04-30-2020, 12:54 PM | #45 | |
Rep 4,456
04-30-2020, 03:12 PM | #46 |
Rep 56
04-30-2020, 03:18 PM | #47 |
Rep 4,456
04-30-2020, 06:37 PM | #48 | |
Rep 740
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
04-30-2020, 06:39 PM | #49 |
Rep 740
i dont think you posted the link, but do you have issues where the corners are, around where your thumb would be placed? like wrinkly?
04-30-2020, 06:41 PM | #50 | |
Rep 4,456
https://f30.bimmerpost.com/forums/sh....php?t=1701538 |
06-05-2020, 07:04 PM | #51 |
Rep 740
If anyone needs a heated steering wheel and the switch cluster, I have one for sale!
https://f30.bimmerpost.com/forums/sh....php?t=1725357
06-18-2020, 11:38 AM | #53 |
Rep 379
Anyone has an M steering wheel heated + vibration module for sale ?
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
01-19-2021, 07:35 PM | #56 |
Rep 33
Hi I was wondering if any one had the wiring diagram for the switch itself to the szl I was able to find the right connecter off a old dei alarm shock sensor that fit perfectly. Or tell me where the 3 PINs go. There all black so hard to tell on the pictures online. https://c1552172.ssl.cf0.rackcdn.com/641972_x800.webp
01-20-2021, 04:32 PM | #57 | |
Rep 525
08-08-2021, 11:55 AM | #58 |
Rep 4
Drives: BMW F36 420d xDrive
Very good job!
Thanks for the guide |
08-22-2021, 06:52 PM | #59 |
Rep 57
Well, I am about to give up. I have done all the physical connections. Checked and double checked. Still no heated wheel. I keep getting an error that the cafd dile is not found for the FEM and REM. Kombi codes no problem.
08-28-2021, 07:57 PM | #60 |
Rep 421
Drives: 2017 F31 328dx
I completed this retrofit today. Had everything I needed save for the button and since the steering wheel I bought online had heat so I figured why the hell not. Thanks for the write up, it definitely helped a ton. Thankfully I didn't run into any coding problems.
01-25-2022, 04:19 AM | #63 |
Rep 30
Thanks for the write up!
I'm trying to work out if I need a new SZL to do this retrofit or if I'm ok just getting the switch, cowling and a second-hand heated wheel. roxxor could you take a look at these pics of my wiring and let me know what you think? |
01-26-2022, 10:28 AM | #64 |
Rep 1,142
Interesting that yours has those wires already run. Do you have any other options such as Lane Departure Warning, Blind Spot Monitor, etc.? Based on your part number, it shouldn't have those pins as the part number you have is for basic models with only the Rain Sensor option and not anything additional.
01-27-2022, 02:42 AM | #65 |
Rep 18
For me, the situation is similar. The power cords are there. You have to buy a different SZL, or try to re-plug the wires and you may be able to code it on this SZL. Unfortunately, it did not work for me.
01-28-2022, 10:05 AM | #66 | |
Rep 30
So those two chunky wires I indicated are the wires which would/could power the steering heater? I wonder if next step is to pop the airbag off and look inside the wheel? |
