BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Quick question about belly pan part
Studio RSR
      09-12-2019, 05:14 AM   #1
canman111
Drives: F30 328i RWD
2014 BMW 328i  [0.00]
Hi guys,
Question for you,
I was removing my front belly pan to inspect something when i noticed that this other smaller squareish piece was leaning on it.
From memory when i removed the belly pan to install some parts before, i dont remember this piece being there. ( meaning its fallen recently?)
It looks like this
https://www.realoem.com/bmw/enUS/sho...diagId=31_0942
Part number 13
https://www.ecstuning.com/b-genuine-...n/31146850067/
I cant figure out where it belongs, or how it stays up. I thought it slotted into something but it didnt stay there securely. Right now its kind of resting against my belly pan.
Any ideas?
      09-12-2019, 05:42 AM   #2
jh_f30
jh_f30's Avatar
1307
Drives: 2013 335i Sportline Auto RWD
Originally Posted by canman111 View Post
Hi guys,
Question for you,
It looks like this
Part number 13
Any ideas?
If it's part #13 in the diagram, the rearward part (the side with the 2 rings) sort of slides/hooks to the subframe in the area where the (2) is in the diagram. On the forward side, it's held in place with 3 screws (part 14) that screw into 3 white plastic grommet-like pieces (part 15-expanding nut) that are set in the front axle support (part 1). If those screws are over-torqued, the expanding nuts can crack and the hex screws won't hold. I replaced all 3 of my expanding nuts a little while back. While waiting for the parts to arrive, I held it up with a couple of zip ties.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~
      09-12-2019, 06:12 AM   #3
canman111
Thanks for your quick response jh_f30
Im not sure how that part would have come off if it is usually attached with 3 screws.
Ill have a look under the car again when i have the chance.
Do you reckon i might need to buy 3x no.15 (and no.14) as well if the part has fallen off?
Is it worth considering if the part is also necessary or should i just not have it in.
      09-12-2019, 10:28 AM   #4
jh_f30
jh_f30's Avatar
1307
I agree that it seems very unlikely that all 3 anchor points are faulty. But if so, the parts are super cheap; I just prefer having it there as I assume BMW designed it as such for a reason. Plus, I think the main belly pan anchors into it at a couple of points.
It'd be better if you can get under the belly pan and take some pics so we can try to positively identify what it is. I would call it trapezoidal rather than squarish, so I'm not convinced that what you're seeing is #13.
      09-12-2019, 05:55 PM   #5
canman111
Thanks for your help.
I'll put up an update when I get under again
