BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > seats electric bmw F30
      01-22-2020, 04:37 PM   #23
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by Louis95 View Post
Wondering if anyone could help me.....
I've got a 2017 LCI F30 with heated seats and electrical lumbar support but manual adjustment.
I've bought a 2015 m3 F80 interior but there is 4 extra pins on the connector block of the new seats.
Does anyone have any know how to wire this into the main harness.
Do I need to swap airbags/ seat tensioner etc. From the old seats onto the new seats?
Is there any coding required ?
Any help/advice will be greatly appreciated...
      01-22-2020, 04:46 PM   #24
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by sylver65 View Post
IT NOT view the pics.
i have this problem. MY f31 5/2015 basic, now it's have HU PRO ID4 and now installing the SEAT HEATING SPORT. but, now not working the MEMORY seat and HEATING.
I HAVE PUT INSIDE THE A173*8b PIN 51 and 52 the pin 5 and 6 from X14*1B K-CAN-H and L.
do you have an idea about WHY it not working?
thanks in advanced for responding
did you code your bmw to add the heated seat option ?
      01-22-2020, 04:53 PM   #25
Louis95
Drives: 335D & 535D
Thanks for your response David and sending me the diagram
I will show this to my mechanic tomorrow and hopefully he will have an idea of what he has to do now
      01-23-2020, 12:55 AM   #26
sylver65
Drives: 320d xdrive
Control on NEWTIS.info the New Wiring
https://www.newtis.info/tisv2/a/en/f...14-1b/Jlg9wqtW
      01-23-2020, 01:27 AM   #27
sylver65
Drives: 320d xdrive
Yes , 459 in VO
      01-23-2020, 02:06 AM   #28
sylver65
Drives: 320d xdrive
Do you Can say me the code ?
      01-23-2020, 10:54 AM   #29
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Yes , 459 in VO
S459A=Réglage électrique des sièges avec mémoire
S494A=Sièges chauffant
Apres l'ajout 494 il faut coder les module suivant:
VO REM =(module arrière)
VO FEMbody=(module avant)
VO IHKA=(console de la clim)
VO SM=(module du siège)
      01-23-2020, 11:42 PM   #30
sylver65
Drives: 320d xdrive
Après avoir ajouté 494, ne pas afficher SM
      01-23-2020, 11:44 PM   #31
sylver65
Drives: 320d xdrive
avec ista, le SMFA est ROUGE
In Esys it’s ghost
      01-24-2020, 01:58 AM   #32
david51
david51's Avatar
France
538
Drives: bmw M3 F80
In Esys it’s ghost
MP
      01-24-2020, 10:08 AM   #33
sylver65
Drives: 320d xdrive
MP
vous envoyer un e-mail
      01-25-2020, 12:46 PM   #34
sylver65
Drives: 320d xdrive
now i have undestud that my SEATS are make for LCI model, and my is PRE LCI.
so, the SMFA is impossibile to communicate with FEM.
      01-25-2020, 12:55 PM   #35
david51
david51's Avatar
France
538
Drives: bmw M3 F80
I installed M4 lci seats on my bmw M235i from 2014 and it worked
      01-29-2020, 05:21 AM   #36
sylver65
Drives: 320d xdrive
Using ISTA the SMFA is RED and with ESYS isn’t possibile to CODE, because it’s Not visible. I think that this SMFA is Passive mode, in Pre LCI it want ACTIVE MODE.
      02-02-2020, 10:03 AM   #37
pcking
pcking's Avatar
Drives: 2014 BMW 320i xDrive
I am interested to learn more about the seat interchange options for the F30.
Mine's got 200K now and the drivers seat is starting to show it, the door panels have some blems, the passenger seat has a small gouge, etc.
I have seen a few interesting options on EBay but would rather know I can make it all work before I invest >$1500 for an interior upgrade.
Mods: Stoptech Sport Brakes, Injen Intake, BMS Catch Can, AFE Downpipe & 328i Sport Exhaust, Evolution Raceworks Chargepipes, VRSF intercooler, AFE tBody Spacer, MHI Big Turbo, BM3 Stage 2 93 Octane tune, Bilstein B8 Sport+ dampers, Dinan Perf Spring Set & Camber Plates
      02-10-2020, 05:53 PM   #38
david51
david51's Avatar
France
538
Drives: bmw M3 F80
if you install new seats you must recover the 2 airbags and the module under the original driver seat and install them on your new seats
pcking87.50
      02-11-2020, 06:05 PM   #39
pcking
pcking's Avatar
Do you know if those fit all the various seat options from the higher models like 330, 335, or M3?
What other cars will work? Heard the 4 series uses same interior parts...
      02-11-2020, 06:14 PM   #40
david51
david51's Avatar
France
538
Drives: bmw M3 F80
bmw F20/21/22/30/31/32/34/80/82
pcking87.50
      02-13-2020, 11:38 AM   #41
sylver65
Drives: 320d xdrive
david51 i must undestand if my car have K-CAN2 o K-CAN because it not working heathing and Memory Seat.
My vin is K539160 ,
Do you can undenstand whole K-can working?
the seat come from https://www.mdecoder.com/decode/k390201
      02-14-2020, 07:45 PM   #42
janmanBMW
Drives: 2017 BMW F31 320d M Sport
Hi there, I'm thinking of swapping heated seats in my BMW F31 2016 Sport (post LCI) to my current car BMW F31 2017 M Sport (non heated seats). I own both cars and I can play around with them as long as i need. Would i get any issues with this swap? I will also move the radio unit across, across. Any suggestions if any coding is required? Anything i should be aware of? Great thanks in advance!
      02-16-2020, 05:37 PM   #43
david51
david51's Avatar
France
538
Drives: bmw M3 F80
you will need to add the heated seat option by coding and wiring for the power supply
add the air conditioning console with the heated seat buttons
      02-17-2020, 12:48 PM   #44
sylver65
Drives: 320d xdrive
david51 contact to me with email, so we can to do with Esys and resolve my problem. Thank’s
