12-30-2018, 10:26 AM | #14104 |
Rep 40,752
PM sent.
12-30-2018, 06:47 PM | #14107 | |
Rep 40,752
12-31-2018, 10:58 AM | #14109 | |
Rep 40,752
Scroll up and read the Post immediately above yours.
01-01-2019, 01:28 AM | #14110 |
Rep 83
Hi Shawn - I just picked up a new 2019 440i Gran Coupe. I have the E-Sys software but when I tried to use it, I encountered errors. I assume I need the latest files - can you send me the link? Or does the expiration of the the token on 12/30/2018 causing my problem?
01-01-2019, 06:36 AM | #14111 | |
Rep 40,752
01-01-2019, 12:36 PM | #14112 |
Rep 83
When I use E-Sys Launcher (2.5 2.100) I get stuck on the pop up box for EST software token. I change path to C:\Data and enter a generic pin, then I get confirmation of a successful software token when I click to "Generate Token" but then the pop up box keeps coming back.
If I launch E-Sys directly (without the Launcher), I am able to connect but unable to read coding data - "file for cafd_00000794-018_070_003 not found" I haven't used this E-sys since 2016 when I coded my '16 340 so maybe it's old/expired...? |
01-01-2019, 01:30 PM | #14113 | |
Rep 40,752
01-01-2019, 01:48 PM | #14114 |
Rep 83
01-06-2019, 03:56 AM | #14116 |
Rep 210
Hi Shawn, thank you for being so helpful with all of us here all this time.
I am installing now MSport brakes on my F36 and i need to code them. As my Esys 2.8.2.155 launcher no longer works due to token, let us know please as soon as a solution is found for 2019 - Esys Launcher Premium (other than the EsysX and the Esys Pro) Thank you
Current:
M4 F82 2016 DCT Austin Yellow 530d Msport G30 2017 Bluestone Metallic Past: F36 430d Gran Coupe M-Sport Alpine White - DMS Remap, E92 320d Crismson Red M-Sport, R56 Mini Cooper S. Mazda RX8 Type-S Japan Import, E46 320ci LCI Convertible M-Sport Silver Grey |
01-06-2019, 09:26 AM | #14117 | |
Rep 40,752
Short of that, there is this: E-Sys Launcher Premium Rearm 1.7.0: Https://f30.bimmerpost.com/forums/sh...62&postcount=1 As for your MSport Brakes though, you can VO Code MSport brakes (HO-Wort = SPBR), so you do not even need E-Sys Launcher, which is needed only for FDL Coding.
01-06-2019, 06:36 PM | #14119 |
Rep 2
01-06-2019, 06:52 PM | #14120 | |
Rep 40,752
You can use old F30 one if you want: https://f30.bimmerpost.com/forums/sh....php?t=1020138
01-07-2019, 06:37 PM | #14121 | |
Rep 2
01-07-2019, 08:08 PM | #14122 |
Rep 40,752
Nothing has "All", not even old Cheat Sheet.
01-09-2019, 12:29 PM | #14123 | |
Rep 2
to do FDL coding, what is the solution now ? I need to code FEM_BODY for led replacement for a 2013 F30 |
01-09-2019, 03:00 PM | #14124 | |
Rep 40,752
Options are: ESysX (http://esysx.com - Info @ esysx .com (No Spaces)) E-Sys Plus (http://www.bmwai.com/Item/ESysPlus Launcher PRO 3.x (http://tokenmaster.blogspot.com/2018...r-pro-320.html - fxx token master @ gmail .com (No Spaces) - Response times vary widely from hours to months to no never. Hacked E-Sys Launcher PRO 2.x (Search eBay) Hacked E-Sys Launcher PREMIUM with Rearm Script (Https://f30.bimmerpost.com/forums/sh...62&postcount=1)
