BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Vibration passed 70 mph
      11-20-2019, 01:20 AM   #1
cesarortiz23
cesarortiz23's Avatar
Drives: bmw m2 lci
Hey you guys so I've started to realize a vibration once I pass about 70 75mph
The faster I go the more it vibrates
I balanced all 4 wheels but idk it didn't seem to fix anything
Anyone else has a suggestion or a opinion or anyone else had this problem
Or aiming towards my tires maybe a tire is bad or I have no clue what it can be
A while back I felt this same thing and I got my previous wheels balanced and the vibration went away this time I went to another place to get my tires balanced and the problem didn't go away so I'm maybe thinking they didn't do a good job balancing them or idk
bmw m2
      11-20-2019, 01:26 AM   #2
IK6SPEED
Drives: BMW M3 / AH3
Does it go away at a higher speed?
      11-20-2019, 01:44 AM   #3
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3038
Drives: 340 6MT, 50e, others
Speed limit here is 70. My car is smooth as silk at 70. I don't know beyond 70 because that's above the limit.
F30lolz6798.50
zamboni1130.50
      11-20-2019, 06:30 AM   #4
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
Already discussed here:
https://www.bimmerpost.com/forums/sh...php?p=21887814
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      11-20-2019, 09:12 AM   #5
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
make sure tires are inflated per door well spec
Stage 2 BM3
Originally Posted by GrussGott View Post
Sounds pizzagatey.
      11-20-2019, 09:36 AM   #6
cesarortiz23
Drives: bmw m2 lci
No
bmw m2
      11-20-2019, 09:41 AM   #7
cesarortiz23
Drives: bmw m2 lci
Originally Posted by ooshnoo View Post
They never say what was the problem or if they solved the problem
bmw m2
      11-20-2019, 09:42 AM   #8
cesarortiz23
Drives: bmw m2 lci
Lol
bmw m2
      11-20-2019, 10:31 AM   #9
thompsac25
Stance to make her dance
thompsac25's Avatar
705
Drives: 2022 G80 M3
Do you have wheel spacers on?
INSTAGRAM: thompsac_m3 YouTube: ACCELERATED MOTION
2022 G80 M3 6MT, FEMTO, BM3, KW, AWE, MAD, lots of carbon
      11-20-2019, 10:56 AM   #10
Savageenterprise
Drives: 2008 M3 (E93)
Could be a bent rim. Tires could balance out ok but if you have a nice bend in the wheel you'll feel that at higher speeds
"Hard times create strong men. Strong men create easy times. Easy times create weak men. Weak men create hard times."
      11-20-2019, 11:28 AM   #11
floridaorange
^^ yes that happened to be - took car to "Ben rim" repair shop and they fixed it.
Stage 2 BM3
Sounds pizzagatey.
      11-20-2019, 11:34 AM   #12
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
OEM or aftermarket wheels?
      11-20-2019, 12:19 PM   #13
thompsac25
thompsac25's Avatar
705
Drives: 2022 G80 M3
A lot of wheel spacers can also have feedback in the steering wheel, so that's why I asked if spacers were installed. I know that I get a little bit of vibration at 72mph because of my front spacers.
      11-20-2019, 12:27 PM   #14
MacklinUSOB
Drives: f30 328i 6MT Sport
Had same problem, was told by shop all of my wheels were bent but two were much worse than the others, had those two straitened and it got much smoother. After switching to APEX wheels it has been very smooth since.
BMW wheels are very malleable, shop said they see bends on every car that is driven in the Northeast.
Past: E36 328is & E38 740i
      11-20-2019, 03:32 PM   #15
floridaorange
Additionally the owner manual provides charts based on 100 mph+ driving by tire size the correct psi, for staggered and square.
My car is 35 psi all around / staggered
Stage 2 BM3
Sounds pizzagatey.
      11-20-2019, 11:53 PM   #16
cesarortiz23
Drives: bmw m2 lci
Hmmm yeah I do have spacers your front actually
I think is 10mm spacer
I'm wondering if is that
bmw m2
      11-20-2019, 11:54 PM   #17
cesarortiz23
Drives: bmw m2 lci
Oem replica 437m wheels
I did notice one wheel is bent up front slightly
but when balancing them they never mentioned anything about it effecting anything
bmw m2
      11-21-2019, 04:20 AM   #18
HighlandPete
Drives: BMW F11 535i Touring
Looks like you have identified your issue. Explains why it doesn't go away with higher speeds. Spacers will amplify the error, as you have changed the dynamics with a larger offset. Can you try a couple of different wheels on the front?
Regarding tire shops, there are those who understand a balance and other's who do not!
      11-21-2019, 05:54 AM   #19
Moonbat
Moonbat's Avatar
128
Drives: N/A
I had a bad vibration on a recent road trip. Pulled into a BMW dealership imagining the worst since I had the tires balanced by DT a few days before the trip.
Service tech came back. Was just the tires (and some control arm bushings getting old). Tech said one tire was over 15g off, and they try to get closer to 5g on the balance at that dealership.
Yup some folks just can't consistently do a decent balance.
      11-21-2019, 08:11 AM   #20
thompsac25
thompsac25's Avatar
705
Drives: 2022 G80 M3
That's going to be my guess. And/or in combination with your bent wheel.
I would pull the spacers off first and see if that solves the issue. Process of elimination.
