BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > New LCI Headlights Retrofit and Coding Helping
proTUNING Freaks
      11-17-2023, 09:50 AM   #1
valeron06
Drives: Bmw F30
Hello,
I have lci LED headlights, but the parking/daytime lights malfunction and turn off. How can I code it? I can use the ESYS program. Angel eyes do not work and I constantly get a warning that the parking/daytime lights are faulty.
      11-17-2023, 10:37 AM   #2
TheNine90
Drives: bmw
You can use esys to code the modules. If the are missing cafd you can inject the cafd.
      11-17-2023, 11:38 AM   #3
mig2830
Drives: F30 340I
The LCI LED head lights are communicating on K_Can2. the coding will probably need to be done with a different production date and year in the VO/FA
      11-17-2023, 12:24 PM   #4
valeron06
Drives: Bmw F30
Actually, the LCI headlights I use are direct plug-in. socket is one of those suitable for socket. I don't know how to delete or introduce the fault from the FemBody module
      11-17-2023, 12:25 PM   #5
valeron06
Drives: Bmw F30
how can I do that?
      11-17-2023, 12:59 PM   #6
TheNine90
Drives: bmw
Change the fa and modify according to the headlights. Load the fa, read svt actual, select the required modules and press code button
      11-17-2023, 01:24 PM   #7
valeron06
Drives: Bmw F30
I know how to use esys, activate fa, read svt and edit fembody cafd, then I don't know which module to enter and edit. mapping_standl? mapping_parkl? mapping_tagfahrl? Which one of these or which code should I change? Likewise, I cannot increase the LED brightness.
      11-17-2023, 01:27 PM   #8
TheNine90
Drives: bmw
Are you asking to code the headlights or modify the cafd?
      11-17-2023, 01:56 PM   #9
valeron06
Drives: Bmw F30
Can you give the codes for both?
      11-17-2023, 02:04 PM   #10
TheNine90
Drives: bmw
Seems you dont know what you are asking for.
First do necessary steps for LCI headlight retrofit, confirm wiring, modify fa to match the LCI headlight,if there are still error then check the coding file.
      11-17-2023, 02:09 PM   #11
valeron06
Drives: Bmw F30
I don't know how to pair it with lci headlights. Can you tell me the direct line of code and the command I need to change?
      11-17-2023, 02:18 PM   #12
TheNine90
Drives: bmw
What have you done so far?
The LCI has different date and typecode. Cant be sure since i dont have much infomramtion about the car. I can have a look at it and see what needs to be done.
      11-17-2023, 02:21 PM   #13
valeron06
Drives: Bmw F30
I activated it and coded it and the fault was cleared and the parking lights came on. Then it gave the same error again and the parking lights went out.
      11-17-2023, 02:24 PM   #14
TheNine90
Drives: bmw
What are you trying to do with that coding? Disable the parking lights?
      11-17-2023, 02:26 PM   #15
valeron06
Drives: Bmw F30
No, I want to turn on the parking lights,( so angel eye). It malfunctions and does not light up.
      11-17-2023, 02:36 PM   #16
TheNine90
Drives: bmw
If its working before then issue is not here in coding.
      11-17-2023, 02:38 PM   #17
valeron06
Drives: Bmw F30
I really don't know what to do. When I connect via cable, I activate a feature and it works, but after a day it goes off again and malfunctions. I couldn't solve the problem
      11-17-2023, 08:59 PM   #18
TheNine90
Drives: bmw
What are the fault codes?
      11-18-2023, 12:49 AM   #19
valeron06
Drives: Bmw F30
daytime running light parking light malfunction
      11-18-2023, 06:09 AM   #20
TheNine90
Drives: bmw
You have confirmed the hardware is OK?
      11-18-2023, 07:51 AM   #21
valeron06
Drives: Bmw F30
How?
      11-18-2023, 11:42 AM   #22
TheNine90
Drives: bmw
The wiring, headlight modules
