BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Tire wear track
      05-05-2021, 02:48 PM   #1
GreepM
Czech_Republic
Drives: BMW 330i 2019 F31 LCI
Tire wear track
Hi guys,
30min stint on track ended on front tires like this....is it overinflated? Let me know your thoughts, thx.
pressure 38F 42R, M adaptive suspension, RWD
      05-05-2021, 04:10 PM   #2
Wires
Drives: 2016 340i xDrive
That would be my guess. It looks like you are losing lateral grip and sliding sideways.
      05-05-2021, 04:58 PM   #3
jmg
jmg's Avatar
Drives: F80 M3 CS, i3 LCI, VW Atlas
38 is borderline high, but that depends on your tires. I try and keep my tires below 38 on the track. The wear looks about right if you are on factory setup, there is some corner wear. Most cars require camber to keep wear even on the track, about -2.7 to -3.0. So yes, that's "normal" but it isn't ideal, but it isn't nearly as bad as I've seen before.
Your rear pressure is too high.
2018 F80 ///M3 CS - Lime Rock Grey Metallic | MPE | MPHAS | GC Camber Plates | PFC-08 | RE-71R
2019 I01 i3 BEV - Giga World
2021.5 VW Atlas 3.6L V6 SEL 4Motion
Previous: F80 M3 | I01 i3 Rex LCI | I01 i3 REx | F30 340i M Sport ZTR | F30 328i Sport | Audi B7 S4 25Quattro #33 of 250 | E21 320i
      05-06-2021, 07:29 AM   #4
ChuckP49
Drives: 2016 435i xDrive Gran Coupe
Tyre pressures too high. Some tracks are more abrasive than others, and the tyre compound is a huge factor, which Goodyears are they?
      05-06-2021, 07:57 AM   #5
Desertnate
Drives: BMW 435i
2016 BMW 435i  [0.00]
While the pressure might be a little high, I don't know if lowering it much would help.
The first picture makes it look like there is wear on the side of the tread block all the way down to almost the sidewall. At the very bottom of that picture you can faintly make out the inverted "V" symbol marking the edge of the tread and the start of the sidewall.
      05-06-2021, 02:42 PM   #6
thejeremyman9
thejeremyman9's Avatar
2090
Drives: 2015 BMW 335i
Same comment. Lowering tire pressure will improve grip but you dont want to have so much deflection under hard cornering that you go past the line on the tire.
I would run 32/35 F/R and check it after each session because it has probably went up.
To me the wear looks normal, about the same as my brand new tires did after 13 autocross laps. Plowing through corners with understeer will make things worse so make sure you arent going in too hot.
      05-06-2021, 03:42 PM   #7
HighlandPete
Drives: BMW F11 535i Touring
That's what I'm seeing. Surely the comments some have made on lowering the pressure will mean even more roll over onto the sidewalls.
      05-10-2021, 11:12 AM   #8
GreepM
Czech_Republic
It's F1 SuperSport 225/45/18
(..it's also my daily, so bigger sidewalls...and 255 on the rear makes the car quite understeer so... maybe next time I'd go 235/40F and 245/40R)
maybe because of the bigger sidewalls the pressure went to 38s idk...I'm not scientist
Still asking myself, when the car is 50:50 weight ratio, why the rears should have more pressure?
Next time I'll try 32F square or 30/32 F/R hot
      05-10-2021, 11:20 AM   #9
GreepM
Czech_Republic
thanks, you're right. Front camber sucks compared to rears which are in better shape. It's noticeable by just a look. Also me driving won't help much
      05-10-2021, 12:02 PM   #10
N55ryan
Drives: Bmw 435i
looks to be from overinflation
      05-10-2021, 03:50 PM   #11
Desertnate
Drives: BMW 435i
You can slightly change the car's understeer/oversteer behavior depending on pressures. It's really the autocrosser's only weapon in a stock class and I'm sure BMW did the same thing as they dialed in the handling for the car.
      05-21-2021, 05:06 AM   #12
GreepM
Czech_Republic
update:
yesterday 32/34 hot (started with 26/28 btw)
DSC OFF !!! I'd say, when you have it ON the car is quite a lot understeer.
I was fighting only with oversteer, which was super fun, only once went wide in to the gravel
I don't know if it's mainly because of the pressures or DSC off, but I enjoyed the whole session.
