BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 1D2404 - Thermostat replaced
proTUNING Freaks
      05-05-2021, 04:32 PM   #1
LaNcE01
LaNcE01's Avatar
23
Drives: LR2,328i,GLC220d,LibertyGT
Hi,
I need some help, I recently replaced my Thermostat due to code 1D2404. as a back story, I was replacing my oem cooler back to my aftermarket cooler after replacing it what I normally do is run bimmerlink to see if any codes pop up. I dismissed the fact that the thermostat died after installing the cooler, put on coincidence even thought I place the wrong plug (cross between the pcv valve plug) but it wasn't. SO I replaced the thermostat but, as the title suggests. the code is up. I am at a loss now on what to do. any ideas?
is the PCV plug supposed to be empty? I mean the plug is there but there is no connectors from the PCV pipe.
Car 2013 328I - N20
Please move if ive got the wrong sub-thread.
      05-06-2021, 09:28 AM   #2
njdangelo
njdangelo's Avatar
436
Drives: 2019 x5 50i
Originally Posted by LaNcE01 View Post
Hi,
Car 2013 328I - N20
I am having a hard time understanding your post but I can say that if a code came on after you worked on your the first thing to do is double check your work. It's far more likely that something was not reinstalled correctly (ie a cable harness was not plugged back in) than a thermostat to coincidentally go bad right after you installed a new intercooler.
Check your work and go from there. Why did you replace the thermostat? Did you put voltage to it and see it sticking or did you just google a code and buy a part? Thats a quick way to waste a lot of money.
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten.
      05-06-2021, 03:59 PM   #3
LaNcE01
LaNcE01's Avatar
23
Yep! I agree its a quick way to waste money. it seems that the code is now gone, but the oil temp / coolant temp is still erratic. goes up to 114*C for the coolant and goes back down on a traffic light or a stop. shouldn't it be more of a stable / consistent??
      05-06-2021, 05:12 PM   #4
njdangelo
njdangelo's Avatar
436
Drives: 2019 x5 50i
Did you bleed the system after you changed the thermostat? Trapped air could cause those symptoms.
      05-06-2021, 05:51 PM   #5
LaNcE01
LaNcE01's Avatar
23
yes! Did the auto bleeding feature twice.
