BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Car won't start after failed Bootmod3 flash
proTUNING Freaks
      07-31-2020, 07:32 PM   #1
chhappy7
chhappy7's Avatar
129
Drives: 2015 328i RWD
2015 328i  [0.00]
Hey guys.
So I've been using stage 1 91 octane then I found some 93 gas so I decided to flash 93 map. But it sort of went through but bootmod3 was unable to clear the codes. As a result I can't turn my car on. The car goes to ignition on mode but I can't turn the actual engine on.
I read through some posts but nothing has worked so far.
1. Disconnect negative terminal for 10 minutes then try to reflash
2. Reflash using the force reflash and unlock option (suggested by BM3 support)
3. DME reset under diagnostic then reflash
4. Use laptop and iOS to see if it was the devices.
So I'm at my wit's end here. I've been waiting for my insurance company to find me towing for the past half hour with no luck so I'm kind of stuck at a parking lot with no public transit either. In hindsight, I should've done this at home but since my first flash went so well I didn't think it would go all SNAFU on me.
I'll probably end up calling a friend to ask if he can give me a ride home and then maybe back to the parking lot but I still need to fix it and PTF is closed for the weekend.
Any help would be great.
2015 328i - M Sport front&rear bumper/diffuser, M3 style fender/side skirt, M Performance brakes, BBS SR, ceramic iDrive, LCI radio trim, 6WB, NBT EVO, X5M razor key
      08-01-2020, 04:14 PM   #2
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
What happened during the flash? Did it finish with 100% complete turn off car wait 5 sec then start the car or it got stuck somewhere and it got interrupt?
Asking because it happened to me 2 night ago.
      08-01-2020, 04:17 PM   #3
chhappy7
chhappy7's Avatar
129
2015 328i  [0.00]
Initially it would finish but didn't clear codes despite the box saying clearing all codes.
Then it proceeded to go all the way to successfully finished but in like 3 seconds so I knew something wasn't right even though it said successfully finished.
Now it just fails before start according to the dialog box.
Currently have battery on charger at home. I had to take it out of the car as I live in an apartment and that was a pain due to the lower battery bracket thing...
      08-01-2020, 04:37 PM   #4
Gen13 F36
Gen13 F36's Avatar
This is what I did to mine per PTF said to update the agent but I have the newest again installed so I went to doing the following
Turn of your antivirus/internet security software.
Uninstall the current agent
Install a freshly downloaded new agent.
Then try again to reflash the car.
Maybe this will work for you too.
Be sure the internet security is off and also disable the windows defender while your at it.
      08-01-2020, 11:51 PM   #5
Gen13 F36
Gen13 F36's Avatar
How did it go?
      08-02-2020, 08:03 PM   #6
chhappy7
chhappy7's Avatar
129
2015 328i  [0.00]
How did it go?
Well, it wasn't the battery.
Bootmod support suggested it was a faulty ENET cable so I ordered one but ZGW Search tool was able to the car just fine.
So upon doing some searching it seems on bootmod3 enthusiast facebook group, Zed coding seems to have helped many people recover from something similar to what I experienced, and so I reached out.
And now within 4 hours of contacting him, my Yanny is back to life!
Albeit with a stock tune, but I think I'm going to keep Yanny in the current form for now.
Here is link to the fb. It took Zed an hour plus but it finally worked!
https://www.facebook.com/zedcoding/
      08-02-2020, 08:35 PM   #7
DreamerJoe
Drives: 2013 F30 335i
what ended up being the actual problem?
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
      08-02-2020, 08:38 PM   #8
chhappy7
chhappy7's Avatar
129
2015 328i  [0.00]
I think something went wrong during flashing where it put it in like a weird mode. The coder didn't tell me exactly how the stock tune was flashed, but it was an hour+ session and told me the software was rejected when he went through regular ways.
Which makes sense because when I went into E-Sys before going to the coder to see if it really is the ENET cable, it could connect to the car just fine but when it came to ECU part, it just gave an error saying value null or something like that.
      08-02-2020, 10:18 PM   #9
DreamerJoe
was the failure vehicle related or bm3/software related? in your position, if it wasn't your or your car's fault, I would reach out to PTF about compensating the cost of the coding session.. especially if it was their software's fault, obviously if it wasn't I would pony up for the bill, but try to find out what went wrong and post it so nobody else runs into the same issue too.. glad you got it all sorted out though, I would be sweatin' it if I thought I had bricked my car during a failed flash, I had an error one time but was able to just reflash after and all was okay luckily (MHD though).
      03-21-2021, 08:46 PM   #10
hristo.p
Drives: 2015 335i Xdrive MSport
Hey guys.
Hey guys.
Same or similar problem, tried to reflash my stage 2 93 OTS map to improve burbles and get GTS roar (in retrospect idk if that is even available for N55, but it was an option) the flash didn't go through, failed 2 times at 1%, reflash to stock failed at 14%. Car won't start. There are various malfunction messages on the dashboard. Charged my battery with a 30amp charger, kept the charger hooked up and tried to reflash again Stage 2 - failed, no % progress displayed. PTF advised to go to stock next - failed at "clearing codes" stage. Luckily PTF have been super responsive and looking for a workaround to get my car to start. If anyone has some suggestions, please let me know! No recent BMW updates, car was running stage 2 flawlessly for several months! I flash through my iPhone.
      03-21-2021, 10:36 PM   #11
AMG KLR
AMG KLR's Avatar
97
Drives: 2018 440i GC
There is your problem
      03-21-2021, 10:43 PM   #12
hristo.p
I did several flawless flashes though. There is always a first time I guess. I ordered a new cable and will try with my MacBook.
Will keep you all posted.
      03-22-2021, 08:48 AM   #13
AMG KLR
AMG KLR's Avatar
97
Likewise i have flashed a handful of times via iPhone but the app is hot garbage IMO. There is a big issue when it comes to the phone detecting the car (AKA the phone acting as the OBD agent). It either works or it doesn't for me and is quite frustrating.
Laptop will sort you out.
      03-22-2021, 06:45 PM   #14
trebec
Drives: F30 335xi
What does that even mean? I do it all the time through my iPhone and the MHD wireless dongle, never had an issue in 10 plus flashes.
2013 335xi F30 - Mineral White Metallic
      03-22-2021, 06:56 PM   #15
jackstrath
Scotland
551
Drives: 16' F31 340i & 03' Focus RS
Apple are always updating their security, most likely something has been changed in the phones soft wear and could now be giving you issues. Laptop is always the better way to do it!
      03-22-2021, 09:13 PM   #16
kslice86
kslice86's Avatar
Drives: BMW 430i GC
2016 BMW X3  [0.00]
My car went through this same problem. If the dealership has recently updated your system. The DME(ecu) will fail cause the vehicle to not start. The new update flags cars with flash tunes. Only way to get it fixed is at the dealership, they will reset the DME(ecu)
      03-22-2021, 10:42 PM   #17
hristo.p
My car is 2015, out of warranty and I haven't been to the dealership in ages... some of the newer models can get updates wirelessly (dealer updating you software without you knowing) but I doubt that's the case here. I saw some other reports with the same issues, it their cars were updated at the dealer.
I have a remote session scheduled with PTF tomorrow who will look into the issue remotely.
Will keep you all posted!
      03-23-2021, 04:14 PM   #18
rt19504
Drives: f82 m4
just registered to note that i am having the same problem as everyone here.
have a new m4 (2019) tried to flash on bootmod3 after unlocking the ecu and it fails at 1% and now i cannot start the car as the ecu is corrupted.
will be looking through it with bm3 support tomorrow, but not holding my breath as we all seem to have the same problem.
likely going to have to end up taking it back to bmw
      03-23-2021, 04:44 PM   #19
kslice86
kslice86's Avatar
Drives: BMW 430i GC
2016 BMW X3  [0.00]
My car is finally ready after a week of being in the shop. The dealership reached out BMW and was told the tune was bad. When I was trying to flash stage 1, it would get to 3% then crash. PTF told me the only way to get passed it was to bench unlock, I would have to send them my DME(ecu).
      03-23-2021, 05:01 PM   #20
thejeremyman9
thejeremyman9's Avatar
2092
Drives: 2015 BMW 335i
I agree its unlikely its due to a software update, but let us know how it goes.
Although you might be having the same failed flash issue, OP's problem is likely different. You are talking about a newer model, different car, different DME, etc. Plus, OP had already flashed and been running BM3 previously.
      03-23-2021, 05:40 PM   #21
kslice86
kslice86's Avatar
Drives: BMW 430i GC
2016 BMW X3  [0.00]
I was running BM3 stage 1 for 3months all of a sudden now it started this. My dealer updated my software the beginning of March.
      03-23-2021, 05:55 PM   #22
im_an_alien
im_an_alien's Avatar
437
Drives: 2016 340i
What's your i-step version
