10-25-2023, 06:11 AM | #89 |
Rep 1,582
Based on the photos in Ebay.UK, they look the same as the US ones.
10-25-2023, 10:46 PM | #90 | |
Rep 1,582
So the only way to jerry-rig it (and not sure it's worth it) is to add two receptive pins in the plug itself, take the stalk and clock-spring apart and run the two wires from those two pins on the inside to the factory pins on the clock-spring plug that supplies power to the steering module. Do not want to risk the ribbon cable's free movement inside the clock-spring.
11-09-2023, 09:13 AM | #91 | |
Rep 47
I have the same thing as you. Did you manage to get the heating working without changing the SZL? Or anyone had the same and managed to make it work? My part no of SZL says that it doesn't support heated steering wheel but I have the plug for the wire on it and also the wires needed to the FEM already added LE:https://www.realoem.com/bmw/enUS/partxref?q=61319351145 this is the SZL that I have currently Last edited by minulache; 11-09-2023 at 11:10 AM.. |
11-10-2023, 11:50 PM | #93 | |
Rep 1,582
https://f30.bimmerpost.com/forums/sh...146335&page=10 A control unit part number has different configurations where one of them may not show steering wheel heating, but the same part number may have one or two configurations where it does have it. https://www.realoem.com/bmw/enUS/sho...diagId=61_2808
11-11-2023, 05:33 AM | #94 |
Rep 47
So I figured it out, had to change the steering column switch. I have the wires in the 9 and 11 in the 12 pin socket, I also had the pins in the back of the steering column switch but I didn't see that in the front one where you plug the heated steering I didn't have any pins. Today I got all the parts and gonna do the retrofit. Fingers crossed!
Thank you very much fe7565 |
11-11-2023, 10:31 AM | #95 |
Rep 47
Finished the retrofit, all working good. Thank you for the guide! Just as a note, after I VO coded the car I had to get out of it, lock it and leave it for a few minutes and then it worked. Right after I did the VO Code it didn't want to work.
11-13-2023, 02:42 AM | #96 |
Rep 1
Just finished installing the heated steering in my bmw f20 2012. It works wonderfull!
Both pins of the wire going in the back of the szl snapped in half in the process but its all working perfectly now. Fuse 144 was free aswell for my model so that was a relief. So for other people with f20s, its the same pretty much! The only difference was that the plug mentioned for connecting to a fuse in the back didnt work for me bc there was no plug to get it into.. i used a flat plug sleeve to connect to the fuse. Otherwise it would just fall out. |
11-26-2023, 01:57 PM | #98 | |
Rep 38
Thanks Daniel |
11-27-2023, 02:30 PM | #99 |
Rep 47
You just need to find a SZL that has the pins in the front (and the options lika HBA if you have them), that's all. Don't look at part numbers etc because you'll become more lost)
11-28-2023, 01:35 PM | #100 | |
Rep 525
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
11-28-2023, 03:56 PM | #101 |
Rep 47
And you will see that the same part no is listed with heated steering wheel and without steering wheel. What do u do then...
12-06-2023, 08:15 PM | #102 |
Rep 4
f30 heated swheel retro
I have replaced the steering wheel (twice) and the lower steering column with switch and doen the coding several times. I also replacced the clockspring with a heated one. The switch illuminates and the dash says steering wheel heat activated etcetera. I just don't have heat in the wheel. Any other things I should check?
thanks for all the help getting this far |
12-08-2023, 04:31 AM | #104 |
Rep 525
Choise right one... Actually you doesn`t have clue why is this so
12-09-2023, 02:36 PM | #105 | |
Rep 152
01-03-2024, 04:33 AM | #106 |
Rep 28
I have the following SZL with BMW part number: 61319351145
According to BMW it doesn't support a heated steering wheel, but on the back I do see the pins for the button. And on the front I see also some extra pins, so does this support heated steering wheel or not? |
01-03-2024, 09:07 PM | #107 |
Rep 1,582
fabje
Based on this, looks like it only supports rain sensor and high-beam assist. https://www.realoem.com/bmw/enUS/sho...59#61319351145 Not sure, if your module can be programmed in Esys or reflashed to include the other options as well. But you could replace the module with another one that has the feature you need. May need to run a couple of extra wires. That is, IF the pins are already there in the clockspring/steering wheel switch unit. Besides the steering wheel heater switch pins, you also need the extra power and ground pins here (circled green). On Ebay USA, the modules are close to the same price as an entire steering wheel with a (matching) module still inside. Example for $90 with module inside (red circle): Here is an example of the SZL module:
01-04-2024, 03:54 AM | #108 | |
Rep 525
You can`t flash SZL on f30 it is not ecu separately. Second thing there is no pins for power and ground(green circle) so you can`t fire up SZL.
