01-24-2021, 12:30 AM | #1 |
Rep 2
Difference Between 440i xdrive coupe and gran coupe 0-60?
I've been looking for this everywhere but can't find an answer. What's the difference between the 0-60 time of a 440i xdrive GC and a 440i xdrive coupe? I'm looking into buying one of them.
01-24-2021, 01:32 AM | #2 |
Rep 883
Likely less than .1 sec. Based on the fact the N55 variants had the same claimed 0-62 times.
The coupe’s CG sits 10mm lower, though both cars share the same length, width, wheelbase and track. The extended GC roofline sits 12mm taller (past the B-pillar). The GC has marginally better weight distribution, but carries ~145lbs addtl weight versus the coupe. |
01-24-2021, 02:13 AM | #3 |
Rep 10
I did the research some time ago and it is after the BMW catalog 0.1 seconds. Same difference as you compare with and w/o xDrive.
I would not decide the kind of car depending on that times and if, I would chose the Supra as it is with 4.5 seconds even 0.5 faster. |
01-24-2021, 12:02 PM | #4 | |
Rep 3,877
440, 440i, 440i gc, gran coupe |
