BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > A definitive answer on headlight brightness LED vs Xenon
      03-02-2016, 01:54 AM   #23
Tengocity
Tengocity's Avatar
Scotland
8566
I'll get my 330e with adaptive LEDs in a few months whilst still having my 335d with adaptive xenons, so will be able to side by side tests. How exciting!
      03-02-2016, 02:41 AM   #24
Mr NSB
Drives: 420d M-Sport
Originally Posted by xenon View Post
The adaptive have the halos and eyebrows in DRL mode whereas the non-adaptive just have four lights?
The halogens have 4 LED DRL's and I believe the LED and LED adaptive have the same halo's.
gfa325.50
      03-02-2016, 02:46 AM   #25
RobUK
RobUK's Avatar
Drives: 340i MPPSK
Am I missing something obvious here? With the pre-LCI Xenons I had TWO headlights, one either side - the 'inner' lights were just fakes - somewhere for BMW to put the second halo ring. On the LCI adaptive LEDs I now have FOUR headlights because the inner lights are actually functioning headlights as well. So even if the individual LED headlights may have a slightly lower LM rating (and a correspondingly lower LUX) compared with individual Xenon headlights, I now have double the amount of them
Personally I like the LEDs - they seem to give a much more even spread and the distance they throw down the road on main beam looks pretty good to me. The one thing I would agree with is that on dipped beam they do sometimes feel a little 'low'.
Life is a state of mind
      03-02-2016, 02:57 AM   #26
NISFAN
NISFAN's Avatar
Drives: BMW M2
Light is very difficult to compare. As said, beam focus and penetration is more important than 'brightness' or light output.
I'm not sure if LED technology has improved, I'm sure it has, but an M6 F13 that I had with LED lights were not good. High beam was good in that it lit up the near world like a Castle Bravo, but didn't have good penetration at distance, which is what you want from a good headlight. Probably why they feel the need to supplement LED with Laser for long distance?
Regarding Lumens and the chart posted earlier, you need to take one thing into consideration, and that is that LED's flash, whereas Xenon pulse. So LED's go from full light output to zero light output repeatedly. Whereas Xenon produce waves of continuous light. That has an effect on measuring equipment, as it usually measures average light output. The human eye sees the light at it's peak value apparently and doesn't detect the flashing on off situation.
      03-02-2016, 03:02 AM   #27
teaston
Drives: X3 M40d
No! The non adaptive have exactly the same new style DRL.
You're thinking of the halogens!
      03-02-2016, 03:07 AM   #28
teaston
Drives: X3 M40d
I think you might have hit the nail on the head there! Two lights in each headlight unit must be what makes the LED's brighter overall!
Re dipped beam too low, mine were also far too low from factory so I adjusted them up myself, just need a hex bit with preferably a cordless drill. They're bloody amazing now!
      03-02-2016, 03:08 AM   #29
xenon
xenon's Avatar
England
1394
Drives: 2021 G21 330i M-Sport
Ah, OK. I didn't even think you could get halogens any more: I thought - like the 1 series - basic LEDs were now the entry level.
What a load of shite, halogens in this day and age on a premium brand.
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      03-02-2016, 03:13 AM   #30
teaston
Drives: X3 M40d
LED's are only standard on M Sports, on both 3 & 1 series.
      03-02-2016, 03:17 AM   #31
xenon
xenon's Avatar
England
1394
I thought on the 1-series it was across the range. What you say makes more sense.
Ian
      03-02-2016, 03:20 AM   #32
Tengocity
Tengocity's Avatar
Scotland
8566
xenon
When will you upgrade your name to LED or even better... LASER?!
      03-02-2016, 03:26 AM   #33
teaston
Drives: X3 M40d
No, definitely just M Sport
      03-02-2016, 03:37 AM   #34
xenon
xenon's Avatar
England
1394
Originally Posted by Tengocity View Post
xenon
When I get a car so-equipped!!
Ian
      03-02-2016, 04:01 AM   #35
Rich9600
Rich9600's Avatar
Drives: i4 M50
Our mini with the Cornering LED Lights uses additional LEDs to light up round corners. This could be the same on the new adaptive units and account for the max brightness being higher on the adaptive units than the standard ones.
Xenons use shutters to move the light.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31)
      03-02-2016, 05:07 AM   #36
B33M3R
B33M3R's Avatar
Drives: F31 335d XD M Sport
I'm awaiting delivery of my F31 335d and haven't specc'd the adaptive option this time around, so standard LEDs for me!
I've had the E90 Xenon adaptives (left & right sweeping) and lastly the LCI Xenon adaptives (full split beam array etc) on the F10. Both were good but the F10 was massive leap in tech.
I was anticipating a bit of a step back on the new car, but reading this I'm thinking even if I'd gone for the adaptives it still may have been the case.
      03-02-2016, 06:48 AM   #37
Daftasabrush
Fool
Daftasabrush's Avatar
England
1857
Drives: F31 340i
Yes you're missing something, the rating is per headlamp unit not per individual lighting section (LED/xenon bulb). The two lights on the LCI aren't as bright in total as the single xenon per side
      03-02-2016, 08:00 AM   #38
JOHNBMWM5
JOHNBMWM5's Avatar
Drives: 2022 LCI Marina Bay Blue/ Smok
I can only say the Adaptive LED's on my LCI M3 are very good all round and when using HBA brilliant , I hope the 435D XDrive M Sport comes with the same system.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      03-02-2016, 10:21 AM   #39
Rukka
Rukka's Avatar
2647
Drives: M4 Comp
I think you might be a bit disappointed there John. IMHO the xenon adaptive on the 435d are pants. Even now I've had mine set up properly I still don't think they light up enough of the road. When accelerating into darkness, the HBA is just not quick enough to turn on and light up the road ahead which I think is near on bloody dangerous at best.
I won't be speccing adaptive again based on my experiences
Rukka
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87
      03-02-2016, 11:19 AM   #40
JOHNBMWM5
JOHNBMWM5's Avatar
Rukka
But are they LED's, that's what I have gone for?.
      03-02-2016, 11:50 AM   #41
Englishbloke
Englishbloke's Avatar
Drives: F30 335d TB
Hold on! I thought this was supposed to be definitive?
Ordered adaptive LED now so will see how they compare to my xenon adaptive soon.
      03-02-2016, 12:11 PM   #42
Tengocity
Tengocity's Avatar
Scotland
8566
About as definitive as the debate over whether a 340i was faster than a 335d or not...
PFC6.00
gfa325.50
      03-02-2016, 12:28 PM   #43
JOHNBMWM5
JOHNBMWM5's Avatar
It is not.
      03-02-2016, 12:36 PM   #44
teaston
Drives: X3 M40d
LED's are brighter than xenons, & that is definitive!
I don't know the reason, maybe because there's two lights in each headlamp, maybe because reflectors are better than projectors, but there is no doubt that they are brighter!
