BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F31 suspension guide & discussion
      09-26-2020, 01:32 PM   #155
gippy
Drives: F32 440i, pre-LCI, w/MPPSK
one other thing about fitting - i also noticed on FaRKle! springs + shocks installation vid is when he torqued everything back up, the angle wasn't applied after.
in ISTA a lot of the values for the job have the angle rotation value next to the torque value.
shouldn't we torque to desired value then rotate the specified angle too?
      09-26-2020, 05:15 PM   #156
FaRKle!
Drives: '17 328d Wagon, '21 M2 Comp
The torque to yield (TTY) angle should only be done on new fasteners. It's used to stretch the fastener after applying the initial fastening torque. You should never do the TTY angle to an already stretched fastener. Most people (including the dealers) don't buy brand new fasteners for the ones that are TTY so I don't tell them to do the additional angle.
      10-20-2020, 01:39 PM   #157
328iX
David
328iX's Avatar
Drives: 2015 328iX F31
Bump
      11-06-2020, 01:03 PM   #158
davidc13
Drives: F31 - 330ix
Have the spring rates for the standard and M-Adaptive F31 suspensions ever been posted? I tried searching but had no luck.
I did find a reference that the rear spring rates are similar to the Eibach 11-20-014-14-HA which is found in E10-20-031-14-22 and E10-20-031-15-22.
I'm currently running Koni SA/ Eibach E10-20-031-04-22 (F 1020kg; F11-20-031-02-VA and R 1310kg; F11-20-031-03-HA) with F8X bump stops, but I'm not too pleased with the ride. At low speed, the road feels wavy and the car seems to rock side to side. Once I pick up speed it feels better.
I'm thinking of playing around with different spring configurations. At this point, I don't mind losing some of the drop from the Eibach springs and try a stiffer than stock M-Sport or F8X spring. I did find a super cheap set of M4 springs (DCT) I'm considering to try out.
Originally Posted by FaRKle! View Post
Also, I had my OE F31 rear spring compared to my Eibach F31 rear spring at my suspension guru's today and they have about the same spring rate. My suspension guy said that's not too uncommon where a lowering spring company will only stiffen the front rate.
      11-12-2020, 02:26 PM   #159
yyzwagon
yyzwagon's Avatar
Drives: F31
some noob questions:
(1) going with any springs set, I need new bump stops right?
(2) going with any springs set, are they compatible with adaptive suspension/EDC?
(3) going with coilovers, am i forced to disable/delete/code-out adaptive suspension/EDC?
      12-28-2020, 02:34 PM   #160
chambo622
Drives: F31 328i M Sport EBII
Originally Posted by Car 65 View Post
I drove the car today and made a point of crossing many speed humps.
The suspension settled a little bit.
Presently 13 3/4" right and left front.
13 7/8" left rear, 13 15/16" right rear.
I'm going to leave it as is for a months use, then measure again.
If I still have the same numbers I'll have an alignment done.
Very pleased with the appearance and ride quality. No more sky high front end.
The front setting would not work well in the snow.
But the last time we had snow where I live was 1961.
If I'm heading to snow country the front can be raised.
That is a definite benefit of this H&R package.
As 328iX has stated, the front is very easy to adjust.
The rear not so much.
I'll report back in a month or so.
How are the coilers after a few months?
      01-07-2021, 08:31 AM   #161
yyzwagon
yyzwagon's Avatar
Drives: F31
im looking for feedback for ppl w/ adaptive suspension on H&R springs + stock everything else (dampers/struts/etc).
is the ride really as bouncy as claimed in post #1?
      02-01-2021, 05:12 PM   #162
DieselTouring
Drives: 2014 328d Wagon
This is primarily for 328iX and FaRKle!, but if anyone knows the answer, please chime in!
Do we know the difference in spring length and spring rate for the front springs in the two Eibach kits (E10-20-031-14-22 and E10-20-031-15-22). From Eibach's EU site, *14-22 lists F11-20-031-01-VA with front axle load 965kg and *15-22 lists F11-20-031-02-VA with front axle load 1010kg, yet both list a 30mm front drop and I can't find anything about spring rate or spring length.
I'll be ordering a set for my 2014 328d Wagon to pair with the Koni SAs, but want to know if the difference is simply starting ride height, if ride height is the same and the spring rate is different, or if they're both different. I've got an email out to Eibach too, but figured someone here may be faster with the answer.
F31 328d M-Sport - M-Performance brakes, DUDMD tune
E36 "M3" (328 fully converted track car)
      02-02-2021, 12:22 AM   #163
FaRKle!
Those springs have the same rate. -031-02VA is 10mm taller.
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      02-02-2021, 05:04 PM   #164
DieselTouring
Thanks for that info. I see you had mentioned that earlier in the thread, but didn't know if the spring rates were the same, so thanks for clarifying.
Additionally, does anyone have experience with the Dinan bump stop kit? I'm replacing my bumpstops anyhow, and wonder if the slight drop from the Eibach Pro-Kit would make use of the Dinan bump stops, or if sticking with the OE bump stops for the F31 328d is prudent to protect the Konis as the drop from the Pro-Kit is minimal and Dinan doesn't specifically list F31 compatability (or 328d for that matter). Cost difference between the OE and Dinan is negligible (~$100 vs. $135, respectively) as a fraction of the total investment.
      02-02-2021, 09:13 PM   #165
damack
damack's Avatar
Drives: 2017 F31 330i M-Performance
Good info on bump stops here
A Look at Bump Stops https://f30.bimmerpost.com/forums/sh....php?t=1621134
      02-04-2021, 12:36 PM   #166
DieselTouring
Super useful link on the bump stops, thanks! That should be added to the first post in the thread.
      03-27-2021, 10:06 PM   #167
Choopís
Drives: 2014 F31/2019 F87/1985 E28
Originally Posted by 328iX View Post
The one in the picture is the Incorrect strut. I also assumed it was for RWD, thanks for clarifying.
I spoke to H&R and they informed me I had all the correct parts, until I told them there's no way it would work, and that's when I was sent the correct parts and the kit was revised.
The correct part number struts that we're sent to me were
1633452-R1/1
1633452-L1/1
Just received my H&R coilover kit that I ordered from Turner Motorsports. Just my luck I received the incorrect struts just as you did with your kit last year. Not sure if this is a Turner mistake or if H&R is at fault. Iíll have to give them a call on Monday and try to get this ironed out.
      03-28-2021, 01:09 AM   #168
328iX
David
328iX's Avatar
Good thing you caught it, can't believe they're still making that mistake
      03-29-2021, 10:42 AM   #169
Choopís
Thank you for posting the info!
I just got off the phone with both H&R and Turner/ECS. H&R confirmed that 28895-4 is the wrong kit and that 28895-8 is the correct kit. I called Turner/ECS and they were clueless. I explained the issue and that I talked to H&R and they confirmed that the Turnerís fit guide is incorrect. The lady asked me what type of car, model, etc., and then had the nerve to tell me the -8 kit would not fit my car. I asked her where she was getting the info and she said from their fit guide.
After explaining it to her again, I still donít think she got it. She issued a return label and stated when they get the -4 kit back, theyíll drop ship the -8 from H&R. They didnít offer any apology or way to accommodate me and speed up the -8 kit getting to me. When I suggested that she may want to have someone update the fit guide, she made no comment.
Iíve been buying from Turner since 2001 and itís really sad how what was such a great company to buy from has now become part of this giant ECS conglomerate where customer service is non-existent.
Rant over.
      03-29-2021, 10:53 AM   #170
328iX
David
328iX's Avatar
I just got off the phone with both H&R and Turner/ECS. H&R confirmed that 28895-4 is the wrong kit and that 28895-8 is the correct kit. I called Turner/ECS and they were clueless. I explained the issue and that I talked to H&R and they confirmed that the Turner’s fit guide is incorrect. The lady asked me what type of car, model, etc., and then had the nerve to tell me the -8 kit would not fit my car. I asked her where she was getting the info and she said from their fit guide.
After explaining it to her again, I still don’t think she got it. She issued a return label and stated when they get the -4 kit back, they’ll drop ship the -8 from H&R. They didn’t offer any apology or way to accommodate me and speed up the -8 kit getting to me. When I suggested that she may want to have someone update the fit guide, she made no comment.
I’ve been buying from Turner since 2001 and it’s really sad how what was such a great company to buy from has now become part of this giant ECS conglomerate where customer service is non-existent.
Rant over.
I didn't even deal with ECS / Turner. I went straight to H&R, made them pay for all the repairs and send me the new parts. They actually told me not to get ECS involved which is why I imagine it was never updated. I was under the impression they would notify them.
      04-20-2021, 06:24 PM   #171
Aziego
Drives: 2015 M3 | 2017 330i Wagon
So I recently purchased a F31. Looking at suspension options as I feel the car is a little unsettled when driving. Of course I want a slightly lowered appearance as well. What is the thoughts on Bilsteins B14? I had PSS9 in a S2000 before and liked the ride. My other ride is a F80 so stiffness doesn't bother me much.
The F31 has 65k miles, any other components to change while I am installing the coils?
      04-21-2021, 01:51 AM   #172
328iX
David
328iX's Avatar
Any option works really, Bilstein or KW street comfort are both great.
I also came from an S2000, actually had 3 of them.
Regarding what to replace I'd normally go with everything. Definitely new top hats front and rear, bump stops, top and bottom isolators, dust boots. Etc. doesn't cost that much more, top hats are you biggest expense.
      04-21-2021, 03:55 PM   #173
Burgers
Bridger
Burgers's Avatar
Drives: F30 335i
If anyone could give me their advice on an issue it would be great!
I just installed some B16s and set all of the parts to the same thread count: 10.
The front right of the car is now about approximately 3/8" lower than the front left. Should I raise that coilover to have an equal height? I saw on the forums here that there is naturally some difference in balancing. Or would it be better to simply ensure that the coilovers are equal height and let it be?
Thank you.
      04-22-2021, 01:52 AM   #174
BBri89
BBri89's Avatar
Drives: F31 320d xDrive M Sport
Thank you.
Is that WITH you in the drivers seat, or not?
You probably want it level and balanced with your typical car load... so driver + normal passengers & luggage.
If you're normally the only one in the car, then just you. If there's always others in the car, then take that into consideration.
But sounds like with someone in the drivers seat then it might be pretty level
2015 F31 320d xDrive M Sport (Plus pack)
My progress thread
      04-22-2021, 05:01 PM   #175
328iX
David
328iX's Avatar
Thank you.
There was always some variance with my vehicles but I believe it always came down to where you're parked & how you stopped the vehicle.
Even going up a driveway into a garage will leave the front higher than the rear, yes you would end up on a flat surface, but the action of going up the driveway shifts all the weight to the rear and it settles there.
I would first measure in several different parking lots and flat surfaces before making adjustments.
Secondly, check you make sure the coilovers are fully seated in the knuckle.
Lastly, get an alignment.
Order doesn't really matter, you can do whichever you'd like first. But point is I would check everything else first, I would try to keep them at equal adjustments, if you lower or raise one side, it will actually upset/ affect other corners, you will find yourself making adjustments indefinitely.
      04-23-2021, 03:27 PM   #176
Burgers
Bridger
Burgers's Avatar
Drives: F30 335i
That's without me in the vehicle. I'll grab a friend and go to some different spots to measure it with me and see what happens. Thanks!
Last edited by Burgers; 04-23-2021 at 03:29 PM.. Reason: I don't know how to reply
