12-02-2018, 11:36 AM | #24 | |
Rep 206
Hi,
Sorry - I havent been here for a while - there is something called work that takes up all my spare time.... Anyhow - did you find a solution? //Chris Quote:
12-21-2018, 10:07 AM | #25 |
Rep 4
The "plug and play" feature only works on cars that already have an installed amp (HiFi or HK systems). For the base audio you will have to do heavy wiring from the HU to trunk, so Itīs probably not worth to buy a $1.000 amp, just because they are "Plug and Play".
The upside is that, if you are up for the wiring, you can buy a much cheaper (and potentially more powerful) amp, like a Rockford Fosgate or a JL and a separate and more efficient DSP. The other option is simply replacing the speakers with Bavsound Stage one for the Base Audio, that will improve your sound a lot, but still it would be working without an amp, which means it won't be as loud as it could be. |
12-21-2018, 11:11 AM | #26 |
Rep 16,054
base stereo, base stereo upgrade |
