BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 msport no voltage at coolant pump connector
      02-10-2023, 02:07 PM   #1
F30_eli
Drives: BMW 320i Msport F30
My coolant pump stopped working after I had my turbo replaced. I suspect that the mechanic did not run the bleed procedure after changing the coolant or maybe damaged the wiring.
Now my car over heats and is throwing error code CD9010 LIN message electric water pump missing. I checked the voltage between pin 1 and pin 4 of the electrical harness connector to the coolant pump and there was no voltage. I also checked all the fuses and they all seemed fine. So now I am assuming that this is an electrical issue as opposed to a bad water pump.
Does anyone a wiring diagram for the harness in the engine compartment? I would like to see where the coolant pump gets it 12V supply from?
Also does anyone know which fuse number in the engine compartment is for the coolant pump?
      02-10-2023, 07:19 PM   #2
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
https://f30.bimmerpost.com/forums/sh....php?t=1085260
Hopefully this will help ya
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      02-12-2023, 03:24 AM   #3
F30_eli
F32Fleet
Thanks for the diagram, I already had that one.
I managed to trace the 12V red wire from the coolant pump all the way to the power distribution box (ISM- interacted supply module), where it made a connection via a connector.
The 12V wire at the water pump end and at the ISM connector end were tested with a multimeter for continuity and I verified that the wire was not damaged. This meant that the problem was most likely with the ISM module.
I opened up the ISM module with the help from this video:
After opening it up I tested the 30A fuse and was able to verify that it was blown.
I will get a replacement fuse and test the coolant pump. Hopefully the pump is still functional.
F32Fleet3789.50
      02-12-2023, 05:33 PM   #4
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
F32Fleet
Nice work!
      05-24-2024, 03:05 AM   #5
Sato
Drives: M135i
... I checked the voltage between pin 1 and pin 4 of the electrical harness connector to the coolant pump and there was no voltage...
Hi, I'm dealing with something similar, coolant pump is "missing" after engine swap/reassembly. I'm trying to solve if this is a wiring, ground, fuse or coolant pump (unlikely). When did you check this voltage, just ignition on? Or when engine was running?
