08-05-2018, 02:54 AM | #1 |
Rep 22
2015 320 GT light system failure
Hi all
My gt has got a dash warning light system failure Reverse light is off, back camera off, unable to open boot, rear windows all not working Booked in for a service, wondering what's the cause, fuse issues? Thanks |
08-06-2018, 07:56 PM | #3 |
Rep 22
thanks for the info, rem sits in boot I assume, interesting to see if they able to crawl in and open it up since the boot is not active, possible to reset the rem via programing? just need a bit more information so prepare to go to dealer to avoid any confusion. thanks
08-06-2018, 08:57 PM | #5 |
Rep 16,079
They would only crawl in if their diagnostics testing revealed that the REM was at fault. A manual hatch release is required by law in the States. Your manual will tell you if you have one. Mine even glows in the dark.
08-14-2018, 11:39 PM | #6 |
Rep 22
went to dealer today, REM fault, clear faults all good, when technician try to upgrade software found gear selector too old for software upgrade so leave as it is.
Is this normal for a software upgrade?Can't imagine on a car which is only 3 years old Cheers all |
