04-30-2021, 05:23 PM | #1 |
Rep 809
Stuttering/hesitation only at low RPMs (asking for help)
I've been trying to troubleshoot an issue where going full WOT I experience hesitation and stutter, mainly when full WOT happens between 900 and 1000 RPMs (at higher RPMs, I don't have any problems in full WOT). No codes whatsoever shown on the iDrive nor when using a scanner....
So far I've replaced these parts for brand new OEM ones trying to resolve the problem: - Injectors - MAF Sensor - MAP Sensor - Spark Plugs - Ignition Coils But the stuttering remains..... I've told that it might be the Fuel Pump Control Unit (part number 16149494391 for the B48 engine), but, I don't have any codes showing that the module has a problem. Should this part throw a code if it is malfunctioning or could it be having problems without throwing any codes? Thanks for the help as I've been trying to resolve this stuttering and hesitation when I WOT between 900-1000 rpms for six months now
Proud BMW owner
E87 130i E90 LCI 320d F22 M235i F15 X5 30d F30 LCI 320i MSport G05 X5 30d MSport Last edited by AlexGT; 05-03-2021 at 06:46 PM.. Reason: Typo |
04-30-2021, 06:14 PM | #3 |
Rep 809
LOL, sorry I meant 1000 (or 1K) RPMS
Proud BMW owner
E87 130i E90 LCI 320d F22 M235i F15 X5 30d F30 LCI 320i MSport G05 X5 30d MSport |
04-30-2021, 06:17 PM | #4 | |
Rep 844
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
04-30-2021, 07:19 PM | #5 | |
Rep 809
https://youtu.be/3Va1NFG6eQU
Proud BMW owner
05-01-2021, 06:28 AM | #6 | ||
Rep 844
In my opinion all of the info is starting to point to a vacuum or PCV issue. I had a very similar issue in an A4 I used to own where it would stutter under load between 1k-2k. I brought it to about 6 different mechanics, Indy, Audi, tuners, and no one could ever find the problem. I tried EVERYTHING to fix it. The only thing that worked, and it was only fixed it for about 3 months, was installing a new intake manifold. Sold the car after 4 years to my coworker who is still driving it without any advancement on the issue. In that particular instance there was definitely negative pressure in the engine because when I would remove my oil cap with the engine running there would be a tremendous amount of suction trying to bring the cap back down. No idea where the pressure was coming from. I learned to just live with it and only go WOT after 2k rpm lol. To this day it bothers me that I could never figure it out.
05-01-2021, 08:02 AM | #7 |
Rep 455
Is the suttering a new development or has it always been there ? Going wot at 900rpm is bound to be a bit messy on my opinion, that's basically fast idle. How had does it stutter?
05-02-2021, 02:46 AM | #9 |
Rep 9
Sorry to Hijack, don't have anything to add to original post, new user and can't start new thread myself, but some of the same symptoms. 2017 320i (b48), 33k miles and 9/10k OCI kept up in its life so far running an eco map around 220ps, for last 3k miles/4 months with no issues until this week. Rough running, idling and vibration diagnosed as a misfire in cylinder 1 at main dealer. Coils swapped and all spark plugs changed and problem remains on cylinder 1. Dealer is holding on to car for a week or so due to workload but wondering if anyone has had similar issue and what I might expect them to find and if there's any possibility the map could have contributed to the issue? Many thanks
05-02-2021, 07:01 PM | #10 | |
Rep 809
05-02-2021, 08:46 PM | #11 | |
Rep 809
Here's a video the BMW dealership took after they replaced the injectors (after they said it might me a problem with the injectors) and the issue remains. https://youtube.com/shorts/wlQf4whbAhk?feature=share
Proud BMW owner
05-03-2021, 03:27 PM | #12 |
Rep 455
I'll try it on mine if I get the chance. Revving while stationary is not really representative though, does it cause any actual drivability issues?
05-03-2021, 03:33 PM | #13 | |
Rep 809
Drivability issues just when WOT between 900-1000RPMs, the issue actually does not happen at all on higher revs when WOT and strangely does not happen when accelerating smoothly (not WOT) between 900-1000RPMs.
Proud BMW owner
05-03-2021, 03:43 PM | #14 |
Rep 455
I don't have the issue no, I can compare it to my 330i with the B48 to confirm if it's an issue or not. To be honest, that particular rev point is really not useful and it might be that it's where a changeover in the calibration maps happens.
05-03-2021, 04:02 PM | #15 |
Rep 809
Thanks but I'm sure you don't have the issue, as it is very noticeable. The issue started six months ago (didn't have it before). Six months with a huge question mark in my head, wondering what the hell is making my B48 to have this weird behavior.
Proud BMW owner
05-03-2021, 06:26 PM | #16 |
Rep 455
Have you made any logs? Throttle pedal/throttle, fuel pressure, ignition advance, any misfires/knocks etc?
05-03-2021, 06:53 PM | #17 |
Rep 7,602
Is your car completely stock or tuned? If its tuned, definitely datalog the problem.
If its completely stock, are you forcing the engine to stay low RPM for the problem to occur? I don't see any other way you would be WOT at <1k RPM except in 1st gear from a dead stop as the car would almost certainly downshift before it starts to build any significant boost or load at that low of RPM. |
05-03-2021, 07:31 PM | #18 |
Rep 809
Nope, dont know how to pull and save logs tbh
Proud BMW owner
05-03-2021, 07:39 PM | #19 | |
Rep 809
Proud BMW owner
05-04-2021, 12:26 PM | #20 | |
Rep 7,602
So are you in manual mode when it happens or auto? |
05-04-2021, 12:30 PM | #21 | |
Rep 809
I always drive in auto mode, but the issue lowers when driving auto in sport mode as the sport mode revs a little bit more the engine so when cruising at lower speed, revs keep above 1k rpms.
Proud BMW owner
05-04-2021, 10:09 PM | #22 |
Rep 334
Drives: 2016 BMW 340i Xdrive Msport
I want to say my car is doing something similar, but my car does it on start ups and sometimes when i'm at like a traffic light. It been like this since i bought the car but it wasn't as obvious. It was always so slight that it could go unnoticed. The worst its been is when i got the DME and took it to the dealer and they said it was the vent valve and i replaced it and the issue went away but its back. Plan on taking it back to the dealer and see what they say this time. Strange thing is i have no cel or anything. Don't feel like giving bmw another $180 for diagnosis but i'm over it at this point. Mite take it to a local mechanic first and see if they can diagnosis it first. This and an issue with my window directional switch button being stuck in one position causing my left side mirror to pan out and make it difficult to see out of are my only current issues. Soon have it all taken care of though.
