11-25-2023, 05:24 PM | #1 |
Rep 1,425
Reduce Coilover Binding - Need Input
I've been dailying my F31 xDrive ~50,000 miles on lowered KW DDC coilovers. Overall, I like the suspension. However, even after raising the height, coilover binding is very common for the front. I've worked with the best shop in the region, who tried multiple adjustments. Ultimately, they ended up wrapping the front coils with a rubber hose material (maybe 30% coverage of the entire coils). This worked very well, eliminating nearly all of the noise/harshness, without any significant loss of function. However, after so many thousand miles, they eventually start to work loose and are a pain to remold to the coils. I've zip tied them, but they eventually fail.
So, I'm curious if anyone has a solution or similar product? Here is an old thread where a user DIY'd a simple solution: https://www.e90post.com/forums/showthread.php?t=609774 I appreciate any feedback.
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
11-26-2023, 12:16 PM | #3 |
Rep 125
Drives: 2018 BMW 330iX Sedan
If your front springs are #2039, they are too soft for the car. I had a similar issue with my KW Comforts, the correct springs are #2041 which are suitable for gross front axle load of between 1001 to 1090 kg.
Detailed in this thread from #18: https://f30.bimmerpost.com/forums/sh....php?t=1799518 |
eleven11371.50 |
11-26-2023, 03:28 PM | #4 | |
Rep 1,425
2017 X5M - Current
11-26-2023, 04:29 PM | #5 |
Rep 125
Yes, the part # is printed on the springs. You can also find the info on the installation instructions which came with your kit. PDF can be downloaded from https://www.kwsuspensions.com/products.html
Looking at the DDC kit for F31 X-Drive, I can indeed see it shows 2039 springs. Note it also shows the max front axle load as 1000kg. The axle load information for my car is at the bottom of the B pillar. My front load is 1020 kg. I'm sure yours will be the same or higher. |
eleven11371.50 |
11-26-2023, 04:56 PM | #6 | |
Rep 1,425
Again, very interesting. I'm curious why KW went with the 2039 (pending my verification)? On quick search, it doesn't look like I can simply order the 2041 springs directly, so a phone call to KW is in order. Correct me if I'm wrong (noting your situation was remedied by contacting KW). With the age/miles, I'm not expecting this to be covered by any warranty.
2017 X5M - Current
11-26-2023, 05:11 PM | #7 |
Rep 125
Once I pointed out my front axle load was higher than specified, they admitted "there was a mistake on this kit in our u.s website & u.s app guides"
I would try to get them to replaced under warranty, I believe it is lifetime? Otherwise, they are relatively reasonable at $90 each plus shipping. They're happy to sell individual parts. You might also be interested in this vid by FaRKle!, he uses even stiffer springs on his F31 (#2025 from the M4 convertible kit). With this route, the rear springs need to be stiffer as well. |
eleven11371.50 |
