11-01-2019, 02:03 PM | #177 |
Rep 19
After they replaced my EGR and Manifold a few weeks ago within 3 days the check engine light came on and BimmerLink showed vacuum error. Took it back to Pacific in Glendale and turns out when they installed the new vacuum hoses on the EGR, they kinked one of the hoses so it rendered the EGR ineffective. I don't know if you can see it without taking everything apart, but they put more new hoses on and been fine since...
11-03-2019, 03:53 PM | #178 |
Rep 1,386
Mine passed the inspection. However, I do wonder what they reset in the PCM while they were in there. The car felt and sounded different with a bit more diesel clatter. After a couple of weeks that seems to be going away.
I'm using the car for my commute as I bought my wife a 2018 GLC. Seeing close to 40 mpg on my commute so looks like the thing is actually running well. |
11-03-2019, 06:04 PM | #179 | |
Rep 776
11-05-2019, 04:32 AM | #180 | |
Rep 112
Another guy I know who also has a 330d had the EGR recall carried out on his car and the hissing is still there afterwards so at least I know it doesn't have anything to do with that. The thing is, I got the car remapped and I mentioned this to the guy doing it. He said that the car is holding boost as expected even though the hissing is there. It's coming from the turbo area (which is right in front of the driving position) and the remap made it louder so I'm guessing it's either induction noise or it's just the turbo wastegate releasing air/pressure it doesn't need at a given RPM. |
11-05-2019, 07:35 PM | #181 |
Rep 2
Drives: 2014 BMW 328xd SportsWagon
Dealer inspected for the EGR cooler recall on my 2014 328d, and said it was fine. Next day engine light came on, and not long after that I got a drivetrain malfunction light, then a few days later a loss of power. Dealer says the EGR itself is gone, and there is still no problem with the EGR cooler. He wants $625 to replace the EGR itself. Is it just a wild coincidence that the day after they inspect for the EGR cooler recall my EGR valve goes bad? Seems strange...
11-09-2019, 10:27 AM | #182 |
Rep 112
Drives: 2014 328D
They did mine a few weeks ago said it was just a gasket no problems yet
11-12-2019, 05:20 PM | #183 |
Rep 30
I just booked an appointment next week to have this recall done.
So the last week I started to get a coolant low light when starting the car. The light came on three different times but after a drive the light would go off and a few days later I would encounter there same issue. There are no visible signs of a coolant leak. I briefly spoke with a SA at the dealer and she said the fluctuation in the temperature could cause the coolant to expand or contract. Told me to bring in the car to top it off and see how the car is after a few days. Which I just did today. The first time the light came on we did have a big dip in temperature but isn't the cooling system a closed system? I never had a car where the coolant needed to be topped up. I'm just curious to the validity of her comments. Again the light came on today and today there was also a big dip in temperature. The car is a 14' 328d.. |
11-13-2019, 09:47 PM | #184 |
Rep 19
I have the '14 328d as well and it was losing at least 1 liter of coolant every three months with no leaks visible. The EGR was just very defective. Before the recall fix, it was obvious when I popped the hood that the reservoir was low each time the light came on though. After they replaced the system under the recall, no more losing coolant. Hopefully that will fix yours...
11-16-2019, 05:57 AM | #186 |
Rep 162
11-18-2019, 11:58 AM | #187 |
Rep 67
Drives: '14 F31 328d Sportline
Dropped my car of at the dealer on October 16th for the recall. Car is sitting at dealer until parts come, can't release because of it being a safety issue. ETA for parts is mid December. Driving a bone stock G20 330i until then
11-19-2019, 06:43 AM | #188 |
Rep 30
I just dropped off my car this morning.. I hope this doesn't happen to me.. no loaner either because I didn't buy the car from them..
11-19-2019, 03:25 PM | #189 |
Rep 39
Recall
I took my 16 328d to the dealership yesterday for service. The SA made me aware of the recall and wanted to know if I wanted it serviced for that. I asked if there was a reason I shouldn't get it performed. He mentioned that a few owners have actually denied the service, but didn't know a reason. I opted for the recall service. After leaving the dealership in the loaner I started googling and found this thread. I read up on a few others and the horror stories in relation.
I received a call later in the afternoon around 3 from my SA letting me know that "i'm in a later stage" and that those parts would need to be replaced before returning the car to me. He said he would call me the next day and let me know the shipping times. I get a call today saying that the EGR cooler, Boost pressure sensor & intake pipe w/ air flap will need to be changed and that i'm looking at mid December before they receive the parts. They stated that it's ok to drive the car. I asked if I had a choice and they stated no. This information doesn't correspond with anything i've seen here and I understand that I could be thinking the worst here and over reacting, but I wanted to be sure. I called BMW NA recall line and they told me that they are relying on the dealer and if that is what they said then that is what I need to do. I thanked them and told them I just wanted to do my proper research. I called my SA back and he assured me he wouldn't put me or my family in any danger. I am to pick up my car in the morning. Am I over thinking things here? I don't have another alternative vehicle so kind of don't have a choice in the matter. |
11-19-2019, 03:57 PM | #190 | |
Rep 776
11-26-2019, 10:30 PM | #192 |
SQUEAKY
104
Rep 322
12-02-2019, 09:32 AM | #193 |
Rep 1,895
Neither of the dealers here will inspect my car because of the parts backlog. Just put me on a list to contact once the parts come in.
12-04-2019, 08:32 PM | #194 |
Photographer
241
Rep 142
Well I will keep this brief:
I scheduled and took my wagon (14 328D) in for the recall on 11/1/19. On 11/7/19 I was told that I needed to have replaced almost everything under the recall (intake manifold, map sensor, egr cooler, vacuum lines, etc.) On around 11/11/19 I was told parts were on back order and to expect them by mid December or January. Today and two loaner cars later I am still waiting for parts to come in. My wagon is literally just been sitting this whole time. UPDATE: 12/5 Wagon is supposedly ready for pick up I will find out more tomorrow morning. This was unexpected but I am happy they finished without any issues.
BMW F87 M2 BSM LCI l BMWMTW0 l Group IG: BMWPlusOnes l Build Thread: Coming Soon....
01-14-2020, 11:44 AM | #195 |
Mini Cooper, Present F15 Owner
Rep 90
Yikes. I'm late to the party!!!
I bought my '15 328D in September '19. Then I found this site! Once again, a day late, many dollars short, possibly. My car has 56K miles on it. I've gone through a brake flush, LOF, and ... added a little coolant and DEF because I was low on both. I stopped by my nearest BMW dealership and talked to the SA to see what kind of service my car had undergone. Pretty minimal, actually, but he did mention the EGR recall inspection and told me if my car was affected, they'd need to keep it until the parts came in. I live 200+ miles from the dealership so this isn't going to be convenient if they impound the car. So the questions in my mind: 1. Would an EGR delete be the real fix? 2. What does "coding" out the EGR actually do? 3. Does this shut off the EGR valve leaving it to no longer serving a function other than decoration? I am a survivor of BMW/NA and a recall dilemma on MINI Cooper power steering pumps. They began by extending the warranty to cover cars that had expired until the NHTSA made them do a recall. I ended up having the power steering pump replaced three times under those directives. What a goat rope! Sorry I'm late to the party but I'm wondering what to do next with my 328d - do a hardware/coding delete or let the recall process run its course. Suggestions? |
01-14-2020, 02:11 PM | #196 |
Rep 1,803
The recall replaces the EGR cooler that had internal stress cracks with an updated part that isn't faulty.
They may replace up to the intake manifold as needed. It is a definitive fix.
01-14-2020, 04:17 PM | #197 |
Rep 90
Thx. I don't live in a part of the world that has emissions testing (yet) which is why I am interested in the EGR/DEF delete. This would also be a definitive fix and from what I gather, results in more grunt and MPG. I might pay for that...
