05-05-2021, 09:25 PM | #1 |
Rep 1,909
Full DIY Video: How to retrofit a NBT Evo + ATM for full working Connected Drive
If you can manage to listen to myself talk none stop for an hour you are going to learn a lot.
Please like and subscribe |
05-06-2021, 11:56 AM | #2 |
Rep 946
This is awesome. Great job explaining everything. I would highly recommend adding a link to the video on YouTube where they build the atm harness since they also have the part numbers for the connectors there. One other thing to add, instead of looping the gps through the whole car, you should be able to just add a fakra cable from the atm to the shark fin on the roof under the headliner. This way you don't have to route another cable all over BUT if you already are doing the Ethernet wire from atm to head unit, your method works perfectly. Also for those who are hesitant to solder the dc-dc converter for the display, I found a really nice one on mouser that works flawlessly and is very stable: https://www.mouser.com/ProductDetail...2Jj6d99w%3D%3D
05-06-2021, 06:05 PM | #3 | |
Rep 1,909
I have never purchased one so I can not vouch for the quality but they seem reasonably priced. I looked into purchasing the OEM GPS cable from a 18 440i coupe for a more OEM retrofit but I thought that the extension cable would be easier to remove from the car when I sell it in five years or so. I perfectly hardwired the evo in my F10 and I was cursing up a store when I needed to remove it when the engine popped. |
05-06-2021, 06:40 PM | #4 | |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
05-06-2021, 08:14 PM | #5 | |
Rep 1,909
05-24-2021, 12:37 PM | #6 |
Rep 540
This is great, really useful, thanks.
Going to retrofit Evo to my 2014 F30 when I find one at a decent price. Only problem I've got is that finding a matched pair of Evo and ATM is difficult, but I can buy them separately but then they of course have mismatched VINs. I'm assuming that I can get the VIN from the ATM then use an FSC kit for the ATM's VIN to install onto the Evo which changes that to match and then I just need to use it in my car with an emulator. More reading to be done, but thanks again. |
05-24-2021, 01:29 PM | #7 | |
E36fiend
285
Rep 637
Zheez285.00 |
05-24-2021, 05:34 PM | #9 |
E36fiend
285
Rep 637
10-29-2021, 06:40 AM | #10 |
Rep 11
Thanks for this! If I purchase an ATM and Head Unit from the same donor car and the owner previously hadn't registered for Connected Drive services, could the remote services be used on my 2012 F30? Things like the Remote Lock and stuff?
10-30-2021, 04:53 PM | #11 |
Rep 9
great job
10-30-2021, 04:54 PM | #12 |
Rep 9
f10 same thing, nbt 2014
i intrested in f10 2014 is it works ?
07-18-2023, 07:01 PM | #13 |
Rep 30
Nickco43 I see that you have ConnectedDrive weather working, however, did you get remote services working also (lock, unlock, etc.)? If so, did you have to provide continuous power to the CAN filter to have the car talk to the ATM after it went to sleep.
10-07-2023, 04:42 AM | #14 | |
Rep 27
Hello. Could you please post a link to the video you mentioned? The one for the ATM harnesses. Thanks |
10-07-2023, 04:49 AM | #15 | |
Rep 27
What are the physical things I'd need Thanks guys |
12-27-2023, 06:31 PM | #16 | |
Rep 459
Not sure if you still check the forums, but I'm looking to understand how you wired the microphone 2 up to avoid the SOS error. Does anyone know? I poked around ISTA and couldn't find the wiring diagram for microphone 2. Also, +1 for Topdonas1 on eBay, I purchased a harness from him and its working great. |
02-10-2024, 09:40 AM | #17 |
Rep 13
02-15-2024, 04:48 PM | #19 | |
Rep 459
Yes you need VIN Cleared on CAN2 going into the head unit.
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
02-25-2024, 08:40 AM | #21 |
Rep 1,752
When you change the ATM, does the VIN on Connected Drive on your phone change to the donor car's VIN?
2016 428ix, r, 2018 430iC, 2018 330it
02-27-2024, 03:13 PM | #22 |
Rep 459
No, from the perspective of the app it is an entirely different car. You'll add the donor HU like its a new car.
