09-14-2018, 02:54 PM | #89 | |
Moderator
7515
Rep 19,368
Furthermore, the vehicle you photographed is not a US spec vehicle since it is an X5 30d model which had never been a candidate for US sales to begin with. A large percentage of SAVs built in South Carolina are for export. It's no surprise to see a non-US-spec test vehicle with SC plates like this out on US roads occasionally, especially on the east coast. |
09-14-2018, 03:01 PM | #90 | |
Rep 11,891
Porsche Cayenne SEH owners are reporting over 30 MPGs of gasoline use on the highway. The Cayenne diesel returns 28
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
09-14-2018, 04:43 PM | #91 | |
Rep 2,349
09-14-2018, 06:24 PM | #92 | ||
Rep 1,447
09-14-2018, 09:27 PM | #93 | |
Rep 11,891
Compensate for 25% disadvantage? You're just making numbers up now. The fact is diesel SUVs are getting no more than 30 MPGs on the highway. Cayenne SEH owners are all reporting numbers north of 30 for highway driving. http://www.fuelly.com/car/porsche/ca...otpedlr/341217 Your fuzzy math analysis is so flawed it's not even funny.
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) Last edited by Flying Ace; 09-14-2018 at 09:34 PM.. |
09-14-2018, 09:35 PM | #94 | ||
Rep 1,447
09-14-2018, 11:20 PM | #95 |
Rep 2,349
Diesel has 15% more energy per litre so it should have at least 15% less consumption. Typically a diesel version of the same car will have a lower diff ratio as well, combined with a more efficient engine design (no spark plugs and higher comp ratio) I'd expect 20-25% difference in fuel consumption would be about right.
Of course a PHEV might be able to match it for the first 100 or even 200 miles but at 500 miles the Diesel will always pull ahead. |
09-15-2018, 07:01 AM | #96 | |
Rep 15,858
We have direct comparisons here in the UK for several model ranges. For example, the 330e (fully charged each night), can never compete for high mileage users, against the diesels of similar performance. The diesel is way ahead on fuel efficiency. * Here in the UK, many smaller ICE installations have proven to be less efficient when cruising at highway speeds, than the same model with a larger capacity ICE. Total road load can be very similar. To the point manufacturers are questioning/debating the benefits of the smaller, more highly tuned engines. This doesn't help the PHEV case, when batteries are depleted. PHEV has its place, but at present, efficiency for long distance use is questionable. |
09-15-2018, 10:06 AM | #97 |
Rep 71
Just as they limit production of less-popular models contrasted to others, there still is a demand.
This is from my 2014 535d on the highway.. No gas engine would ever compare.. |
09-15-2018, 11:50 AM | #98 | ||
Rep 2,858
BMW NA executives will drive US market vehicles prior to market release, as this has been told directly to me by these executives who drive these vehicles. Regarding my tone, I'm sure that President Trump would have also stated the same, as unfortunately it's accepted language.
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
09-15-2018, 11:52 AM | #99 |
Rep 2,858
Dam, compare that to my 2018 X5M which averages 14 mpg, as the range is sub 400 miles when the tank is filled up.
09-15-2018, 12:26 PM | #100 | |
Rep 5,824
The media were there to drive the relevant models available for the new X5 Series. Amongst the US market models of the petrol engine variety. There was also the Diesels including the high performance M50d available to drive. Because it's an international launch. The majority of markets of the X5 Series maintain the Diesel as the best selling model of that series that is why these models 30d and M50d are being shown in the US for media purpose only and not as respective inclusion to that particular market.
The M850i is evidence that BMW have got their mojo back when it comes to dynamic sports cars...
Ibiza3611.50 |
09-15-2018, 03:32 PM | #101 | |
Rep 2,349
One thing with diesel is that it doesn’t seem to matter much if you get a 520d or a 535d for open road driving, the mpg only changes a small amount when compared to a 530i and 540i - at least in my experience |
09-15-2018, 03:37 PM | #102 | |
Rep 2,349
However from Napier to Taupo which has a large number of hills and some quite twisty bits there was a much smaller difference, about 10% and the 328i definitely needed to be pushed quite a bit harder. The big thing here probably is that the 335i could drive up the hills and out of the corners with ease and not making a huge amount of boost, in turn keeping the AFR much closer to 14.7 for longer. 100% agree about the 330e and 530e being flawed. Mainly because of the 46l tank limiting range At least the X5 PHEV has a bigger fuel tank and larger capacity batteries. If you could physically fit that drivetrain into a 540e or 545e with a 60-70l tank it’s be a great car Last edited by brad850csi; 09-15-2018 at 03:43 PM.. |
HighlandPete6658.50 |
09-15-2018, 05:18 PM | #105 | |
Rep 15,858
With the current backlash on diesel and the complexity of emission controls, can't see the diesel having much of a chance at this critical time in PHEV development. Diesel will have to cope a lot better with cold and intermittent running. |
09-15-2018, 07:05 PM | #106 | ||
Rep 1,447
09-15-2018, 08:47 PM | #107 | |
Rep 317
-Michael |
09-16-2018, 01:25 PM | #109 |
Rep 1,447
I'm sure a phev will do even better . Diesel is the highway king
09-16-2018, 01:27 PM | #110 | |
Rep 570
