08-24-2018, 02:20 PM | #67 |
Rep 277
08-24-2018, 02:25 PM | #68 |
Rep 2,302
I just changed my last posting.
08-25-2018, 04:16 PM | #69 |
Rep 277
I checked everything and there are 2 things different.
- Kombi_Cic was set to mid with 6wa and when coded 6wb it was set to low. I changed it to High - setting_info_display was set to aktiv in 6wa and to nicht aktiv on 6wb so i set it back to aktiv Now i got the menu back but its called info display and not instrument cluster display. Alsoi checked the navi option but i have noting on the cluster. With my 6wa i had the arrow on the cluster but now i get nothing. So what do you have to code for this? And in D_kombi Navi nbt_enable is set on nbt_aanzeige Annyone know what the problem is? |
08-25-2018, 04:33 PM | #70 |
Rep 2,302
In my car it's also called "Info display".
Do you have a head up display? Navi_NBT is also set to "nbt_anzeige" for my car. Edit: https://f30.bimmerpost.com/forums/sh...8&postcount=47 maybe "kein_NBT" for your car the right setting? Last edited by atzebmw; 08-25-2018 at 04:44 PM.. |
08-25-2018, 05:01 PM | #71 | |
Rep 277
08-06-2020, 06:19 AM | #73 | |
Rep 646
Sorry to bother you but I’m really new in this coding. I purchased and got a 6WB coded in my F36 and everything works except the navigation in the middle. I then tried to log in and when loading the code from the car, it gives error BKOMBI connection. Shouldn’t BKOMBI have been swapped for DKOMBI? Naturally I can’t find your codes because of the “missing” DKOMBI menu and BKOMBI connection issue. As mentioned all other features work and I have the Instrument selection menu in iDrive where I can select what to view in instrument cluster. The navigation is there as well as an option, it just doesn’t show
| 2021 Tesla Model 3 |
08-06-2020, 07:40 AM | #74 | |
Rep 40,789
10-21-2020, 06:03 PM | #75 |
Rep 50
Almost there 6WB
@shawnsheridan Shawn, you are the hugest help, thanks so much. Some of these threads are so long, but I promise I've tried to search them all first before this post. So I just installed a new 6WB into my F30 with HU_BASIC. I had to install a 3 ended MOST cable. I could only get BKOMBI to show up until I found your instructions on editing the SVT. I now have DKOMBI showing up. I was using 3.28.1 and could not get 'Detect CAF from SWE' to highlight. I found a post where you suggested 3.27.1. Using that I now get Detect CAF to highlight but now when I select it I get a PSdZ error "Failed to get CAFs for SWE "swfl_00003e5a-007_003_005" (C1111).
I'm guessing I don't have up to date PSdZ data? Not sure where to get it or put it (I now have both 3.28.1 and 3.27.1 installed). Ughh. The only thing I'm not sure I've done is I remember you saying you set the VO Production date to 1211?? Not sure exactly how or where to set that. Last edited by cjsansom; 10-21-2020 at 08:30 PM.. |
10-21-2020, 08:28 PM | #76 | |
Rep 40,789
Injecting CAFD (Detect CAF for SWE) and Flashing ECU's with >= v.4.17.20 PSdZData requires using newer E-Sys 3.30.0 or higher. It's FA Date (Zeitkriterium) not FSC Date. PM sent.
10-21-2020, 10:47 PM | #77 |
Rep 50
10-21-2020, 10:53 PM | #78 |
Rep 40,789
If FA is correct for 6WB including Build Date, then you will need to flash it.
10-21-2020, 11:10 PM | #80 |
Rep 40,789
10-23-2020, 06:29 PM | #81 |
Rep 50
OK, fair enough. The FA date was 0312, I changed it to 1211 but I got an error about not everything in my FP was available in 1211. I then tried 0313, but got the original error (Failed to get CAFs for SWE). Should it be something else?
10-23-2020, 06:52 PM | #82 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
Try 1115.
11-04-2020, 11:54 AM | #84 |
Rep 40,789
12-22-2020, 08:36 AM | #86 |
Rep 40,789
If you cannot Inject CAFD, then you must flash it.
01-24-2022, 06:54 AM | #87 |
Rep 59
I have Retrofitted a NBT in my car and lately i got a Tyre Pressure Warning, checked all my tires and they were all good.
I then tried to reset the warning, but with no result, this is a 2010 F10 so i don't have the valve types that is in the rims. But anyway, i tried to code the entire tire Pressure thingy away, but somehow i cannot acess my Kombi, since i have managed to code it away in the NBT_Hu i guess i will also have to code it away from the KOMBI. But i get this error: https://f30.bimmerpost.com/forums/at...1&d=1643028857 |
01-24-2022, 06:57 AM | #88 | |
Rep 40,789
