixture ratio. |
03-01-2020, 09:24 PM | #59 |
Rep 5,392
Not a silly question at all. The Turbosmart BOV for the N55 engine fits all N55 engines. But the photos of the Turbosmart show an electronic cable with a connector on the end. Photos of the stock DV don't show a cable.
Since N55 owners are conditioned, because of various parts variations, to think in terms of whether their engine is a Pneumatic Wastegate model (PWG) or an Electronic Wastegate model (EWG). So seeing an electronic cable with connector on the Turbosmart leads to the assumption that maybe it only works on the N55 EWG engine. Not so! The stock DV works on both the N55 PWG and N55 EWG engines. If you turn the stock Diverter Valve and look closely you'll see that it has the same cable connector on its body. (Please see photo) For some reason, Turbosmart decided to locate the connector off the body and onto a cable. Both the stock DV and the TS BOV connect exactly the same way to the car's wiring harness back to be controlled by the DME. |
03-02-2020, 04:47 PM | #60 | |
Rep 18
johnung4528.00 |
03-02-2020, 07:29 PM | #61 | |
Rep 7,606
Any vent to atmosphere BOV that vents air that has already been read by the MAF is going to cause a rich condition when that air is vented to the atmosphere instead of going into the engine. Having said that, whether or not this affect is negligible on a modern car/engine like this has not been determined to my knowledge. The DME can probably correct for it using STFT, etc. An apples to oranges comparison is my 3000gt. It came factory with a recirculated BOV and runs based on a MAF (no closed loop fueling on WOT). When i got the car 12 years ago it had a vent to atmosphere BOV. If you were to do a hard pull and immediately push the clutch in and go to neutral at the end of the pull the wideband would read extremely rich, the idle would dip, and sometimes the car would stall. I converted it back to recirculating. Now again were talking about 1991 ECU versus 2013+ with additional sensors, etc, but the concept is the same - the MAF thought a certain amount of air was going into the engine and fueling was determined based on that, but some of that air was vented, leading to a temporary rich condition. |
03-02-2020, 08:03 PM | #62 | ||
Rep 5,392
IMO it is more likely that the MAF information is being used almost as a ballpark range check. Then the mixture fine tuning occurs from sensor information as the air continues towards the engine. What convinced me of this was when I was investigating Inlet Pipe options. Guys voiced concerns that the connection from the air pipe to the turbo Inlet wasn't really secured and subject to leaks, yet it didn't seem matter to engine performance. Guys installed the first version of the Pure Turbos Inlet that didn't really have a fastening system like a sleeve. It just kinda fit into the opening. It didn't even have a bolt hole like the stock plastic Inlet Pipe. A leak there obviously changes the amount of air that the MAF already measured. But doesn't severely effect how the engine runs. That's the experimental evidence that tells me that the MAF sensor reading isn't critical to fine tuning the mixture. Not sure if I'm explaining myself well but that's where my opinion is coming from. |
03-02-2020, 11:36 PM | #63 | |
Rep 66
I got attacked on the M2 forum by a person who just seems doesn't like aftermarket diverter valves in general. My experience in the N55 M2 is I seem to have better response over stock DV (even though someone was literally telling me that my experience is wrong), I definitely achieve higher boost over stock DV according to before and after dyno runs, boost comes on a little earlier than stock, I've now been running the dual port for 6 months with no issues or CEL's. Because of my experience, I've come to the conclusion my stock valve was leaking. Car was only 2 years old when I made the change, the stock valves IMO aren't ideal, even at stock boost as my car was and still is. I've been brand loyal to turbosmart since 2006 when I bought my first boost tee and ran over it by accident and they repaired it for me for free even though it was my fault I broke it. So maybe I'm biassed against other brands of bovs and wastegates? I've never had an issue with their products that I hadn't caused myself. Would I swap the DV+ out for the Turbosmart one if I wasn't having issues with the DV+, probably not. But I'd definitely swap it if I thought the DV+ was leaking rather than going to stock DV. And I personally would just go for the Turbosmart product from the beginning anyway and not worry about if I'm losing boost, or if I forgot to oil it or needs to be re-oiled like seems to be happening with the DV+. |
03-03-2020, 01:10 AM | #64 |
Dream crusher
984
Rep 2,421
This oiling of the DV+ is new to me. What are the symptoms of a dry/un-oiled DV+?
IG: @bmwdoubles |
03-03-2020, 12:01 PM | #65 | |
Rep 7,606
Having said all that i would never install a VTA BOV on a car that came recirculating from the factory, but that's just me, and i know other people will. Probably the same people that add extra burbles - to each his own. |
oma3710194.50 |
03-03-2020, 12:53 PM | #66 |
No 55mph
1622
Rep 8,476
All reasons if you dont want to take chances to just go with the Plumb Back VR9 version of Turbosmart
I'll be switching out my DV+ for a TSPB in a month or so Never had problems with the DV over yrs (never reoiled it either), just like to try out different avenues from time to time
