07-28-2018, 08:00 AM | #45 |
Rep 3
07-28-2018, 08:22 AM | #46 | |
Rep 40,785
Load the edited SVT in VCM - Go to File and Select SVT Target - load the above edited file, Go to Master and Write SVT Target. Go back to TAL Cal and Read SVT again and BKOMBI should be disappear. Read ECU and you should see KOMBI appear in RED.
kop7180.00 |
07-30-2018, 11:56 AM | #47 | |
Rep 3
07-30-2018, 12:01 PM | #48 |
Rep 40,785
08-23-2018, 05:19 AM | #49 |
Rep 277
A question, im doing a 6wa to 6wb retrofit.
I did install coded VO and i have the Dkobi in my list of modules, but when i click on detect cafd i get error. Its this one Failed to get CAFs from SWE "swfl_00003e5a-004_000_002" [C111] KIS error: Die technische Einheit 00003E5A konnte in der KIS-Wissensbasis nicht gefunden werden [1263] Do you know what the problem is? Thanks |
08-23-2018, 06:51 AM | #50 | |
Rep 2,302
Your psdzdata are up to date? |
08-23-2018, 06:56 AM | #51 | |
Rep 40,785
08-23-2018, 07:04 AM | #52 |
Rep 277
08-23-2018, 07:08 AM | #53 |
Rep 40,785
You need to update PSdZData for sure.
08-23-2018, 07:15 AM | #55 |
Rep 40,785
I provided in PM I just replied to.
08-24-2018, 06:11 AM | #56 |
Rep 277
What do you have to code to get this option back on your nbt settings? Cause i don't have it any more, i lost it after 6wb retrofit. My nbt has as first line control diplay.
So what do i have to code to get the instr. cluster display |
08-24-2018, 08:47 AM | #57 |
Rep 2,302
Did you also VO code the HU_NBT?
08-24-2018, 09:38 AM | #58 |
Rep 277
08-24-2018, 09:54 AM | #59 |
Rep 277
08-24-2018, 12:44 PM | #60 | |
Rep 2,302
I just searched all codings of my NBT Evo and didn't find any values for that. I also think the button has to be always there, no matter of 6WA or 6WB. But i still have an idea. Do you have the ncd/cafd tool? If not, you can download it here: https://mega.co.nz/#F!HAdwmCzJ!kTdsZFT8dZliEkRkZY5JIA With this tool you can compare 2 cafd files. So you can compare the old cafd file before the 6WB coding against the current file. The tool will show you the differences between the files and you might find the special value for this menu button. |
08-24-2018, 01:38 PM | #61 | |
Rep 277
Can you put a copie of your cafd nbt evo? Probablly will be some differance but maybe ill find it there, or i can give you a copie of mine and you can check with yours, cause ive never used that program Last edited by deneyer; 08-24-2018 at 01:48 PM.. |
08-24-2018, 01:51 PM | #62 | |
Rep 2,302
But there's no need to reinstall the old 6WA. Only change your VO from 6WB to 6WA and then code the HU_NBT. Then have a look if the menu button is there. If yes then save the cafd somewhere on a safe place (for example a copy on the desktop). After that change back to 6WB and code the HU_NBT. Now you have the cafd with 6WA (copy on desktop) and another cafd with 6WB codings (C: Data/CAF...) which you can compare. Here my cafd with NBT Evo and 6WB https://mega.nz/#!hKYQ3CKb!A8GBkDlIv...xR3EfgdXQhQ7E4 |
08-24-2018, 01:55 PM | #63 | |
Rep 277
08-24-2018, 02:01 PM | #64 |
Rep 2,302
08-24-2018, 02:10 PM | #65 | |
Rep 277
Dont know what you are saying here but when i did retrofit i deleted 6wa vo code 6wb, then added cafd file for D_KOMBI and after that i just clicked right button on nbt and on D_kombi and hit code. I didn't change my nbt so i don't have to inject a new CAFD file. |
08-24-2018, 02:17 PM | #66 | |
Rep 2,302
Then you only have to change vo to 6WA now and code NBT. Now the menu button should be there again. Then read the coding data and save it to a safe place (Desktop). Then all backwards to 6WB and code NBT and read coding data again. Now you have 2 files to compare. Last edited by atzebmw; 08-24-2018 at 02:23 PM.. |
