BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > Error reading code
      12-12-2021, 05:51 PM   #1
andylew0
andylew0's Avatar
Wales
Drives: BMW X2 S 2.0
Error reading code
Not sure if I’m right category so apologies in advance. Anyone have any idea why Bimmer code won’t read my front right headlight. Comes up with “Error while reading coding data” Car is an X2 2018 2.0’sdrive.
Thanks
Andrew.
https://f48.bimmerpost.com/forums/at...1&d=1639353043
      12-17-2021, 12:58 AM   #2
brown7
Drives: bmw x3
Bimmercode cannot do OBD-II diagnostics or clear codes, but the dongle that it needs can be used with other mypascoconnect software since that is myloweslife actually what it is intended to be used for
      12-17-2021, 07:46 AM   #3
andylew0
andylew0's Avatar
Wales
Originally Posted by brown7 View Post
Bimmercode cannot do OBD-II diagnostics or clear codes, but the dongle that it needs can be used with other software since that is actually what it is intended to be used for
I’m aware of that hence I also have BimmerLink. Bimmercode reads the left hand headlight. But not the right. So basically I can code brightness on the left headlight but not the right. Bimmer are aware of the issue. And are looking into a solution. As for some reason the right hand module is different.
      02-17-2024, 04:58 PM   #4
Galib_J
Drives: BMW M4 COMPETITION F83
Update for solution
Hi, I have the exactly same issue on my f83 LCI. Have you been able to sort it out and find a solution?
      02-18-2024, 04:13 AM   #5
andylew0
andylew0's Avatar
Wales
Hi sorry no not found a way around it. To be honest I’ve not looked for quite some time to see if bimmer ever came up with a fix after I reported it.
