BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Check Engine - 12B302
      09-23-2020, 09:51 AM   #1
jcarv20
Drives: 2014 435i
Hello all,
I've gone thru some threads and googled the check engine code i'm getting "12B302 - Oxygen sensor heating after catalytic converter, activation: Short circuit to earth" and I'm trying to determine the best order to troubleshoot this, any help would be appreciated. I understand there are a few possibilities such as the Integrated Supply Module located on the passenger side located near the battery terminals (part number is 12637591534), but also it could be one of the O2 sensors (more likely pre-cat; I have a catless dp with MHD Stage 2+), I also heard maybe a fuse? (Not sure which). I've had the downpipe on for probably close to a year but this check engine code has only come up the last couple weeks. Car doesn't really drive any different but I'd like to resolve any issues as we all know it could lead to something else further down the road. Any input is highly appreciated.
      09-23-2020, 12:27 PM   #2
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
Why do you think its the precat O2 sensor when the code is for the O2 after the cat? I would say try the simple things first like checking the connections and the wiring. It could just be the O2 itself as well.
      09-25-2020, 01:03 PM   #3
jcarv20
Drives: 2014 435i
Just going off what I've read; doesn't make much sense to me either why it would be the pre-cat not the post cat O2.
      09-25-2020, 07:07 PM   #4
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
its the post cat 02
you have a line break.. I have the same code
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      09-28-2020, 04:03 PM   #5
jcarv20
Drives: 2014 435i
Originally Posted by Phantom10R View Post
its the post cat 02
Hey - did just swapping out the post cat sensor resolve your issue? I was trying to check the fuses and location of the ISM but I'm not sure where either is, I can't find an accurate diagram of an F32.
      09-28-2020, 07:16 PM   #6
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
its the post cat 02
I haven't swapped it yet lol.. being lazy
      09-29-2020, 06:43 AM   #7
jcarv20
Drives: 2014 435i
LoL fair enough, I feel ya.
      10-28-2020, 01:03 PM   #8
5w20
@_sunbish
5w20's Avatar
282
Drives: Bmw 435i & 340i
I had this same code. You can verify if it's the sensor with a multimeter, but if you like to wing it then replace the REAR O2 sensor. I had the same code, but I verified that the sensor was my problem. Replace sensor and code is gone.
