05-06-2021, 11:43 PM | #1 |
Rep 947
Ignition Coil Primary and Secondary Resistance?
BMW 340i xDrive 2016 I'm in the US.
Anyone know a good set of procedures for this car or would generic advice from google do the job? I want to use my Ohm meter to check each of the coils to make sure they are functioning correctly. |
05-07-2021, 10:12 AM | #2 |
Rep 1,686
Drives: 2014 428i and 2018 X5
Use an OBD reader and check for misfires. if there are none, then it's probably safe to assume their functioning ok.
Do you have a reason to believe they are not?
05-07-2021, 10:18 AM | #3 |
Rep 4,876
Checking for misfires is the best method. Resistance won't help you if the insulation is breaking down in the coil, and they are arcing under use.
05-07-2021, 10:21 AM | #4 |
Rep 18
I am interested in this as well as I have codes 113026 relay ignition, supply voltage injection: short circuit to ground/119404 rail sensor, signal: fixed lying/ 1F0514 Valvetronic, supply voltage: Short circuit to ground. I was told that its possible a bad coil could result in these codes so knowing how to do what the OP is asking would be very helpful!
05-07-2021, 10:33 PM | #5 |
Rep 947
I'm having trouble with it so I dont want to turn it on. I was having misfires and also I think an injector is stuck open.
05-07-2021, 10:34 PM | #6 |
Rep 947
well my plan is to check all coils primary and secondary winding resistance and see if they match. Is that a good plan?
05-08-2021, 08:07 AM | #7 |
Rep 4,876
I'd check for codes first. The DME will trap errors on coils not functioning properly, misfires, etc.
You can just pull out one of the good coils and compare to your suspected bad one if you are looking to validate resistance. I'm just saying I've seen in high voltage devices like this where they test fine on the bench, apply power and they arc inside. |
05-08-2021, 08:24 AM | #8 |
Rep 16,079
If the insulation is breaking down there will be leakage from winding to winding, which would be seen as lower resistance than normal. Misfires can be caused by other factors as well, so if you have misfires doing a resistance test of the coils would help to confirm or rule them out as a potential cause. I haven't come across the exact primary/secondary values, but the primary resistance is listed as less than 600 megohms, with the primary to secondary resistance ratio being 1:80.
05-08-2021, 10:32 AM | #9 | |
Rep 4,876
05-08-2021, 10:49 AM | #10 |
Rep 16,079
I've enough experience with inductors and transformers in audio to know that when you have a winding to winding short due to cooked insulation you can measure the change in both the inductance and resistance, and capacitance too for that matter. However, I agree that trying to find out what the spec resistance for the coils is doesn't matter when you can simply pull and measure all of them and compare the results.
05-08-2021, 12:27 PM | #11 | |
Rep 947
Primary resistance less than 600 mΩ Ratio, primary coil to secondary coil 1:80 but this is still helpful information. So 1:80 would mean im looking for 48 Ohms on the secondary coil? That being said I'll just pull and compare all results. |
05-08-2021, 12:37 PM | #12 |
Rep 947
05-08-2021, 11:18 PM | #13 |
Rep 947
Just an update for everyone I set my ohm meter to 200 ohms and read the readings and got .4 - .5 ohms off of each primary winding so under the 600 milliohm requirement.
I could not however figure out how to get any sort of secondary winding reading. |
