01-28-2022, 10:09 AM | #67 |
Rep 30
Interesting. Did you manage to complete the retrofit eventually? How did it work out?
01-29-2022, 10:34 AM | #68 | |
Rep 1,142
01-30-2022, 02:15 AM | #69 | ||
Rep 18
02-09-2022, 06:32 AM | #71 |
Rep 3
Weird.
My szl has an empty (no pins) in the hole where you would plug in the button wire. But I do have a rain sensor and the car is facelifted. I can't even make out which szl to buy... It's just stupid getting one with automatic high beams if my car doesn't have that option. For example 9351143 szl can have all options but no rain sensor, or no options and only rain senzor. Im stumped. Also good luck finding one. But if there are they're 300$ |
02-12-2022, 05:26 AM | #72 | |
Rep 18
02-15-2022, 10:18 AM | #73 |
Rep 740
If anyone's interested, I have the SZL and sport line heated steering wheel (with paddleshifter, vibrating motor, etc) for sale. PM me!
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
08-15-2022, 08:02 PM | #75 | |
Rep 30
Guys, I'm about to attempt this retrofit in a couple weeks. Just a bit confused on a few things after reading through other people's replies to this thread.
Can someone please confirm I'm understanding Roxxor's instructions (below) correctly: Parts required if vehicle does not have Driving Assistant options = Steering Column Switch Cluster? I'm glad I found this thread but just wish I found it before I decided to do the retrofit. Based on a few replies, it seems like this can be a tricky mod. I already have the lower trim panel w/button and the new steering wheel is on its way. Just need to confirm if I will need this additional part. Should I wait to get the current, non-heated, steering wheel off before I order the Steering Column Switch Cluster? EDIT: This is the part I'm considering if it ends up being required Quote:
Last edited by phat_joe; 08-15-2022 at 08:29 PM.. Reason: added link for part I'm considering |
08-21-2022, 10:08 AM | #76 |
Rep 30
Did you ever figure this out?
2000 323ci | 2015 328i xDrive
10-20-2022, 01:53 PM | #77 |
Rep 1
I am a bit confused. I went to realoem to try to figure out which steering column switch cluster I need. I see there are 6 different part numbers listed there, but they all have the same descriptions, for vehicles with steering wheel heater, and rain sensor, and high beam assistant, and lane departure warning, and lane change warning, and driving assistant. My car only has the rain sensor currently, but according to this list there isnt a version without all of the options. Does this indicate that the steering column switch in my car is already a version that supports the heated steering wheel and thus makes it easier to retrofit a heated wheel and switch into my car? I have the m-sport wheel already.
11-08-2022, 10:30 AM | #78 | |
Rep 161
Per your instructions, I should change my steering wheel cluster if I dont have lane assist options. I only have the rain sensor. So in the listing here, I only see PN that include Lane-Change... which one do I pick? Last edited by mazen222; 11-08-2022 at 10:57 AM.. |
11-08-2022, 04:04 PM | #79 |
Rep 152
Buy the one that has the options for your car plus the heated wheel.
1140, 1139, 1142, 1145 - no heated wheels. Dont buy that those. 1141 - heated wheel, no rain sensor, no HBA. 1143 - heated wheel, no HBA. 1144 - heated wheel, no rain sensor. 1146 - supports all the options so get that one if you don't want to worry about it. Basically, look at the second column. Find the ones that have the options your car has in addition to S248a. I got the 1143 SZL because my car doesn't have HBA and its was cheaper than 1146. Last edited by pdxpeter; 11-08-2022 at 04:09 PM.. |
mazen22227.50 |
12-23-2022, 11:01 AM | #80 |
Rep 1
Can i use an older cluster version?
Hi,
I have an F31 and as far as i understand I would need to use a 61319351151, which is really hard to find. Do you think that the older 61319242285 work instead? My current cluster is 61319351148. Also mine is right hand drive but parts should be the same right? Thanks |
08-08-2023, 01:57 PM | #81 |
Rep 33
Hello, I've f30 lci 2018 with kafas2 and hba. Do I need extra wires or not? See attached picture...
Update: yes it will work. Last edited by labanauskas; 08-09-2023 at 01:55 AM.. |
08-20-2023, 06:54 PM | #82 |
Rep 207
Drives: 2012 335i Sport
Having a hard time figuring out the part number for my SZL, I don’t have lane keep assist or any of those, just high beam assist and auto wipers, I do have the power wires ran to the SZL and I have pins on the plug for the heated wheel button, does that mean mine would be comparable? 2012 335i SportLine with paddle shifters
08-21-2023, 11:11 AM | #83 |
Rep 525
751 is the same like 1145 so no heating
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
thatgarrett787.50 |
10-21-2023, 07:14 PM | #84 |
Rep 1,582
I have a stock base 328i. I am in the process of doing a 6-pin basic to 5-pin high mirror upgrade and at the same time lane change warning. I do not need steering wheel heating, but had to get a steering wheel ECU module that does vibrator motor. Apparently, my car does not currently have a steering wheel ECU module, as there are no power (Pin 9) and ground pin (Pin 11) on the A83/1B connector (entire left row is missing). Only the right row is there which is filled up by the six airbag wires.
I am not about the buy a new clock-spring (steering column switch cluster) so will just run the power and (FEM) ground wire directly to the new steering wheel ECU module (Pin 3 and 6), bypassing the connector. Did anyone run into this issue? I would have thought that BMW has at least the pins there. But seems like I would need an entire different part number clock-spring to have those pins there. Or there are a lot more things going on inside the clock-spring's circuit board? Sample picture from the internet: Actual switch have:
10-22-2023, 01:09 PM | #85 |
Rep 1,582
Also, do not have the "hidden" driver assist switch cluster harness behind the headlight switch. So I need to run the wires from the FEM. What a bone-basic model I got
10-25-2023, 12:02 AM | #86 |
Rep 14
10-25-2023, 12:57 AM | #87 | |
Rep 1,582
But I ended up buying a clock spring with "1143" part number for $45 shipped on Ebay. Has all options except High Beam assist. It's still being delivered to me. Once it's here, I will see what path can be done for the wire. That is if I can get to it without taking apart so the ribbon cable will not get damaged. If you need the full option clock spring 61319351154, Ebay has a brand new "old stock" for $110...very hard to find this, and not for this low price and not brand new! (just double check the part number and confirm): https://www.ebay.com/itm/362905511384 But I saw some on the Ebay.UK website where these items are generally cheaper.
10-25-2023, 06:09 AM | #88 |
Rep 14
thx for the reply but are RHD and LHD szl's interchangeable? i didnt think so.
and i saw the one on ebay, but unfortunatly the seller wont ship outside of the us. (im located in europe, belgium.) i was also thinking of buying one without the highbeamassist as they are much cheaper, i have been looking up if there the pcb's inside of the szl's are different from eachoter and i dont think so as the szl only works as a communication between modules. so i will try to swap the stalk of my current szl and solder it to the new one without the HBA or rainsensor depends on wich i would buy. but just to be 100perfect sure that bypassing the szl isnt possible |
