03-06-2020, 02:06 AM | #1 |
Rep 91
Sliding the F30 / 320
Noob question over here, but for years I drove a fwd, and during the high school days I'd do the occasional e brake rips, or would turn off traction systems and get a Chevy Cruze 😂 to "slide" for a bit.
My thing is, I know for something like an m3, giving it a little gas while making a left turn for example will kick the rear out. I see with the 320 with it's limited power, I wasn't able to fully do this. Got it to slide a little once, but it overcorrected to the other side. Was hoping to get some more knowledge on this, so I don't hug a pole one day😂 |
03-06-2020, 04:53 AM | #2 |
Rep 518
What are you asking for.... a gained skill????
Either take your car out and learn how to drive it, or stop fkn around dangerously. You clearly don't know what you're doing, especially when YOU think that the car overcorrected itself. Nope, that was all you and not knowing wtf you were doing. I've got a 330i xdrive, and I can drift it easily in the snow. I don't have the balls to force a slide on dry pavement because I'd have to increase speed by a larger amount than I'm willing to fk up at with our only car. |
03-06-2020, 05:04 AM | #3 |
Rep 923
I can't tell you how many threads began with 'I was drifting' and ended up being 'need new shocks, wheel, etc. Often because of curb; often because of potholes; always because of physics.
OP...it's an expensive toy. If you don't have others to play with, treat this one nicely. I'm old, that's why I sound this way.
03-06-2020, 05:11 AM | #4 |
Rep 518
Also, if you're wondering how far my "skill" goes, in the snow I'll drift it on empty streets in an industrial park, late at night, and upto about 90kph. That's a 90kph slide that is continuous for about 150 to 200 meters, in my own lane. I'd try faster but I can't see the oncoming lane at the exit and it's over a crest for where I can do that one. Aside from that one spot, I'll keep it around 60 or 70.
On dry pavement. I've done 90 on a cloverleaf and the tires just barely started to let loose after a little squealing. |
03-06-2020, 10:37 AM | #5 | |
Rep 91
03-06-2020, 10:38 AM | #6 | |
Rep 91
03-06-2020, 10:42 AM | #7 | |
Rep 91
03-06-2020, 11:28 AM | #8 | ||
Rep 844
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
SportySpice204.00 tex26702412.50 |
03-06-2020, 11:28 AM | #9 |
Rep 518
Yeah..... I've drifted every vehicle I've ever owned so I know how they'll respond in an emergency situation.
Just because you don't understand that it's more difficult to drift an AWD vehicle over a RWD. Especially when you think an M3 only gets loose when turning left lol. Since you obviously don't know anything about drifting an underpowered car, go look up Keiichi Tsuchiyas drift bible. It will show you how to slide an underpowered car. |
03-06-2020, 11:28 AM | #10 |
Rep 2,433
Drives: 2021 M2C
Well this thread is heading in the right direction.
03-06-2020, 02:45 PM | #11 |
Rep 36
03-06-2020, 04:33 PM | #13 |
Rep 891
Sign up for a car control clinic that has access to a skid pad. After you can sustain a slide around the pad move onto autocross. Closed course. Always.
03-06-2020, 04:59 PM | #14 |
Rep 518
Yup I can drift my AWD in the snow.... you know it takes more skill to drift a vehicle that is made to have the most traction and stability possible right?
You're also aware that just because it's AWD doesn't mean it isn't a heavily rear bias AWD system, it's not like a Subaru with symmetrical AWD. I owned the 2002 WRX when it came out for a year, and I can tell you it handled a lot better in the snow with it's AWD system. By handling better I mean it was almost impossible to get it out of line and keep it sliding. Whereas the BMW allows you to turn off driver aids and let's you play. |
03-06-2020, 05:46 PM | #15 |
Rep 103
I don't have the 320 but have a RWD 4 series. With all the computers on, kicking the back out is quite hard - you have to be pretty violent with it - even with a larger engine. With a 320 I would expect you to have to really throw it hard over to break grip.
My car has a sport + mode that turns off the ASC without completely disabling all the safety features - that mode allows for a little more twitch on the back end. Of course turning all the safety features off gives you the best chance of stepping the back out - but as another contributer pointed out - now you're really on your own so handle with extreme caution. Sport + mode allows me just enough slide to break grip a little in a corner and you always have to be waiting for it so you catch the slide with some opposite lock. If it catches you unawares, be prepared to spin. Not something for the public road until you're really familiar with the dynamics of your vehicle. |
03-06-2020, 07:27 PM | #16 | |
Rep 338
2013 320ix N20 8AT|BM3 stg1|Muff Res Delete|HPB-LED-Amber-DRL's
IG: DadzBmer_N2o |
03-06-2020, 08:08 PM | #17 |
Rep 518
I raced my WRX everywhere, before knowing they had a glass gearbox, no issues with mine though, and for me I found you just needed balls to push the gas when you would think you should be braking.
I was racing a guy in traffic (I was young then) down a highway, switched from the middle lane to left most, he went to the right lane, the left lane cars were slowing for no reason, I had barely passed the car in the center lane, whipped it to the right, went completely perpendicular to the flow of traffic, got the front half of the car in the middle lane, counter steer the slide, floor it, and it straightened out like a dream, back in the middle lane. I definitely got lucky, but it was go big or go into the back of the car in the left lane. Certainly wasn't something I'd recommend. Another time I was cruising through a blizzard, about 8 to 12 inches of snow on the ground, late at night, I was doing maybe 120 and a cop pulled out to get me from a 3way intersection, I watched him sliding across all 3 lanes for about a block before he straightened it out, I just slowed and let him catch up, no real way to get away from him radioing ahead, I was one of the only cars on the road that night so I'd be easy to spot, pulled over and he just told me to slow it down a bit. I wasn't drifting then, just driving faster than conditions would dictate as being safe.... despite not sliding around at all. |
03-06-2020, 08:51 PM | #18 | |
Rep 91
*this was what im looking for a while now, didnt know what its called Last edited by F30Unit; 03-06-2020 at 08:57 PM.. |
03-06-2020, 08:53 PM | #19 | |
Rep 91
Thanks for your reply. Yeah I know an event that has a place for burnouts or drag strip, good place to go. But thats what I wanted to know really, how hard is it to let the rear out. Interesting knowing the 4 series also needs a kick |
03-06-2020, 08:55 PM | #20 | |
Rep 91
03-06-2020, 09:04 PM | #21 | |
poopycat
266
Rep 791
CA, bahahahahahahahah I'll bet you are stuck on oberlin. Please leave. |
03-06-2020, 09:22 PM | #22 |
Rep 518
Yea it was aggressive and it was meant to be. You don't seem like you have even the basic theory down, let alone any of the practical knowledge, and certainly none of the skill required.
it's an expensive thing to get in to as well, I don't know what rims and tires you have on yours, but the 330i has low pro 18 inch tires, looking at about a grand for a set, and you'll easily be blowing through a set a year if you start driving hard, let alone drifting. Look up the video I suggested and check actual driving course videos, underpowered means you'll have to work at the upper limits of speed to get it sideways, or really thrash it hard. More power makes it easier to get sideways at more easily manageable speeds, which lessens the chance of something catastrophic happening because of your lack of knowledge and ability. I've been driving since I was 15, I'm just under 40 now, and I have drifted every vehicle I've owned to gain the knowledge and ability I have(at least 10 different vehicles), and it definitely wouldn't hurt me to take a driving course to learn more. Watch Initial D as well, it may be just some anime series, but keiichi tsuchiya was the consultant for the show, so it's not all hot air and guesswork. Last edited by Icarium81; 03-06-2020 at 10:57 PM.. |
Tags |
drift, driving, f30, knowledge, sliding |
