BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 328i Reliability
      04-30-2021, 08:43 PM   #1
gpdriver17
Drives: F90 M5
328i Reliability
What's the reliability like on 328's? I'm thinking about picking up a used one with ~60k miles. In the past I've had 2 BMW's that were out of warranty and both were NIGHTMARES. One was an E36 M3, said to be rock solid, 70k miles, I spent 9k in repairs in the first 6 months. Another was an E36 328i with 90k miles. Immediately it over heated, head cracked, while it was getting this 5k repair done, the window fell down in the door and it was 1,300 to fix that. Are the F30's much better? I'm fine with some repairs here and there. Just don't want to be best friends with the service advisor.
2019 BMW M5
0-60 2.58
1/4 Mile 10.17
      04-30-2021, 09:52 PM   #2
jsouth
jsouth's Avatar
Drives: 2013 328i
The reliability of any used car is completely dependent on the service habits of previous owners.
My 2013 328i was purchased in January 2016 with 44k miles. I have changed oil and filter regularly, tires, spark plugs, coils, ATF and filter, and because mine was built in 7/2012 I preemptively replaced the timing chain and guides and oil pump chain. I now have almost 147k miles - super reliable car.
Other than the maintenance above, I had to replace a side mirror (under warranty) because it would not retract. I have had to replace the hood release cable.
It's one of the most economical cars I have ever owned. Great gas mileage and low cost of ownership. It is easy on tires (no irregular wear).
M Smurf103.50
Wires821.00
      04-30-2021, 11:16 PM   #3
tturedraider
tturedraider's Avatar
Drives: 18 Glacier Silver 340i M Sport
Personally, I’d be more comfortable looking at B46 330i’s, 2017 & 2018. The N20/26 has known issues with the timing chain guide that have the potential to lead to a catastrophic failure. The issue is reported to be resolved with March 2015 production. To be on the safe side I would recommend looking only at 2016 model 328i’s. Relatively few N20/26’s will have timing chain issues, but the potential would be a constant concern for me.
www.bmwcca.org
member #388003 - Use me as a referral
& you could win a one day ///M Driving School!!
___________________________________________
      05-01-2021, 05:20 AM   #4
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [0.00]
2014 BMW 328i  [5.00]
Ive owned two so far and have had a great record of reliability with mine. I take proper care and maintenance, however.
2014: bought at 29k drove to 95k without any issues. Still would be driving if someone hadn't ruined it for me.
2016: bought at 46k currently at 65k without any issues. Plan to drive for 200k miles plus.
If you do end up with an N20 motor, aim for a build date after 02.2015 when the timing chain components were revised.
adhrp460.50
      05-01-2021, 11:11 AM   #5
gpdriver17
Drives: F90 M5
Thanks for the input! Glad to hear they've improved since the E36.
2019 BMW M5
0-60 2.58
1/4 Mile 10.17
      05-01-2021, 12:47 PM   #6
Psi5
Psi5's Avatar
Drives: 2020 BMW F32 440i
Def buy one with complete, or nearly so, maintenance records. Regular maintenance on BMWs is as important, if not more so, that the particular model's reliability (with the exception of known weak spots, like E39 water pumps - ask me how I know).
Garage:
2020 F32 440i 6MT
2018 Mazda 3 6MT
2013 Mazda 3 6MT
2008 Honda Oddyssey
      05-01-2021, 05:03 PM   #7
schnellwagen
Drives: 2017 BMW 330i SULEV
Originally Posted by tturedraider View Post
Personally, Iíd be more comfortable looking at B46 330iís, 2017 & 2018. The N20/26 has known issues with the timing chain guide that have the potential to lead to a catastrophic failure. The issue is reported to be resolved with March 2015 production. To be on the safe side I would recommend looking only at 2016 model 328iís. Relatively few N20/26ís will have timing chain issues, but the potential would be a constant concern for me.
This.
      05-04-2021, 04:34 PM   #8
phefner
phefner's Avatar
Drives: 991.1 C4S, 991.2 GT3, F30 340
Had our 2013 328xDrive since 2015, been flawless. Only peeve is I just dropped it off for its 75,000 mile service. Told the plug service is going to be like $460! I mean it's just 4 plugs. Ton of space under the hood. WTF are these things made of? It's really going to take 1/2 day?
Quietly Effective
      05-04-2021, 04:47 PM   #9
chowser51
chowser51's Avatar
Drives: F33 430 and F39 X2 M35i
The first three plugs are 5 minutes each. The last plug took a little longer.
$80 for 4 plugs and a long extension socket
M Smurf103.50
      05-04-2021, 07:45 PM   #10
heifetz17
heifetz17's Avatar
35
Drives: 2013 328xi
The e36 was a fantastic car if properly maintained! If not maintained it could be a nightmare.
I've only put about 10k miles on my 328 so far but my mechanic is the one that's serviced the car all the way back to 20k miles and it has 75k now. It's only ever had oil changes and fluid flushes. We're going to replace the timing components at about 90-95k miles just as a precaution. Service records make or break the deal on a used BMW.
      05-04-2021, 09:03 PM   #11
adhrp
Drives: 2012 328i (F30); 2021 X3 (G02)
It has always been in the ballpark of $200 for me. In fact, BMW Value Service has it priced at just over $200. You are being ripped off.
2012 328i Luxury Line | Glacier Silver/Saddle Brown | Premium pkg | Tech pkg | Cold Weather pkg | Lighting pkg | Park Distance Control | Rear sun shade | Anti-theft alarm system
2021 X3 (G02) | Dark Graphite Metallic/Cognac with Contrast Stitch | Premium pkg | Driving Assistance Professional pkg | Front & Rear Heated Seats | Anti-theft alarm system
      05-06-2021, 12:46 PM   #12
phefner
phefner's Avatar
It gets better.
Front Brakes need replacement. So for the ROTOR, Pads, Sensors, Labor... little north of $700. Just for the fronts.
1 Rear Run Flat (pos tire imho), like a little north of $250.
Grounding Braid... again a little north of $200.
I must have JackAss written on my forehead. And this is a dealer I've been doing all my BMW business, like 12 cars in 22 years. Plus all services, all.
This is only the second car we have kept pass warranty and for more than 4 years. Jacking up maintenance isn't going to entice me into another BMW lease. Done with those.
Never again. They're about to lose a client.
Quietly Effective
      05-06-2021, 02:43 PM   #13
M Smurf
M Smurf's Avatar
104
Drives: 2013 328i M Sport
This is the first car I've been motivated enough to my own work, for the most part, and I quite enjoy it to be honest especially given the savings involved.
Brakes are very straighforward actually DIY...if you're motivated. Not much involved
2013 328i M Sport, Estoril Blue, Venetian Beige, Walnut trim, 8AT, Premium, Cold Weather, Lighting, Technology, Navigation, Driver Assistance, HK Sound
      05-06-2021, 02:45 PM   #14
Chihuahua
Chihuahua's Avatar
2053
Drives: E30, F30
Make sure you buy one with updated timing chain and guides. Google N20 timing chain. Other than that it's typical modern day turbo BMW stuff. Good luck with your car search.
      05-06-2021, 02:53 PM   #15
gpdriver17
Drives: F90 M5
Thanks guys, I found a 2016 with 43k miles. Hopefully it wont have the timing chain issue.
2019 BMW M5
0-60 2.58
1/4 Mile 10.17
sspade1972.50
      05-06-2021, 05:12 PM   #16
chowser51
chowser51's Avatar
Brakes should be approx $200 per axle for pads, rotors, sensor wire, if you have the basic brake package. And about a little under an hour to do it yourself.
It's time to start learning how to work on the car if you want to save $$.
