05-05-2021, 06:08 AM | #23 |
Rep 457
I'd say yours is not linked to the OP's: different engine types, yours has EGR, etc.
05-06-2021, 05:02 AM | #24 | |
Rep 919
05-13-2021, 05:59 PM | #25 |
Rep 809
Thanks for offering your help man. When you say you're near-ish, what do you mean? Because I live in Guatemala (Central America) hehe.
Proud BMW owner
E87 130i E90 LCI 320d F22 M235i F15 X5 30d F30 LCI 320i MSport G05 X5 30d MSport |
05-13-2021, 06:06 PM | #26 |
Rep 809
For those who have been kind enough to try and assist and suggest, here's an update:
A BMW mechanic (not from de stealership) found that my oil has water-ish color so he said I need to replace the oil heat exchanger and its corresponding gasket because that "could be" the reason I'm getting this sputtering. This parts had been ordered from ECS Tuning (still waiting for them to arrive): https://www.ecstuning.com/b-genuine-...r/11428585624/ https://www.ecstuning.com/b-genuine-...t/11428591462/ I'm not an expert so I'm giving this theory a chance. Will let you know the outcome once they get replaced. And, I've also ordered a brand new wastegate (still pending for arrival) https://www.ecstuning.com/b-genuine-...r/11657850453/ Wish me luck
Proud BMW owner
05-14-2021, 01:32 AM | #27 | ||
Rep 42
Drives: BMW G20 330i & BMW G30 540i
05-14-2021, 01:18 PM | #28 | |
Rep 7,606
05-14-2021, 02:23 PM | #29 |
Rep 809
Thank you for the suggestion, but I won't be able to do that as I don't live in the USA.
Proud BMW owner
05-14-2021, 02:26 PM | #30 | |
Rep 809
Thanks for the good wishes
Proud BMW owner
01-16-2024, 08:39 PM | #31 | |
Rep 1
I'm kinda late to this thread, but did you solve your issue? I have the exact symptom like yours (no CEL), can't figure it out what the issue is for several weeks. I don't have issue with acceleration but only when I release the gas pedal let say at 55 mph and let the car run by itself until rpm drops to 1000 from 2500-3000 then I feel a sensation of pulsation/hesitation/engine surge and rpm needle bounces up and down couple times and eventually it settles down at a proper idle (only see this behavior at 1000 rpm and my car is completely stock except replacing the oil cooler with Mosselman). I replaced plugs, coils, clean MAF, MAPs, and swapped solenoids and also replaced one of the MAP with a new one, but nothing changes (may be it helps a bit, but the symptom still exists). It's a very annoying experience and it just starts this weird behavior a few months ago. Btw, I'm planning to bring my car to the shop next week and hopefully will find out the root cause. Thanks. Last edited by ryanvu05; 01-16-2024 at 09:06 PM.. |
02-15-2024, 01:11 PM | #32 |
Rep 1
Hello Ryan
Have you manged to resolve the issue . I have the very same problem with my BMW 3201 2013 model. The problem only appears in comfort mode and between 1.5 to 2 k revs. In sport model there's no.issue . |
02-15-2024, 02:26 PM | #33 |
Rep 86
One person mentioned the PCV - BMW put out an extended warranty on this part for the B58
PCV is a common issue with these engines - worth a shot if BMW will replace it for free |
